8 Replies Latest reply on Oct 16, 2013 12:20 AM by pwillener
    Flash Player plug in does not install
    FKMITCHELL
      The material sent by C F McBlob was kindly sent but does not work.  I downloaded the correct zip file, installed Flash player on this machine, and still get messages from web sites that Flash Player is needed.  This computer has win 7 32 bit Enterprise edition; the computer I have that works with flash player is WIn7 32 bit professional edition.  Is there a difference?  The control panel information is that the plugin is not installed.  Do I need to turn off the McAfee firewall in order to install this?
        • 1. Re: Flash Player plug in does not install
          pwillener Level 8
          Can you post the contents of the FlashInstall.log file in C:\Windows\system32\Macromed\Flash ?
          • 2. Re: Flash Player plug in does not install
            FKMITCHELL Level 1
            How to copy the file and paste it in to this forum?  Copy - paste does not work, as the paste command does not appear in this box when I right-click on it (paste is grayed out)
            • 3. Re: Flash Player plug in does not install
              FKMITCHELL Level 1
              Sorry it took so long.  Busy weekend.  Control-V works even though the "Paste" option on the menu is grayed out.
              Call: 397
              Safety Check
              Call: 79
              Call: 886
              File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll"
              File: wrote 4096 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll"
              CheckAdminPermissions Name = SYSTEM
              Call: 886
              File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll" (overwriteflag=1)
              CheckAdminPermissions Account Type = Admin
              Jump: 111
              Call: 111
              Call: 37
              GetWindowsVersion -
              CheckSupportedPlatform  - OS=
              Call: 403
              CheckFPPermissions
              Call: 37
              GetWindowsVersion -
              Call: 886
              File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll"
              File: wrote 8704 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll"
              ObjectExistsAndIsOwnedBySomeoneElse = 0
              Jump: 431
              End Safety Check
              File: overwriteflag=4, allowskipfilesflag=2, name="Flash9f.ocx"
              File: wrote 2991488 to "C:\Windows\system32\Macromed\Flash\Flash9f.ocx"
              File: overwriteflag=4, allowskipfilesflag=2, name="FlashUtil9f.exe"
              File: wrote 218496 to "C:\Windows\system32\Macromed\Flash\FlashUtil9f.exe"
              End Main Section
              Section: ""
              Start Post Section
              Call: 448
              CallUninstallers
              Call: 886
              File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
              File: wrote 17920 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
              Call: 886
              File: overwriteflag=1, allowskipfilesflag=0, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
              File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll" (overwriteflag=1)
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Call: 886
              Jump: 759
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Call: 886
              Jump: 758
              Delete: "C:\Windows\system32\Macromed\Flash\Flash.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash6.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash6a.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash7.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash7a.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash7b.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash7c.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8a.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8b.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8c.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8d.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash8e.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9a.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9b.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9c.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9d.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\Flash9e.ocx"
              Delete: "C:\Windows\system32\Macromed\Flash\GetFlash.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\GetFlash.exe.manifest"
              Delete: "C:\Windows\system32\Macromed\Flash\UninstFl.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9a.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9b.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9c.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9d.exe"
              Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9e.exe"
              End Call Uninstallers
              Register Player
              Registration Successful
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerActiveX\Components" "Main"="1"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerActiveX" "Path"="C:\Windows\system32\Macromed\Flash"
              created uninstaller: 9625, "C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ShockwaveFlash" "DisplayVersion"="9.0.124.0"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayName"="Adobe Flash Player ActiveX"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayVersion"="9.0.124.0"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "Publisher"="Adobe Systems Incorporated"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "URLInfoAbout"="http://www.adobe.com/go/getflashplayer"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "VersionMajor"="9"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "VersionMinor"="0"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "HelpLink"="http://www.adobe.com/go/flashplayer_support/"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "URLUpdateInfo"="http://www.adobe.com/go/flashplayer/"
              Call: 886
              File: overwriteflag=1, allowskipfilesflag=0, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll"
              File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll" (overwriteflag=1)
              Call: 886
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayIcon"="C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "UninstallString"="C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "RequiresIESysFile"="4.70.0.1155"
              WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "NoModify"="0x00000001"
              WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "NoRepair"="0x00000001"
              WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Compatibility Flags"="0x00000000"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Accepted Documents" "Flash"="application/x-shockwave-flash"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" ""="Adobe Flash Player"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "ComponentID"="Flash"
              WriteRegBin: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "IsInstalled"="01 00 00 00"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Version"="9.0.124.0"
              WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Locale"="EN"
              WriteRegStr: "HKEY_CURRENT_USER\SOFTWARE\Macromedia\FlashPlayer" "FlashPlayerVersion"="9.0.124.0"
              End Post Section
              Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll")
              Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll")
              Delete: DeleteFile on Reboot("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll")
              Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll")
              Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll")
              RMDir: RemoveDirectory("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\")
              • 4. Re: Flash Player plug in does not install
                FKMITCHELL Level 1
                I think I posted the wrong file.  The one I just found - which I believe you asked for - is full of the same error message in hundreds of lines, to wit:  (The bottom of the file contains a different error code in about a dozen lines).  I am sorry - a novice error.
