5 Replies Latest reply on Feb 20, 2015 9:39 AM by dcfreelancelot
    3D map with just contour lines.
    Tom_Farrell Level 1
      Hello,
      I'm a junior motion graphics designer at an advertising agency in the UK.
      The Brief:
      30 Seconds: Animation
      Simple contour lines from an ordnance survey map, and some text.
      But I do have a very good grasp on After Effects CC.
      For an upcoming pitch I need to recreate a visual. Which is:
      Basically I need a constant rolling hill effects with just the contour lines, then I will be animating text to specific points as if they were camera tracked.
      I have After Effects CC so i was wondering whether it would be easier to re-create in Cinema 4D lite, but admittedly I'm very much an amateur there.
      From my initial thoughts:
        • Make this Illustrator file animate forwards in 3D space then put an echo on it. (would this look okay?)
        • Then the thought came about creating the environment in Cinema 4D. (Can it be done in the Lite version?)
        • Or grab stock to save the hassle (Ideally I'd prefer to re-create it)
      Any help would be greatly appreciated,
      Tom
