1 Reply Latest reply on Oct 18, 2013 4:42 PM by elainecc
    Having issue where animation does not play on Godaddy server.
    Kevin_808 Level 1
      Hi Guys,
      Thanks in advance for any help.  Like the tile says I'm having an issue where part of my animation doesn't work, but only on GoDaddy servers, and I'm at a loss as to why.  It works locally and it worked on my media temple server (Which I have since canceled), it also works on BIZCatalyst.  I was using a blur filter and I thought that might have had something to do with it (Like maybe the browsers can't render it cause the tech is too new), but I reanimated the parts that didn't work and used a simple transparency filter animation without success.
      Here is a link to the web page for the project hosted on GoDaddy: http://www.thesanninegroup.com/index.html
      Here is a link to the files so you can see how they are supposed to work:  http://d.pr/f/xawI
      Essentially the third slide is supposed to animate in icons inside each of the circles in the leaves and then lables are supposed to pop up.  Neither work on GoDaddy's servers but work fine everywhere else.
      Any ideas?