                =O====== M/11.6.602.180 2013-03-28+03-12-16.740 ========
                0000 [I] 00000010 "C:\ProgramData\Adobe\AIH.6b01902f938b298960e5a599fe4acdfbec0178d3\install_flash_player_a x.exe" -install -iv 8 -au 1
                0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0004 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0005 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash9f.ocx 5
                0006 [I] 00000018
                0007 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash9f.ocx 5
                0008 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
                0009 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
                0010 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
                0011 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                0012 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0013 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0014 [I] 00000012
                =X====== M/11.6.602.180 2013-03-28+03-12-18.725 ========
                =O====== M/11.6.602.180 2013-04-02+23-05-22.888 ========
                0000 [I] 00000010 "C:\ProgramData\Adobe\AIH.1a2459d74f054078fbdaa435cdf3c62bcddab460\install_flash_player_a x.exe" -install -iv 8 -au 0
                0001 [F] 00001041
                =X====== M/11.6.602.180 2013-04-02+23-05-23.037 ========
                =O====== M/11.6.602.180 2013-04-02+23-13-05.441 ========
                0001 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0002 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
                0003 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
                0004 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
                0005 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                0006 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0007 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                0008 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                0009 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0010 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0011 [I] 00000012
                =X====== M/11.6.602.180 2013-04-02+23-13-08.939 ========
                =O====== M/11.6.602.180 2013-04-25+16-38-35.790 ========
                0000 [I] 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe" -update activex
                0001 [E] 00001039
                =X====== M/11.6.602.180 2013-04-25+16-38-45.092 ========
                2013-4-28+0-14-0.714 [error] 1223 1058
                2013-4-28+1-14-0.457 [error] 1223 1058
                2013-4-28+8-4-54.170 [error] 1223 1058
                2013-4-28+17-44-50.640 [error] 1223 1058
                2013-4-28+18-14-0.173 [error] 1223 1058
                2013-4-28+19-14-0.349 [error] 1223 1058
                2013-4-28+20-14-0.287 [error] 1223 1058
                2013-4-28+21-14-0.209 [error] 1223 1058
                2013-4-29+1-3-57.203 [error] 1223 1058
                2013-4-29+1-3-57.328 [error] 1223 1058
                2013-4-29+1-14-0.245 [error] 1223 1058
                2013-4-29+8-2-34.779 [error] 1223 1058
                2013-4-29+8-14-0.151 [error] 1223 1058
                2013-4-29+9-14-0.138 [error] 1223 1058
                2013-4-29+17-48-7.686 [error] 1223 1058
                2013-4-29+18-14-0.198 [error] 1223 1058
                2013-4-29+20-20-31.326 [error] 1223 1058
                2013-4-29+21-22-1.970 [error] 1223 1058
                2013-4-29+22-14-0.196 [error] 1223 1058
                2013-4-30+8-18-18.967 [error] 1223 1058
                2013-4-30+16-42-7.437 [error] 1223 1058
                2013-4-30+17-14-0.15 [error] 1223 1058
                2013-4-30+18-14-0.194 [error] 1223 1058
                2013-4-30+19-14-0.347 [error] 1223 1058
                2013-4-30+20-14-0.219 [error] 1223 1058
                2013-4-30+21-14-0.213 [error] 1223 1058
                2013-4-30+22-14-0.36 [error] 1223 1058
