9 Replies Latest reply on Oct 14, 2013 4:29 AM by Doc Maik
    InDesign Interactive Buttons Fade In/Out Only Work Once In SWF
    ShawnNotSean
      I have an animation sequence that has an in out out button with fade effect to cycle through some image overlays on a chart. I used a forum trick of ceating a blank rectangle, grouping the box and image, setting the fade out to the group, and then I assign that to the out button. This all works fine except once you click through the sequence of buttons/content the Fade In buttons no longer work yet you can invoke the fade out as many times as you want. Setting the In animation to loop or play more than once doesnt work. I was thinking it was a layer order or grouping issue or perhaps I need some sort of Reset button? Any ideas for a fix or work-around?
