2 Replies Latest reply on Oct 15, 2013 1:28 PM by mrslother
    Loop on all items in a collection
    Dan-BTP
      I need to loop on all items in a collection in a VB.NET program that is using the InDesign API. For example, I want to loop on all master spreads in a document. Here is my sample code:
          Dim I As Integer = 0
          Dim MyApp As InDesign.Application = Nothing
          Dim MyDoc As InDesign.Document = Nothing
          Dim MyPage As InDesign.Page = Nothing
          MyApp = CType(Activator.CreateInstance(Type.GetTypeFromProgID("InDesign.Application"), True), InDesign.Application)
          MyDoc = CType(MyApp.Documents.Add(False), InDesign.Document)
          With MyDoc
            With .DocumentPreferences
              .PageHeight = "8.5i"
              .PageWidth = "5.5i"
            End With
            With .ViewPreferences
              .HorizontalMeasurementUnits = InDesign.idMeasurementUnits.idPoints
              .VerticalMeasurementUnits = InDesign.idMeasurementUnits.idPoints
            End With
            If .MasterSpreads.Count > 0 Then
              For I = 0 To .MasterSpreads.Count - 1
                Dim ThisMasterSpread As InDesign.MasterSpread = CType(.MasterSpreads.Item(I), InDesign.MasterSpread)
              Next I
            End If
          End With
      When it executes, I get an error on the last Dim statement that defines ThisMasterSpread. It highlights .MasterSpreads.Item(I) and gives the following error:
      COMException was unhandled: The requested member of the collection does not exist.
      How do I successfully loop on all master spreads?
      Thanks!