                2013-4-30+23-14-0.198 [error] 1223 1058
                2013-5-1+0-14-0.201 [error] 1223 1058
                2013-5-1+1-14-0.309 [error] 1223 1058
                2013-5-1+8-24-55.390 [error] 1223 1058
                2013-5-1+9-14-0.267 [error] 1223 1058
                2013-5-1+10-14-0.972 [error] 1223 1058
                2013-5-1+11-14-0.166 [error] 1223 1058
                2013-5-1+12-19-3.939 [error] 1223 1058
                2013-5-1+18-21-58.30 [error] 1223 1058
                2013-5-1+19-14-0.200 [error] 1223 1058
                2013-5-1+20-14-0.249 [error] 1223 1058
                2013-5-2+8-48-56.281 [error] 1223 1058
                2013-5-2+16-0-9.125 [error] 1223 1058
                2013-5-2+16-14-0.38 [error] 1223 1058
                2013-5-2+17-14-0.199 [error] 1223 1058
                2013-5-2+18-14-0.293 [error] 1223 1058
                2013-5-2+20-35-19.578 [error] 1223 1058
                2013-5-2+22-30-30.797 [error] 1223 1058
                2013-5-2+23-14-0.155 [error] 1223 1058
                2013-5-3+0-14-0.191 [error] 1223 1058
                2013-5-3+0-14-0.224 [error] 1223 1058
                2013-5-3+1-14-0.294 [error] 1223 1058
                2013-5-3+8-44-3.403 [error] 1223 1058
                2013-5-3+15-15-39.628 [error] 1223 1058
                2013-5-3+16-14-0.192 [error] 1223 1058
                2013-5-3+17-14-0.193 [error] 1223 1058
                2013-5-3+20-3-54.107 [error] 1223 1058
                2013-5-3+20-14-0.234 [error] 1223 1058
                2013-5-3+21-14-0.195 [error] 1223 1058
                2013-5-4+0-52-54.617 [error] 1223 1058
                2013-5-4+1-14-0.189 [error] 1223 1058
                2013-5-4+8-27-26.527 [error] 1223 1058
                2013-5-5+14-43-56.232 [error] 1223 1058
                2013-5-5+15-14-0.462 [error] 1223 1058
                2013-5-5+17-53-0.404 [error] 1223 1058
                2013-5-5+18-14-0.194 [error] 1223 1058
                2013-5-5+20-43-20.734 [error] 1223 1058
                2013-5-6+2-10-3.984 [error] 1223 1058
                2013-5-6+2-14-1.919 [error] 1223 1058
                2013-5-6+3-15-41.706 [error] 1223 1058
                2013-5-6+4-14-1.325 [error] 1223 1058
                2013-5-6+5-14-0.334 [error] 1223 1058
                2013-5-6+6-14-0.337 [error] 1223 1058
                2013-5-6+8-21-47.160 [error] 1223 1058
                2013-5-6+16-18-0.775 [error] 1223 1058
                2013-5-6+17-14-0.360 [error] 1223 1058
                2013-5-6+20-23-0.811 [error] 1223 1058
                2013-5-6+21-50-21.827 [error] 1223 1058
                2013-5-6+22-14-0.143 [error] 1223 1058
                2013-5-6+23-14-0.155 [error] 1223 1058
                2013-5-7+0-14-0.150 [error] 1223 1058
                2013-5-7+8-51-47.826 [error] 1223 1058
                2013-5-7+18-14-0.188 [error] 1223 1058
                2013-5-7+19-36-3.796 [error] 1223 1058
                2013-5-7+20-14-0.223 [error] 1223 1058
                2013-5-7+21-14-0.155 [error] 1223 1058
                2013-5-7+22-33-44.687 [error] 1223 1058
                2013-5-7+23-14-0.151 [error] 1223 1058
                2013-5-8+0-14-0.147 [error] 1223 1058
                2013-5-8+1-14-0.144 [error] 1223 1058
                2013-5-8+3-42-25.748 [error] 1223 1058
                =O====== M/11.6.602.180 2013-05-08+03-42-42.639 ========
                0001 [E] 00001039
                =X====== M/11.6.602.180 2013-05-08+03-42-46.376 ========
                2013-5-8+4-14-0.146 [error] 1223 1058
                2013-5-8+17-14-0.248 [error] 1223 1058
                2013-5-8+18-14-0.189 [error] 1223 1058
                2013-5-8+19-14-0.288 [error] 1223 1058
                2013-5-8+20-14-0.151 [error] 1223 1058
                2013-5-8+21-14-38.764 [error] 1223 1058
                2013-5-8+22-18-5.519 [error] 1223 1058
                2013-5-8+23-14-0.392 [error] 1223 1058
                2013-5-9+1-19-34.873 [error] 1223 1058
                2013-5-9+4-38-27.117 [error] 1223 1058
