1 Reply Latest reply on Oct 7, 2013 10:40 AM by Josh_Corey
    how do i stop margins from shifting when adding a field?
    wfw1
      How do I stop margins from automatically changing when I insert a new field?
        • 1. Re: how do i stop margins from shifting when adding a field?
          Josh_Corey Adobe Employee
          Can you try to describe what you see in a little more detail, maybe a screen shot attached too?
          The only thing I can think that you might be seeing is fields with the label on the left or right (selectable for each field in its properties panel) which are also the first field in any row will share the same "label width", if you were to resize the label for any field of that type it will affect all other label left/right fields at the beginning of rows.  That behavior at this time is expected.
          Josh
