22 Replies Latest reply on Oct 6, 2013 7:51 AM by A.T. Romano
    Video is taking to long
    jeff432006
      why is my church video taking 3000 mins to upload to youtube,i have never had t take that long
        • 1. Re: Video is taking to long
          the_wine_snob Level 9
          Welcome to the forum.
          1. What is the Duration of your Timeline (the length of your video)?
          2. What is your Internet connection type and speed?
          3. Are you uploading directly from PrE, or outputting a file, to be manually uploaded? If the former, I would test with a YouTube output selection for the specs. of your video, and try manually uploading it.
          4. Has your process, for similar video, been quicker in the past?
          • 2. Re: Video is taking to long
            jeff432006 Level 1
            yes it was fast took like 1hr the video is only 30mins long its shows its 6.43gb
            • 3. Re: Video is taking to long
              Jeff,
              What is the Duration of the Timeline, and are you doing this with a direct upload from PrE to YouTube?
              • 4. Re: Video is taking to long
                jeff432006 Level 1
                i have veages studio and never had this trouble and now i got premiere elements 11 its taking way too long to upload
                • 5. Re: Video is taking to long
                  Jeff,
                  Sorry but it will be difficult to help, if we cannot get answers to the questions posed. They might well hold the necessary clues.
                  • 6. Re: Video is taking to long
                    A.T. Romano Level 7
                    jeff432006
                    The answers will be in the details, and the details for us to help you are lacking.
                    What version of Premiere Elements are you using and on what computer operating system is it running?
                    Are you doing a direct upload of a Premiere Elements Timeline to YouTube from within the program using .../Online/YouTube?
                    If so, what Online/YouTube preset are you using?
                    This gets us circled back to "What do you have on the Timeline in the way of video and audio compression, frame size, frame rate, file extension, and the like? What is the duration of the Timeline?" Is your Timeline over the stated YouTube limits for ...Online/YouTube?
                    With more information, we could explore:
                    a. Your Internet connection and YouTube Uploader
                    b. Exporting your Timeline to a file saved to the computer hard drive and then uploading that file from there to YouTube at the YouTube web site?
                    c. The differences between this project and others that you may have gotten to YouTube successfully before.
                    Have you used the try again principle? If so, over what period of time. This may be a YouTube site problem.
                    Let us put the information together and then decide what next.
                    Thanks.
                    ATR
                    Add On..I did not see all of Hunt's posts until after I had one mine.
                    • 7. Re: Video is taking to long
                      jeff432006 Level 1
                      Duration Timeline is 00;30;03;24
                      • 8. Re: Video is taking to long
                        A.T. Romano Level 7
                        jeff43006
                        Is this the first time that you are using Premiere Elements 11's Publish+Share/Online/YouTube?
                        Those requested details will really expedite things.
                        ATR
                        • 9. Re: Video is taking to long
                          jeff432006 Level 1
                          Duraation Timeline is 00;30;03;24
                          • 10. Re: Video is taking to long
                            jeff432006 Level 1
                            yes my first time
                            • 11. Re: Video is taking to long
                              A.T. Romano Level 7
                              jeff432006
                              You will never get that 30 minute upload via Premiere Elements 11 Publish+Share/Online/You. Limit is 2.0 GB/15 minutes 0.00 sec.
                              If you want to get that Premiere Elements Timeline to YouTube, then export to file saved to computer hard drive and then upload that file from there to YouTube at the YouTube web site.
                              If you supply basic information about video size, frame rate, and such, we can give you exact details for your Publish+Share/Computer choices for doing this.
                              Thanks.