                2013-5-9+5-14-0.188 [error] 1223 1058
                2013-5-9+8-58-39.530 [error] 1223 1058
                2013-5-9+9-34-0.531 [error] 1223 1058
                2013-5-9+15-44-7.983 [error] 1223 1058
                2013-5-9+16-14-0.264 [error] 1223 1058
                2013-5-9+17-14-0.198 [error] 1223 1058
                =O====== M/11.6.602.180 2013-05-24+17-48-22.788 ========
                =X====== M/11.6.602.180 2013-05-24+17-52-15.368 ========
                =O====== M/11.7.700.202 2013-05-24+17-55-16.653 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe" -refreshIEElevationPolicies
                =X====== M/11.7.700.202 2013-05-24+17-55-16.703 ========
                =X====== M/11.7.700.202 2013-05-24+17-55-16.704 ========
                =O====== M/11.7.700.202 2013-05-24+17-55-15.624 ========
                0000 [I] 00000010 "C:\ProgramData\Adobe\AIH.6810efccffb736f7296828e7ec7199847d106aa9\install_flash_player_a x.exe" -install -iv 10
                0002 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx 5
                0003 [I] 00000018
                0004 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx 5
                0005 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_202.ocx
                0006 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
                0007 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
                0008 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                0009 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0010 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                0011 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                0012 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0013 [W] 00001106
                0014 [W] 00001106
                0015 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0016 [I] 00000012
                =X====== M/11.7.700.202 2013-05-24+17-55-19.860 ========
                2013-5-24+18-14-59.490 [error] 1223 1058
                2013-5-24+19-14-0.247 [error] 1223 1058
                2013-5-24+20-16-19.47 [error] 1223 1058
                2013-5-25+0-48-18.69 [error] 1223 1058
                2013-5-25+1-14-0.809 [error] 1223 1058
                2013-5-25+2-14-11.457 [error] 1223 1058
                2013-5-25+5-35-2.525 [error] 1223 1058
                2013-5-25+6-18-4.876 [error] 1223 1058
                2013-5-25+8-54-23.991 [error] 1223 1058
                2013-5-25+9-22-23.870 [error] 1223 1058
                2013-5-25+10-14-5.253 [error] 1223 1058
                2013-5-25+11-14-0.535 [error] 1223 1058
                2013-5-25+12-14-0.194 [error] 1223 1058
                2013-5-25+13-19-44.468 [error] 1223 1058
                2013-5-25+14-14-0.162 [error] 1223 1058
                2013-5-25+15-20-17.145 [error] 1223 1058
                2013-5-25+16-40-41.953 [error] 1223 1058
                2013-5-25+17-14-0.43 [error] 1223 1058
                2013-5-25+18-14-0.179 [error] 1223 1058
                2013-5-25+19-14-0.257 [error] 1223 1058
                2013-5-25+20-14-0.174 [error] 1223 1058
                2013-5-25+21-14-0.200 [error] 1223 1058
                2013-5-25+22-14-0.205 [error] 1223 1058
                2013-5-25+23-14-0.200 [error] 1223 1058
                2013-5-26+0-14-0.232 [error] 1223 1058
                2013-5-26+1-14-0.187 [error] 1223 1058
                2013-5-26+8-26-43.296 [error] 1223 1058
                2013-5-26+16-57-20.716 [error] 1223 1058
                2013-5-26+17-14-0.178 [error] 1223 1058
                2013-5-26+18-14-0.201 [error] 1223 1058
                2013-5-26+19-14-0.296 [error] 1223 1058
                2013-5-26+20-27-15.437 [error] 1223 1058
                2013-5-27+8-32-6.404 [error] 1223 1058
                2013-5-27+9-14-0.443 [error] 1223 1058
                2013-5-27+10-14-0.149 [error] 1223 1058
                2013-5-27+11-14-0.43 [error] 1223 1058
                2013-5-27+17-6-38.247 [error] 1223 1058
