1. Re: Error 48 @include
Dwight L Oct 8, 2013 9:39 AM (in response to Dwight L)This was a stumper, eh? I figured out what caused the Error 48, so here it is in case someone else stumbles across it.
The problem is with how the path is parsed. It contains this phrase: "Adobe Photoshop CS6 (64 Bit)", and those spaces create a problem for Photoshop's Javascript engine. Because that folder (with spaces) is created by the Photoshop installer, my programmer mind says that this is a bug.
2. Re: Error 48 @include
Chris Cox Oct 8, 2013 9:58 AM (in response to Dwight L)OK, have you contacted the maker of your ZogArt scripts and told them about this?
3. Re: Error 48 @include
Dwight L Oct 8, 2013 12:10 PM (in response to Chris Cox)You have a solution, Chris?
4. Re: Error 48 @include
Chris Cox Oct 8, 2013 12:33 PM (in response to Dwight L)No, I don't know anything about your third party scripts.
You need to contact the maker of those scripts.
5. Re: Error 48 @include
Dwight L Oct 8, 2013 5:35 PM (in response to Chris Cox)Thanks for taking a whack at the old ball, Chris, but I'm not sure there's much to be said really. These are not third party scripts. I am the programmer, and I just contacted me and I agreed completely about the problem. That makes two of us now who think this is a bug. <smile>
These scripts work in PSCS3, but there were no spaces in the folders the Adobe installer created back then. I could create a spaced path and test it in CS3, but that serves no purpose. Since the Adobe Javascript engine cannot correctly parse the path the Adobe installer created, I say there is a bug, either in the installer or in the Javascript engine. Am I wrong?
I'll have to move my functions file to another folder whose path does not confuse the engine, and make corrections if this bug reappears in other code. This error looks like a pretty insignificant fix for a good programmer, but I'm an old man with old ways, and things are maybe not so easy as they look to my clouded eyes.
In case I'm completely misunderstanding you, are you able to write Javascript code with an Include statement that points to a file with spaces in the path to be parsed?
6. Re: Error 48 @include
Chris Cox Oct 8, 2013 7:56 PM (in response to Dwight L)Without seeing the rest of the code, I'm not sure why you are unable to handle spaces in filenames.
I'd need an example to test and see why your code might be going wrong.
7. Re: Error 48 @include
Dwight L Oct 9, 2013 8:40 AM (in response to Chris Cox)OK, that's simple enough. Create two text files with .js extensions in the script folder, C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Presets\Scripts\. Name one file Test.js, and the other Functions.js. In Test.js you need a single line: \\ @include C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Presets\Scripts\Functions.js. You can quote the path or not. Functions.js can be left empty. Start Photoshop, then <File>, <Scripts>, <Test>. Error 48.
8. Re: Error 48 @include
Dwight L Oct 11, 2013 1:12 PM (in response to Dwight L)Chris, are you there? Have you reproduced the error? I'm not sure what to do. There was no problem with spaces in the path string until I migrated the code from CS3. I'd like to keep my code in one folder if possible.
