0 Replies Latest reply on Oct 8, 2013 1:47 PM by slotexpert
    mango blog on win2k8 cf8
    slotexpert
      Error: : Could not find the included template /7cswinery/cblog/skins/cutline/index.cfm.
      Note: If you wish to use an absolute template path (for example, template="/mypath/index.cfm") with CFINCLUDE, you must create a mapping for the path using the ColdFusion Administrator. Or, you can use per-application settings to specify mappings specific to this application by specifying a mappings struct to THIS.mappings in Application.cfc.
      Using relative paths (for example, template="index.cfm" or template="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
      getting this error after install at www.7cswinery.com/cblog/
      files are there path is WRONG how do I cange it
      MANGO BLOG IS NOT SUPPORTED BY MFG
      YOU ARE USING IT
      HELP
      win2k8 server, iis7.5, CF8, mangoblog1.7
      other cf apps working FINE
