0 Replies Latest reply on Oct 4, 2013 9:02 AM by M.Su
    Tallying Fields (Multistate)
    M.Su Level 1
      I have a series of faked multistate check box style fields for indicating gender, such as 'M' for male and 'F' for female. The document script is at the bottom.
      Is there a way for a field to total the number of males/females?
      Also, in a similiar vein, is there a script that can essentially calculated the number of fields that are filled with text? For example, if Fields 'A', 'B', and 'C' are filled, then 'D' would show '3'.
      ___________________________________________________________
      // Array for Button Text and Text Colour
      var bButtonText = [];
      bButtonText.push(["M", color.black]);
      bButtonText.push(["F", color.black]);
      bButtonText.push(["", color.black]);
      var setNextButtonVal = function (f_name, ap_array) {
      // Retrieve value of text box associated with multistate button
      var f = getField(f_name);
      var val = f.value;
      // Increment the value by one
      val += 1;
      // Return to beginning if value cannot be located
      if (typeof ap_array[val] === "undefined") {
      val = 0;
      // Update text field value to trigger validation script
      f.value = val;
      var setNewButtonText = function (b_name, caption_array, val) {
      // Set button text as indicated in array
      var f = getField(b_name);
      f.buttonSetCaption(caption_array[val][0]);
      f.textColor = caption_array[val][1];
