11 Replies Latest reply on Oct 5, 2013 12:26 PM by kglad
    BitmapData Loader
    Ron Colmen Level 2
      I'm working on a project which exports an image using BitmapData to a serverside script. Is it possible to do a loader to determine the completion time?
        • 1. Re: BitmapData Loader
          i'm exporting 1280x800 images on a project i just finished and it takes less than 5 seconds?  how long is it taking you and for what size images?
          • 2. Re: BitmapData Loader
            Ron Colmen Level 2
            900 x 600. For most users it takes under 10 seconds.
            My issue is, if there's a break in the users internet connection the bitmap exporting process never ends and the user will never know about it. That's the reason for adding the loader.
            • 3. Re: BitmapData Loader
              the exporting is done with a for-loop that can't be interrupted.  if it takes 10 seconds, your flash should freeze for 10 seconds.  does it?
              • 4. Re: BitmapData Loader
                Ron Colmen Level 2
                yes, correct.
                • 5. Re: BitmapData Loader
                  then all you can do is to "chunk" the for-loop and provide periodic updates.  this is from http://www.amazon.com/gp/product/1435460200/ref=s9_simh_co_p14_d5_i1?pf_rd_m=ATVPDKIKX0DER &pf_rd_s=left-1&pf_rd_r=0BTBFZ0YDPP0ZHKXKTP4&pf_rd_t=3201&pf_rd_p=1280661682&pf_rd_i=typ01
                  do-loops, for-loops and while-loops
                  Loop types that execute from start to end before anything updates on stage include do-loops, for-loops and while loops. They cannot be used to animate objects because no matter what code you use to execute the loop and no matter what you do to (try and) slow it down, it will still execute from start to finish before anything changes on stage. They are appropriately used for rapid execution of code.
                  There is never a situation when you should intentionally slow these loops. However, there are situations when you might want to break these loops into more than one chunk so the stage can update between each chunk.
                  Chunks
                  For example, if you have a for-loop that takes 10 seconds to execute, your game will appear to freeze for 10 seconds after this loop starts. Nothing will update on stage and nothing will respond to user input. Either you should warn your user before starting that loop or you should break that loop into several smaller chunks that allow visual updates to the user so they do not think your game is broken.
                  For example, this for-loop that adds odd numbers (and shows the first m odd numbers sum to m*m) freezes my Flash Player for about 9 seconds.
                  var i:Number;
                  var n:Number=3000000000;
                  var s:Number=0;
                  var startI:Number=1;
                  var endI:Number=n
                  var startTime:int=getTimer();
                  for (i=startI; i<endI; i+=2) {
                         s+=i;
                  // 9 seconds
                  trace((getTimer()-startTime)/1000,s,n*n/4,s-n*n/4);
                  The following technique shows how to break this (and any other for-loop) into chunks that allow the Flash Player to update every second.
                  var i:Number;
                  var s:Number=0;
                  // This is the number chunks into which the previous for-loop will broken. If the // previous for-loop took about 9 seconds, using 10 chunks means there will be updates // about every 0.9 seconds.
                  var chunks:int=10;
                  var endI:Number=n/chunks;
                  var t:Timer=new Timer(100,1);
                  1. t.addEventListener(TimerEvent.TIMER,f);
                  f();
                  function f(e:Event=null):void {
                                s+=i;
                         trace("stage update",startI,endI,s);
                         if (endI<n) {
                                t.reset();
                                t.start();
                         } else {
                         startI+=n/chunks;
                         endI+=n/chunks;
                  • 6. Re: BitmapData Loader
                    Ron Colmen Level 2
                    Thanks for sharing! (as3?)
                    I'll give it a try.
                    • 7. Re: BitmapData Loader
                      yes, that's as3.
                      here it is in as2:
                      var i:Number;
                      var s:Number=0;
                      var startTime:Number=getTimer();
                      var chunks:int=10;
                      clearInterval(fI);
                      var fI:Number = setInterval(f,100);
                      f();
                                    s+=i;
                             if (endI==n) {
                                 trace((getTimer()-startTime)/1000+" "+s+" "+n*n/4+" "+s-n*n/4);
                                 clearInterval(fI);
                             } else {
                             startI+=n/chunks;
                             endI+=n/chunks;
                      • 8. Re: BitmapData Loader
                        Ron Colmen Level 2
                        Thanks once again.
                        The bold line is not recoganized in as2.
                        var i:Number;
                        var s:Number=0;
                        // This is the number chunks Numbero which the previous for-loop will broken. If the // previous for-loop took about 9 seconds, using 10 chunks means there will be updates // about every 0.9 seconds.
                        var chunks:Number=10;
                        clearInterval(fI);
                        f();
                        function f(e:Event=null):Void { //this line requested argument to null doesn't work in as2?
                                      s+=i;
                               trace("stage update"+"  "+startI+"  "+endI+"  "+s);
                               if (endI==n) {
                                   clearInterval(fI);
                               } else {
                               startI+=n/chunks;
                               endI+=n/chunks;
                        • 9. Re: BitmapData Loader
                          use:
                          function f():Void{
                          • 10. Re: BitmapData Loader
                            Ron Colmen Level 2
                            When I run this, the flash player gives a warning (A script in this movie is causing flash player to run slowly...). What's wrong?
                            var i:Number;
                            var s:Number=0;
                            clearInterval(fI);
                            f();
                            function f():Void{
                                          s+=i;
                                   trace("stage update  "+startI+"  "+endI+"  "+s);
                                   if (endI==n) {
                                       clearInterval(fI);
                                   } else {
                                   startI+=n/chunks;
                                   endI+=n/chunks;
                            • 11. Re: BitmapData Loader
                              as2 is slow so that's too ambitious for it.  use:
                              var i:Number;
                              var n:Number=3000;
                              var s:Number=0;
                              clearInterval(fI);
                              f();
                              function f():Void{
                                            s+=i;
                                     if (endI==n) {
                                         trace(((getTimer()-startTime)/1000)+" "+s+" "+(n*n/4)+" "+(s-n*n/4));
                                         clearInterval(fI);
                                     } else {
                                     startI+=n/chunks;
                                     endI+=n/chunks;