                              ATR
                              • 12. Re: Video is taking to long
                                jeff432006 Level 1
                                yes firt time
                                • 13. Re: Video is taking to long
                                  jeff432006 Level 1
                                  fram rat 25 frames/second
                                  lenght 00:29:46
                                  frame width 1920
                                  frame height 1080
                                  data rate 30000kbps
                                  total bitrate 30192kbps
                                  • 14. Re: Video is taking to long
                                    Jeff,
                                    Though there are two slightly different Durations, or run-times listed: 00;29;46 (assume 00;29;46;00 in SMPT), and 00;30;03;24, I completely agree with ATR - even with an Extended YouTube account, this is not going to work, and especially directly from PrE.
                                    I would Cut your Timeline into segments, at the Duration that your YouTube Account allows, and then upload those, one at a time.
                                    • 15. Re: Video is taking to long
                                      A.T. Romano Level 7
                                      jeff432006
                                      I have heard that some can get more than 15 minute limited if you upload your 15+ file at the YouTube web site. But I never found out just how much you can extend the 15 minute limit.
                                      But, what about trying the Premiere Elements 11 Publish+Share/Online/Vimeo? There is no posted time limit that I know of for that. The preset would be PAL-Vimeo HD which will be for 1280 x 720. No adjusts.
                                      If you want to produce a file that you can try to upload at YouTube or Vimeo, please look at
                                      Publish+Share/Computer/AVCHD with preset of MP4 - H.264 1920 x 1080p25.
                                      Please let us know the outcome.
                                      Thanks.
                                      ATR
                                      • 16. Re: Video is taking to long
                                        A.T. Romano Level 7
                                        Are you back or just flying overhead nearing DC?
                                        Whatever the case, glad to have your attention.
                                        Are you sure about the extended limits over at the YouTube web site? I have yet to find an exact number, but I have not been looking long. I thought it would take in at least 30 minutes. I will look so more if you are not sure.
                                        Thanks.
                                        ATR
                                        • 17. Re: Video is taking to long
                                          ATR,
                                          Leaving for SFO tomorrow evening, then heading to DC on Monday. Still here for a bit, trying to follow a rain-delayed President's Cup golf competition, but keep losing my concentration, with those delays, and NBC HD's replays of earlier rounds. Tough on an old brain.
                                          • 18. Re: Video is taking to long
                                            ATR,
                                            As for the limits on ALL YouTube Accounts, I have not found anything longer than 15 mins., but there could well be other Accounts, with longer Durations, that I have just not located yet.
                                            • 19. Re: Video is taking to long
                                              Just found this URL: https://support.google.com/youtube/answer/71673?hl=en
                                              It talks about "longer than 15 mins.," but I do not see what the max. Duration would be, with that increase and verify info.
                                              When I get a minute, I will try to extend the Duration for my account, and verify via my cellphone. Then, I suppose that I'll know the max.
                                              • 20. Re: Video is taking to long
                                                A.T. Romano Level 7
                                                I getting the YouTube limit at YouTube information back in bits and pieces. Latest thinking is that, if you have a "Partners Account", there is no time limit but the file size cannot exceed 20 GB. Please let us know if you can confirm that.
                                                Thanks.
                                                ATR
                                                • 21. Re: Video is taking to long
                                                  Markpic Level 1
                                                  Some of my YouTube video's take 8-hours to upload.
                                                  I try and keep the upload to 1.5 GB's or less.
                                                  I'll use the Adobe PE 11 choice of YouTube Wide Screen HD
                                                  (for my large video files.
                                                  I'll use m2t 720p (60 fps) for my smallest video files.
                                                  • 22. Re: Video is taking to long
                                                    A.T. Romano Level 7
                                                    Markpic
                                                    So, what is your answer to the question at hand?
                                                    a. What is the YouTube limitations for space and duration for an upload there for videos with duration longer than 15 min 0.00 sec? And, what does one have to do to get and specify the amount of time wanted?
                                                    The time that it take you specifically to upload to YouTube (8 hours) and the file size (1.5 GB) does not address the issue under discussion. The user can upload 2.0 GB to YouTube via Premiere Elements ...Online/YouTube, provided the duration of the Timeline does not exceed 15 minutes.
                                                    ATR
