1 Reply Latest reply on Jun 14, 2006 2:56 PM by .:}x-=V!P=-x{:.
    mx.transitions.Tween: scaling and movement issue
      I've been trying to create a map which zooms and moves at the same time. So basically altering the scale and coords of a mc.
      However the problem is that when I alter the scale values the coordinate values then relate to a different point on the mc. I.E. using the Tween class to change the _x and _y properties doesn't factor in changing _xscale and _yscale values.
      I was wondering if anyone had any suggestions for this problem or has solved it in the past.
      I've attached code to show how i'm calling the tweens.
      Many Thanks!
