6 Replies Latest reply on Oct 8, 2013 3:43 AM by PEPPERFACE
    Play Random Symbols When Button Is Clicked
    PEPPERFACE Level 1
      First off, I do apologise for not being able to make use of the answers that have already been proffered in response to similar questions to this, but none of the posts that I've pored over seem to cover what I'm after (unless, it's a matter of my failing to understand the concept... which may well be the case! Haha!)
      Anyway, I have a dozen or so animated symbols on the stage and I'd like a randomly called one to play each time users click a button.
      Any advice, or directions to any tutes out there, will be very gratefully received.
      Cheers in advance
      Frannie x
        • 1. Re: Play Random Symbols When Button Is Clicked
          resdesign Adobe Community Professional & MVP
          hey Frannie,
          Try something like this:
          var mySymbols = ['Symbol_1','Symbol_2','Symbol_3','Symbol_4'];
          i=0;
          sym.$('btn').click(function(){
          i++;
          var myVar = Math.floor((Math.random()*4));
          sym.getSymbol(mySymbols[myVar]).play();
          • 2. Re: Play Random Symbols When Button Is Clicked
            jbowden Adobe Employee
            Here's something a little more concise that may help or otherwise be of interest:
            var childSymbols = sym.getChildSymbols();
            var r = Math.floor((Math.random()*4));
            childSymbols[r].play();
            Add that code to your click handler. Only minor tweaks are needed if the button and symbol instances are not at the same symbol level.
            hth,
            Joe
            • 3. Re: Play Random Symbols When Button Is Clicked
              Nice Joe!
              A clarification for the API:
              I think that you need to add the curly brackets  in the example because of course without them, the example would not work.
              API example under getChildSymbols (missing brackets added below).
              for(var i=0; i<childSymbols.length; i++) { // Return the number of direct children
              childSymbols[i].stop();           // Stop all of the children
              • 4. Re: Play Random Symbols When Button Is Clicked
                Hi Marie,
                Actually, using opening/closing curly braces for a loop are not required, at least not for the example given:
                for(var i=0; i<childSymbols.length; i++) // Return the number of direct children
                As a matter of coding style, I'd probably add them myself for clarity - but the above code will work without the curly braces for those who prefer not to use them.
                • 5. Re: Play Random Symbols When Button Is Clicked
                  i have always used curly brackets. I even did not know you could skip them. Thanks for the information!
                  • 6. Re: Play Random Symbols When Button Is Clicked
                    PEPPERFACE Level 1
                    Huge thanks, both of you... top advice and wholly implementable!
                    Cheers!
                    Frannie x