                2013-5-27+17-14-0.189 [error] 1223 1058
                2013-5-27+18-14-0.272 [error] 1223 1058
                2013-5-27+19-14-0.202 [error] 1223 1058
                2013-5-27+20-14-0.149 [error] 1223 1058
                2013-5-27+21-14-0.271 [error] 1223 1058
                2013-5-27+22-14-0.197 [error] 1223 1058
                2013-5-27+23-14-0.196 [error] 1223 1058
                2013-5-28+0-14-0.193 [error] 1223 1058
                2013-5-28+1-14-0.687 [error] 1223 1058
                2013-5-28+2-14-0.191 [error] 1223 1058
                2013-5-28+3-14-0.193 [error] 1223 1058
                2013-5-28+8-33-31.826 [error] 1223 1058
                2013-5-28+17-38-22.842 [error] 1223 1058
                2013-5-28+18-14-0.205 [error] 1223 1058
                2013-5-28+19-14-0.177 [error] 1223 1058
                2013-5-28+20-14-0.198 [error] 1223 1058
                2013-5-28+21-14-0.175 [error] 1223 1058
                2013-5-28+21-14-0.222 [error] 1223 1058
                2013-5-28+22-14-0.299 [error] 1223 1058
                2013-5-28+23-14-0.193 [error] 1223 1058
                2013-5-29+0-14-0.632 [error] 1223 1058
                2013-5-29+1-14-0.196 [error] 1223 1058
                2013-5-29+2-14-0.183 [error] 1223 1058
                2013-5-29+3-14-0.201 [error] 1223 1058
                2013-5-29+8-17-52.780 [error] 1223 1058
                2013-5-29+8-17-52.905 [error] 1223 1058
                2013-5-29+18-10-58.328 [error] 1223 1058
                2013-5-29+18-14-0.42 [error] 1223 1058
                2013-5-29+19-14-0.225 [error] 1223 1058
                2013-5-29+20-14-0.187 [error] 1223 1058
                2013-5-29+21-14-0.229 [error] 1223 1058
                2013-5-29+22-14-0.201 [error] 1223 1058
                2013-5-29+23-14-0.188 [error] 1223 1058
                2013-5-30+0-14-0.265 [error] 1223 1058
                2013-5-30+1-14-0.199 [error] 1223 1058
                2013-5-30+2-14-0.717 [error] 1223 1058
                2013-5-30+3-14-0.220 [error] 1223 1058
                2013-5-30+4-40-56.842 [error] 1223 1058
                2013-5-30+5-32-22.562 [error] 1223 1058
                2013-5-30+6-14-0.169 [error] 1223 1058
                2013-5-30+8-10-27.688 [error] 1223 1058
                2013-5-30+8-58-23.499 [error] 1223 1058
                2013-5-30+9-36-2.749 [error] 1223 1058
                2013-5-30+15-13-50.655 [error] 1223 1058
                2013-5-30+15-14-0.15 [error] 1223 1058
                2013-5-30+16-14-0.225 [error] 1223 1058
                2013-5-30+17-14-0.188 [error] 1223 1058
                2013-5-30+18-14-0.191 [error] 1223 1058
                2013-5-30+19-14-0.194 [error] 1223 1058
                2013-5-30+20-42-42.251 [error] 1223 1058
                2013-5-30+22-41-53.92 [error] 1223 1058
                2013-5-30+23-14-0.200 [error] 1223 1058
                2013-5-31+0-14-0.433 [error] 1223 1058
                2013-5-31+1-14-0.186 [error] 1223 1058
                2013-5-31+2-14-0.189 [error] 1223 1058
                2013-5-31+3-14-0.192 [error] 1223 1058
                2013-5-31+8-54-4.857 [error] 1223 1058
                2013-5-31+17-21-45.124 [error] 1223 1058
                2013-5-31+18-14-0.189 [error] 1223 1058
                2013-5-31+19-14-0.190 [error] 1223 1058
                2013-5-31+20-14-0.240 [error] 1223 1058
                2013-5-31+21-14-0.190 [error] 1223 1058
                2013-5-31+22-14-0.192 [error] 1223 1058
                2013-6-1+0-33-24.154 [error] 1223 1058
                2013-6-1+1-14-0.358 [error] 1223 1058
                2013-6-1+2-14-0.189 [error] 1223 1058
                2013-6-1+3-14-0.566 [error] 1223 1058
                2013-6-1+8-50-19.493 [error] 1223 1058
                2013-6-1+9-14-0.190 [error] 1223 1058
                2013-6-1+10-14-0.52 [error] 1223 1058
                2013-6-1+11-14-0.40 [error] 1223 1058
                2013-6-1+12-14-0.42 [error] 1223 1058
                2013-6-1+13-14-0.45 [error] 1223 1058
