2 Replies Latest reply on Aug 10, 2006 6:15 AM by vinnio
    update variable from a textfile?
    vinnio Level 1
      How can I update a variable from a textfile into a frame? The hard part is that I want to keep the same variables in the textfiles and I want only change the textfile name.
      example script on a frame,
      new loadVariablesNum(page);
      page = loadVariablesNum("data/img_autonoom.txt", 0);
      variable example is from a textfile is &link1, &link2 and that I will use for my movieclips as _root.link1 _root.link2 etc.
      already thanks for your time!
        • 1. Re: update variable from a textfile?
          Level 7
          vinnio,
          I think you're asking how to load a variable from a text file, right?
          This is the part I don't understand. You cannot change the text file's
          name from Flash. You can reference a text file by its current name, and you
          can load variables stored in that text file, but that's the extent of it.
          Line 1 (with the term "new") is not necessary, here. loadVariablesNum
          is not a class or method, it's just a function. There's nothing to
          instantiate, such as you would with, say, an Array instance. Just call the
          loadVariablesNum() function in a line by itself.
          Line 2 acts as if loadVariablesNum() returns a value, but it doesn't.
          The variable page will not be updated in this manner. Simply call
          loadVariablesNum() and supply a) the path to to your text file and b) the
          level into which you'd like to load the variables stored in that text file.
          If that text file *contains* a variable named page, then page will become a
          variable in level specified, and its value will be the value set for that
          variable in the text file. Make sense?
          This is all spelled out in detail in the ActionScript 2.0 Language
          Reference, by the way. You might also consider using loadVariables() or the
          LoadVars class (that one does require the "new" line).
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: update variable from a textfile?
            vinnio Level 1
            Thanks David! It's makes more sense now. I think I have to study more in ActionScript 2.0 Language...
