5 Replies Latest reply on Oct 24, 2013 4:07 AM by Littleone7
    JSON static Text field
    oliverS Level 1
      Hello everybody,
      I want to load data from a JSON file in  two different Textfields
      but it does not work.
      I make two simple Textfields which I named
      "firstTXTfield" and "secondTXTfield" and put them on the stage.
      Now I want to load Data from a JSON file:
                "first" : "Hello world 01",
                "second" : "Hello world 02",
      On the compositionReady I put the following code:
      $.getJSON('content.json', function(data){
                function updateInfo(i){
                                               sym.$("firstTXTfield").html(data[i].first);
                  sym.$("secondTXTfield").html(data[i].second);
      Maybe someone could help
      THX
        • 1. Re: JSON static Text field
          resdesign Adobe Community Professional & MVP
          You need to give a value to i in order for them to show. Basically the variable needs to be initiated one way or another.
          i=0;
          • 2. Re: JSON static Text field
            Littleone7
            I have a similar query I think. i need to crab a quote from my JSON database and pass that into a symbol in edge. I've looked at a couple of posts but I'm still stuggling. My code is below:
            $.getJSON('http://glogis04/fm/fmService.php?getQuote&type=Operational%20Support', function(data){
                        i=0;
                        sym.getSymbol('righ_txt').$('Quote_txt').html(data[i].type.text);
            I also want it take a random quote for the records each time its asked.
            This is my first time with working with databases of any kind so real newbie here.
            thanks again!
            • 3. Re: JSON static Text field
              Littleone7 Level 1
              update
              my developer firend who created the JSON database but doesn't know edge per say edited the javascript I cave him and added a for loop too:
              var quotesArray = new Array();
              var currentQuote = 0;
              sym.getSymbol('righ_txt').$('Quote_txt').html("");
              $.getJSON("http://glogis04/fm/fmService.php?getQuotes&type=Technical%20Services", function(data){
                             for(var i=0; i<data.length; i++){
                                           quotesArray.push({"type":data[i].type,"text":data[i].text});
                             sym.getSymbol('righ_txt').$('Quote_txt').html(quotesArray[currentQuote].type);
              but it still doesnt work... help
              • 4. Re: JSON static Text field
                I believe you need to change this to:
                          // sym.getSymbol('righ_txt').$('Quote_txt').html("");  // probably not needed.
                               sym.getSymbol('righ_txt').$('Quote_txt').html(quotesArray[currentQuot e].type);
                • 5. Re: JSON static Text field
                  Littleone7 Level 1
                  Thanks resdesign.
                  We realised it was because the two files weren't on the same server so it didn't like it. Now they are its working fine with:
                  var quotesTArray = new Array();
                  var quotesOArray = new Array();
                  var quotesSArray = new Array();
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getQuotes&type=Technical%20Services", function(data){
                                               quotesTArray.push({"type":data[i].type,"text":data[i].text});
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getQuotes&type=Operational%20Support", function(data){
                                               quotesOArray.push({"type":data[i].type,"text":data[i].text});
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getQuotes&type=Strategic%20and%20Financial%20Planning", function(data){
                                               quotesSArray.push({"type":data[i].type,"text":data[i].text});
                  // Data from JSON Database for Projects
                  var projectsTArray = new Array();
                  var projectsOArray = new Array();
                  var projectsSArray = new Array();
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getProjects&type=Technical%20Services", function(data){
                                               projectsTArray.push({"type":data[i].type,"text":data[i].text});
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getProjects&type=Operational%20Support", function(data){
                                               projectsOArray.push({"type":data[i].type,"text":data[i].text});
                  $.getJSON("http://ldnpc9f1r65j/fm/fmService.php?getProjects&type=Strategic%20and%20Financial%20Planni ng", function(data){
                                               projectsSArray.push({"type":data[i].type,"text":data[i].text});
                  Then inside the click functions I ask the contents of the array I need to which saves on loading ie:
                  sym.getSymbol('righ_txt').$('Quote_txt').html(quotesTArray[0].text);
                  sym.getSymbol('righ_txt').$('PE_list_txt').html(projectsTArray[0].text);
                  The thing i'm now stuggling with is how to put several records from the same Array into one text box on separate lines.
                  ie.
                  record 0
                  record 1
                  record 2
                  record 3
                  The only way I can think to do it is to have 4 text boxes and give each of them a record to look at.
                  thanks
