1 Reply Latest reply on Oct 9, 2013 3:20 AM by Peter Spier
    Tomprint
      I have lost all print presets in InDesign CS6 - how to find them and replace them?
        • 1. Re: =
          Print presets are saved in the program as part of the InDesign Defaults file that is destroyed when you reset prefs. Is that what happened to you? Unless you took the time to select them in the File > Print Presets > Define...
          dialog and save them to an external file  (press the Save button) so you can reload them in the same place, you are most likely out of luck unless you can restore and earlier version of InDesign Defaults from a backup. See Replace Your Preferences for file locations.
