7 Replies Latest reply on Oct 5, 2013 12:37 PM by kglad
    enabling/disabling function
    Ron Colmen Level 2
      I'm using the below code to display 'help tips'. Now I want to use a buttton to enable / disable tipS()
      I tried using an IF condition within to tipS, but failed. How can I achieve the enabling/disabling?
      function tipS(tagTarget, helpTips) {
                tagTarget.onRollOver = function() {
                          h = _root.createEmptyMovieClip("h", 5);
                          h.attachMovie("tipBox", "tipBox", 10);
                          //other stuff - x,y, autoSize,backgroundColor,etc...
                          h.tipBox.message.text = helpTips;
                          h.onMouseMove = function() {
                                    //x & y
                tagTarget.onRollOut = function() {
                          removeMovieClip(h);
      tipS(mc, "text");
        • 1. Re: enabling/disabling function
          var tipsOn:Boolean;
          if(tipsOn){
                                        //x & y
                              removeMovieClip(h);
          } else {
          delete tagTarget.onRollOver;
          delete tagTarget.onRollOut;
          tipS(mc, "text");
          • 2. Re: enabling/disabling function
            Ron Colmen Level 2
            Thanks. I did this - did not work?
            tips_btn.onRelease = function(){
                      tipsOn = !tipsOn;
                      //trace (tipsOn)
            • 3. Re: enabling/disabling function
              that will work to toggle tipsOn as long as you used that first line of code i suggested:
              var tipsOn:Boolean;
              • 4. Re: enabling/disabling function
                Ron Colmen Level 2
                Yes, I have included that. But does not wok.
                var tipsOn:Boolean;
                          tipsOn =!tipsOn;
                          //trace (tipsOn)
                function dyoTip(tagTarget, helpTips) {
                          if(tipsOn){
                                    h.attachMovie("toolTip_MC", "toolTip_MC", 10);
                                    h.toolTip_MC.message.text = helpTips;
                                    removeMovieClip(h);
                } else {
                dyoTip(a_mc, "test A");
                • 5. Re: enabling/disabling function
                  use:
                  tips_btn.onRelease = function() {
                      tipsOn = !tipsOn;
                      dyoTip(a_mc,"test A");
                  • 6. Re: enabling/disabling function
                    Ron Colmen Level 2
                    Thanks Kglad.
                    • 7. Re: enabling/disabling function
                      you're welcome.
