1. Re: Lasso Tool Auto Completes
Trevor.Dennis Oct 9, 2013 6:45 PM (in response to Jon_dawell)Hi Jonathon. You are certainly not the first person to have this problem. Some workarounds here
2. Re: Lasso Tool Auto Completes
Chuck Uebele Oct 9, 2013 7:04 PM (in response to Jon_dawell)Believe it or not, but the lasso tool has been improved in CC. In CS6 and earlier, it was horrible about closing by accident or not closing. To close a selection, you can either hit "Enter" or ctrl/cmd click. The sensitivity has also been adjusted so that it will not close if the mouse moves and two click happen close together - a big problem before. Now the mouse has to be in the same position and double clicked to close the selection. So if you're getting this accidental closing with CC, most likely you're double clicking and not moving the mouse, or the sensitivity of you pen is such that it sends a double click.
3. Re: Lasso Tool Auto Completes
Jon_dawell Oct 9, 2013 7:04 PM (in response to Trevor.Dennis)Thanks Trevor,
unfortunately nothing in that thread actually helps. Ive read through other posts of the same problem but they seem to get lost in bizarre or tedious work arounds - rather than an actual solution. Im happy continuing on by adding to my selection or starting over as a ' if I have to work-around '. Yet I hope someone, somewhere, someday soon finds a final solution.
Thanks again.
4. Re: Lasso Tool Auto Completes
Jon_dawell Oct 9, 2013 7:11 PM (in response to Chuck Uebele)Thanks csuebele,
I have noticed the much improved double click sensitivity, but what I am experiencing is definitely not related to that I could click 1000 pixels a part with 5sec in between clicks and this error will occur.
I can safely say what is happening is not a user error with a known function of the lasso tool.
5. Re: Lasso Tool Auto Completes
Chuck Uebele Oct 9, 2013 7:17 PM (in response to Jon_dawell)What is your input device? I sometimes use a laptop that the touch pad is so sensitive that it will click on links with my finder just near the pad, same for my Wacom at times.
6. Re: Lasso Tool Auto Completes
Jon_dawell Oct 9, 2013 7:22 PM (in response to Chuck Uebele)I use an Apple Magic Mouse.
7. Re: Lasso Tool Auto Completes
Chuck Uebele Oct 9, 2013 7:36 PM (in response to Jon_dawell)I'm not familiar with the magic mouse, but I did a quick search on it. It looks like it could have the issues I mentioned above about being over sensitive. Have you had this issue with a regualar mouse - if you still have one?
8. Re: Lasso Tool Auto Completes
Jon_dawell Oct 9, 2013 7:47 PM (in response to Chuck Uebele)It is a possibility that it is something to do with my mouse but its not a sensitivity issue. I probably should have mentioned this - when I make the click that is about to close the path the lasso line ends at the last anchor leaving my mouse to roam away from the path and the path is still visible from the last anchor point without making a selection (yet) and it isnt until my next click the selection is made. I have just found if I hold space bar use the drag screen tool(hand tool) when I let go my path reconnects to the cursor and I can continue on as normal. So this would be another work around but not a fix. Any idea what is causing this with this information?
I am unsure if a regular mouse does this or not I will grab one tomorrow and try it, but I dont expect it to change things somehow.
Thanks for your help.
9. Re: Lasso Tool Auto Completes
Chuck Uebele Oct 9, 2013 7:52 PM (in response to Jon_dawell)I'm not sure what would be causing this, but with these new input devices they can cause issues. I'm on a Windows system, and it has caused all sorts of issues with my Wacom when they added touch screen features and their own tablet controler. This might be an issue that Adobe has to address, but it might be a case of each side saying the other's at fault.
10. Re: Lasso Tool Auto Completes
Jon_dawell Oct 9, 2013 7:55 PM (in response to Chuck Uebele)Yes that seems to be the case.
I can replicate this fault by right clicking my mouse - but I know Im not doing that while im making a selection.