                2013-6-1+14-14-0.63 [error] 1223 1058
                2013-6-1+15-14-0.35 [error] 1223 1058
                2013-6-1+16-14-0.38 [error] 1223 1058
                2013-6-1+17-14-0.37 [error] 1223 1058
                2013-6-1+18-14-0.109 [error] 1223 1058
                2013-6-1+19-14-0.188 [error] 1223 1058
                2013-6-1+20-14-0.191 [error] 1223 1058
                2013-6-1+21-14-0.200 [error] 1223 1058
                2013-6-1+22-14-0.187 [error] 1223 1058
                2013-6-1+23-14-0.174 [error] 1223 1058
                2013-6-2+4-39-2.374 [error] 1223 1058
                2013-6-2+19-14-0.195 [error] 1223 1058
                2013-6-2+20-14-0.182 [error] 1223 1058
                2013-6-2+21-14-0.201 [error] 1223 1058
                2013-6-3+5-0-47.608 [error] 1223 1058
                2013-6-3+17-14-0.263 [error] 1223 1058
                2013-6-3+18-14-0.186 [error] 1223 1058
                2013-6-3+19-14-0.206 [error] 1223 1058
                2013-6-3+20-14-0.243 [error] 1223 1058
                2013-6-3+21-14-0.199 [error] 1223 1058
                2013-6-3+23-0-59.545 [error] 1223 1058
                2013-6-3+23-14-0.189 [error] 1223 1058
                2013-6-4+0-14-0.236 [error] 1223 1058
                2013-6-4+1-14-0.197 [error] 1223 1058
                2013-6-4+2-14-0.200 [error] 1223 1058
                2013-6-4+3-14-0.187 [error] 1223 1058
                2013-6-4+17-14-0.233 [error] 1223 1058
                2013-6-4+18-14-0.267 [error] 1223 1058
                2013-6-4+19-14-0.192 [error] 1223 1058
                2013-6-4+20-21-38.14 [error] 1223 1058
                2013-6-4+21-14-0.188 [error] 1223 1058
                2013-6-4+22-14-0.558 [error] 1223 1058
                2013-6-4+23-14-0.173 [error] 1223 1058
                2013-6-5+0-14-0.187 [error] 1223 1058
                2013-6-5+1-14-0.181 [error] 1223 1058
                2013-6-5+2-14-0.199 [error] 1223 1058
                2013-6-5+3-14-0.202 [error] 1223 1058
                2013-6-5+14-52-55.551 [error] 1223 1058
                2013-6-5+15-14-0.221 [error] 1223 1058
                2013-6-5+16-14-0.192 [error] 1223 1058
                2013-6-5+17-14-0.195 [error] 1223 1058
                2013-6-5+19-12-49.108 [error] 1223 1058
                2013-6-5+19-14-0.15 [error] 1223 1058
                2013-6-5+20-14-0.196 [error] 1223 1058
                2013-6-5+21-14-0.198 [error] 1223 1058
                2013-6-5+22-14-0.201 [error] 1223 1058
                2013-6-5+23-14-18.952 [error] 1223 1058
                2013-6-6+0-14-0.213 [error] 1223 1058
                2013-6-6+1-14-0.325 [error] 1223 1058
                2013-6-6+2-14-4.88 [error] 1223 1058
                2013-6-6+17-11-45.76 [error] 1223 1058
                2013-6-6+17-14-0.16 [error] 1223 1058
                2013-6-6+18-14-0.292 [error] 1223 1058
                2013-6-6+19-14-0.193 [error] 1223 1058
                2013-6-6+20-14-0.196 [error] 1223 1058
                2013-6-6+21-14-0.199 [error] 1223 1058
                2013-6-7+5-9-57.249 [error] 1223 1058
                2013-6-11+17-14-1.981 [error] 1223 1058
                2013-6-11+18-14-7.399 [error] 1223 1058
                2013-6-11+19-14-0.350 [error] 1223 1058
                2013-6-11+20-14-0.197 [error] 1223 1058
                2013-6-11+23-19-40.530 [error] 1223 1058
                2013-6-12+0-14-6.124 [error] 1223 1058
                2013-6-12+1-14-0.203 [error] 1223 1058
                2013-6-12+2-14-0.314 [error] 1223 1058
                2013-6-12+3-14-0.196 [error] 1223 1058
                2013-6-12+3-14-0.230 [error] 1223 1058
                2013-6-12+4-14-0.194 [error] 1223 1058
                2013-6-12+18-14-0.597 [error] 1223 1058
                2013-6-12+19-14-0.192 [error] 1223 1058
                2013-6-12+20-14-0.196 [error] 1223 1058
                2013-6-12+21-14-0.172 [error] 1223 1058
                2013-6-12+22-14-0.356 [error] 1223 1058
                2013-6-12+23-14-0.176 [error] 1223 1058
