3 Replies Latest reply on Oct 21, 2013 2:52 AM by AMULI
    slideshow buttons dont work properly
    pointseven
      okay i know this is very simple, however i have spent nearly 3 hours trying to find the answer and i can't find it. I am working in edge animate.
      I have a slideshow of 20 hard coded images and I just want two buttons to navigate between them to make it simpler. I have one picture every 250ms and each is labeled with "f1", "f2", etc. I am using a sym.stop(); trigger on the timeline at each label and the forward button has a simple sym.play(); and the reverse button a simple sym.playReverse();. This sort of works however it doesn't stop at the first and last frame properly. It also skips a picture each time i change direction (ex: changing from playing forwards to playing backwards) I tried a lot of alternative codes like playing the playhead for only 250ms which I couldn't get working either
      i guess an array of labels in a list could work, and moving up and down the chain with the back/fwd buttons would work but i dont know how do that either. I would actually prefer this.
      Any help would be greatly appreciated.
      some screenshots because its in Edge Animate and this is hopefully more comprehensible.
      http://i44.tinypic.com/2qlv4o4.jpg
      http://i43.tinypic.com/anih02.jpg
      http://i43.tinypic.com/c21qw.jpg
      http://i44.tinypic.com/15ot352.jpg
        • 1. Re: slideshow buttons dont work properly
          elainecc Adobe Employee
          Hi there, pointseven-
          Can you post your entire project for us to take a look at?  I can't tell right now why the first and last ones are skipping from your screenshots.
          -Elaine
          • 2. Re: slideshow buttons dont work properly
            AMULI Level 4
            Hi pointseven,
            As your images are every 250 ms, you don't need any labels.
            sym.stop() triggers at each label are useless as well : instead of using sym.play() and sym.playReverse() (there is nothing to play ), just use sym.stop(<ms>). You get the current position in the timeline via sym.getPosition().
            Suppose four images at 0, 250, 500 and 750 ms and two buttons named prev and next.
            Stage > compositionReady event handler :
            sym.stop();
            sym.$('prev').hide();
            next > click event handler :
            sym.stop( sym.getPosition() +250);
            sym.$('prev').show(); // just after moving one slide forward, it makes sense moving backward
            if (sym.getPosition() == 750) // last image
              sym.$('next').hide();
            prev > click event handler :
            sym.stop( sym.getPosition() -250);
            sym.$('next').show();
            if (sym.getPosition() == 0)
            Instead of hiding/showing the buttons, you could set their opacity. A hidden button is not clickable, but a button with reduced opacity is, hence a test at the begining of the click event handlers.
            sym.stop();
            sym.$('prev').css('opacity','0.5');
              return; // click not processed
            sym.$('prev').css('opacity','1');
              sym.$('next').css('opacity','0.5');
              return;
            sym.$('next').css('opacity','1');
            The two examples are downloadable here : https://app.box.com/s/cptzincsd1ed3ssi3gr1
            Gil
            • 3. Re: slideshow buttons dont work properly
              AMULI Level 4
              PS : I started setting the autoplay property of the Stage symbol to false, but then sym.getPosition() returns -1.
              So I turned to a sym.stop(); trigger at 0 ms, which has the same effect as autoplay = false, except now sym.getPosition() returns 0 as expected.
              Gil
