1 Reply Latest reply on Oct 10, 2013 8:48 AM by Drewy62
    Prepopulate PDF with data from database
    MuralidharKoti Level 1
      I have a requirement to prepopulate the PDF with data from database (ex: Invoice Number, Amunt and 'Yes/No'). This then needs to be sent to users to mark the invoices that they have paid (by marking those invoices as Yes).
      My question is, is it possible to pre-pupulate the PDF with invoice data that I have before sending to my supplier? also can I dynamically generate one PDF for supplier. Again the list of supplier comes from my database.
      Please advise if 'FormsCentral' is the right product to satisfy the above said requirement.
      Thanks in advance for your help.
      Regards,
      Murali
        • 1. Re: Prepopulate PDF with data from database
          Drewy62 Adobe Employee
          Murali,
          Thanks for your question. Unfortunately Formscentral is not the product you want for the workflow you describe. At this time there are several steps you require that we don't support. I suggest that you look into a PDF workflow using Acrobat or Livecycle. Both of these products have user forums that you can ask your questions on.
          Andrew