                2013-6-12+23-14-0.223 [error] 1223 1058
                2013-6-13+0-14-0.193 [error] 1223 1058
                2013-6-13+1-14-0.194 [error] 1223 1058
                2013-6-13+1-14-0.225 [error] 1223 1058
                2013-6-13+2-14-0.197 [error] 1223 1058
                2013-6-13+3-14-0.231 [error] 1223 1058
                2013-6-13+10-0-26.912 [error] 1223 1058
                2013-6-13+10-14-0.204 [error] 1223 1058
                2013-6-13+11-14-0.284 [error] 1223 1058
                2013-6-13+12-14-0.194 [error] 1223 1058
                2013-6-13+13-14-0.196 [error] 1223 1058
                2013-6-13+16-15-52.328 [error] 1223 1058
                2013-6-13+17-14-0.173 [error] 1223 1058
                2013-6-13+18-14-0.266 [error] 1223 1058
                2013-6-13+19-14-0.221 [error] 1223 1058
                2013-6-13+20-23-42.562 [error] 1223 1058
                2013-6-13+22-42-35.578 [error] 1223 1058
                2013-6-13+23-14-0.195 [error] 1223 1058
                2013-6-14+0-14-0.195 [error] 1223 1058
                2013-6-14+1-14-0.267 [error] 1223 1058
                2013-6-14+2-14-0.208 [error] 1223 1058
                2013-6-14+3-14-0.195 [error] 1223 1058
                2013-6-14+4-14-0.197 [error] 1223 1058
                2013-6-14+16-24-41.375 [error] 1223 1058
                2013-6-14+17-14-0.744 [error] 1223 1058
                2013-6-14+18-14-0.193 [error] 1223 1058
                2013-6-14+19-14-0.231 [error] 1223 1058
                2013-6-14+20-14-0.191 [error] 1223 1058
                2013-6-14+21-14-0.252 [error] 1223 1058
                2013-6-14+22-14-1.982 [error] 1223 1058
                2013-6-14+23-14-0.300 [error] 1223 1058
                2013-6-15+0-14-0.193 [error] 1223 1058
                2013-6-15+1-14-0.199 [error] 1223 1058
                2013-6-15+2-14-0.179 [error] 1223 1058
                2013-6-15+3-14-0.197 [error] 1223 1058
                2013-6-15+4-14-0.356 [error] 1223 1058
                2013-6-15+5-14-0.187 [error] 1223 1058
                2013-6-15+19-32-54.562 [error] 1223 1058
                2013-6-15+20-14-0.189 [error] 1223 1058
                2013-6-15+21-14-3.906 [error] 1223 1058
                2013-6-15+22-14-2.720 [error] 1223 1058
                2013-6-16+16-45-29.28 [error] 1223 1058
                2013-6-16+17-14-0.658 [error] 1223 1058
                2013-6-16+18-14-0.345 [error] 1223 1058
                2013-6-16+19-14-0.192 [error] 1223 1058
                2013-6-16+20-14-0.195 [error] 1223 1058
                2013-6-16+21-14-0.198 [error] 1223 1058
                2013-6-16+22-14-0.200 [error] 1223 1058
                2013-6-16+23-14-0.187 [error] 1223 1058
                2013-6-17+16-54-11.30 [error] 1223 1058
                2013-6-17+17-14-2.390 [error] 1223 1058
                2013-6-17+18-14-0.146 [error] 1223 1058
                2013-6-17+19-14-0.32 [error] 1223 1058
                2013-6-17+20-14-0.190 [error] 1223 1058
                2013-6-17+21-14-0.349 [error] 1223 1058
                2013-6-17+22-14-0.189 [error] 1223 1058
                2013-6-17+23-14-0.195 [error] 1223 1058
                2013-6-18+0-14-0.195 [error] 1223 1058
                2013-6-18+1-14-0.198 [error] 1223 1058
                2013-6-18+2-14-0.201 [error] 1223 1058
                2013-6-18+10-0-22.139 [error] 1223 1058
                2013-6-18+10-14-0.33 [error] 1223 1058
                2013-6-18+11-14-0.35 [error] 1223 1058
                2013-6-18+12-14-0.22 [error] 1223 1058
                2013-6-18+15-45-28.361 [error] 1223 1058
                2013-6-18+16-14-0.104 [error] 1223 1058
                2013-6-18+17-14-0.200 [error] 1223 1058
                2013-6-18+18-14-0.195 [error] 1223 1058
                2013-6-18+19-14-0.197 [error] 1223 1058
                2013-6-18+20-14-0.193 [error] 1223 1058
                2013-6-18+21-14-0.196 [error] 1223 1058
                2013-6-18+22-14-0.199 [error] 1223 1058
                2013-6-18+23-14-0.201 [error] 1223 1058
