0 Replies Latest reply on Oct 7, 2013 6:16 PM by SA69303
    Error Using DialogModes.NO With ExecuteAction
    SA69303 Level 1
      Hello all,
      I am trying to export an image sequence as an MP4 using File->Export->RenderVideo...
      I was able to get the code using the script listener plugin.
      Here is my javascript code:
      Inputs
      FilePath       = "C:\\tmp"
      FileName     = "test.mp4"
      Function
      if (!Preview.prototype.RenderMp4)
        Preview.prototype.RenderMp4 = function (filePath, fileName)
                try {
                          var idExpr = charIDToTypeID( "Expr" );
                          var desc3 = new ActionDescriptor();
                          var idUsng = charIDToTypeID( "Usng" );
                          var desc4 = new ActionDescriptor();
                          var iddirectory = stringIDToTypeID( "directory" );
                          desc4.putPath( iddirectory, new File( fileName ) );
                          var idNm = charIDToTypeID( "Nm  " );
                          desc4.putString( idNm, filePath );
                          var idameFormatName = stringIDToTypeID( "ameFormatName" );
                          desc4.putString( idameFormatName, """H.264""" );
                          var idamePresetName = stringIDToTypeID( "amePresetName" );
                          desc4.putString( idamePresetName, """1_High Quality.epr""" );
                          var iduseDocumentSize = stringIDToTypeID( "useDocumentSize" );
                          desc4.putBoolean( iduseDocumentSize, true );
                          var iduseDocumentFrameRate = stringIDToTypeID( "useDocumentFrameRate" );
                          desc4.putBoolean( iduseDocumentFrameRate, true );
                          var idpixelAspectRatio = stringIDToTypeID( "pixelAspectRatio" );
                          var idDcmn = charIDToTypeID( "Dcmn" );
                          desc4.putEnumerated( idpixelAspectRatio, idpixelAspectRatio, idDcmn );
                          var idfieldOrder = stringIDToTypeID( "fieldOrder" );
                          var idvideoField = stringIDToTypeID( "videoField" );
                          var idpreset = stringIDToTypeID( "preset" );
                          desc4.putEnumerated( idfieldOrder, idvideoField, idpreset );
                          var idmanage = stringIDToTypeID( "manage" );
                          desc4.putBoolean( idmanage, true );
                          var idallFrames = stringIDToTypeID( "allFrames" );
                          desc4.putBoolean( idallFrames, true );
                          var idrenderAlpha = stringIDToTypeID( "renderAlpha" );
                          var idalphaRendering = stringIDToTypeID( "alphaRendering" );
                          var idNone = charIDToTypeID( "None" );
                          desc4.putEnumerated( idrenderAlpha, idalphaRendering, idNone );
                          var idQlty = charIDToTypeID( "Qlty" );
                          desc4.putInteger( idQlty, 1 );
                          var idvideoExport = stringIDToTypeID( "videoExport" );
                          desc3.putObject( idUsng, idvideoExport, desc4 );
                          executeAction( idExpr, desc3, DialogModes.NO);
                          } catch (e) {alert (e)}
      Error
      Error: General Photoshop error occurred. This functionality may not be available in this version of Photoshop.
      - Could not complete the command because of a problem with Adobe Media Encoder.
      Notes
      The above function will work if we replace:
      with
      executeAction( idExpr, desc3, DialogModes.ALL);
      However, I want to suppress all input.to the user for full automation.
      I am using PhotoShop CS6 (64 bit)
      Any help would be greatly appreciated.
      A.