                2013-6-19+16-15-21.265 [error] 1223 1058
                2013-6-19+17-14-0.206 [error] 1223 1058
                2013-6-19+18-14-0.193 [error] 1223 1058
                2013-6-19+19-14-0.198 [error] 1223 1058
                2013-6-19+20-14-0.196 [error] 1223 1058
                2013-6-19+21-14-0.199 [error] 1223 1058
                2013-6-19+22-14-0.186 [error] 1223 1058
                2013-6-19+23-25-43.937 [error] 1223 1058
                2013-6-20+0-14-0.193 [error] 1223 1058
                2013-6-20+1-14-0.189 [error] 1223 1058
                2013-6-20+2-14-0.347 [error] 1223 1058
                2013-6-20+3-14-0.192 [error] 1223 1058
                2013-6-20+16-18-38.936 [error] 1223 1058
                2013-6-20+17-14-0.386 [error] 1223 1058
                2013-6-20+18-14-0.311 [error] 1223 1058
                2013-6-20+19-14-0.189 [error] 1223 1058
                2013-6-20+20-36-50.264 [error] 1223 1058
                2013-6-20+21-14-0.188 [error] 1223 1058
                2013-6-20+22-14-0.197 [error] 1223 1058
                2013-6-20+23-14-0.200 [error] 1223 1058
                2013-6-21+0-14-0.203 [error] 1223 1058
                2013-6-21+4-33-22.920 [error] 1223 1058
                2013-6-21+5-14-0.194 [error] 1223 1058
                2013-6-21+6-14-0.197 [error] 1223 1058
                2013-6-21+7-14-0.200 [error] 1223 1058
                2013-6-21+15-24-19.609 [error] 1223 1058
                2013-6-21+15-31-39.405 [error] 1226 1062
                =O====== M/11.7.700.224 2013-06-21+15-31-18.610 ========
                0000 [I] 00000010 "C:\Users\nellem\AppData\Local\Temp\{DEC962C7-C7CC-40C6-B3BB-495D7EF53D38}\InstallFlashPl ayer.exe" -iv 4
                0002 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll 5
                0003 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll 5
                0004 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe 5
                0005 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe 5
                0006 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_224.ocx
                0007 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
                0008 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
                0009 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                0010 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0011 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                0012 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                0014 [W] 00001106
                0015 [W] 00001106
                0016 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0017 [I] 00000012
                =X====== M/11.7.700.224 2013-06-21+15-31-48.125 ========
                =O====== M/11.7.700.202 2013-06-21+15-29-24.141 ========
                0000 [I] 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe" -update activex
                0001 [I] 00000011 1
                =X====== M/11.7.700.202 2013-06-21+15-31-48.172 ========
                2013-6-21+16-14-0.376 [error] 1223 1058
                2013-6-21+17-14-0.191 [error] 1223 1058
                2013-6-21+18-14-0.194 [error] 1223 1058
                2013-6-21+19-19-32.736 [error] 1223 1058
                2013-6-21+20-14-0.212 [error] 1223 1058
                2013-6-21+21-14-0.203 [error] 1223 1058
                2013-6-21+22-14-0.237 [error] 1223 1058
                2013-6-21+23-14-0.333 [error] 1223 1058
                2013-6-22+0-15-12.92 [error] 1223 1058
                2013-6-22+1-14-0.187 [error] 1223 1058
                2013-6-22+2-14-0.190 [error] 1223 1058
                2013-6-22+3-14-0.208 [error] 1223 1058
                2013-6-22+17-58-37.189 [error] 1223 1058
                2013-6-22+18-14-0.314 [error] 1223 1058
                2013-6-22+19-14-0.302 [error] 1223 1058
                2013-6-22+20-14-0.690 [error] 1223 1058
                2013-6-22+21-16-50.338 [error] 1223 1058
                2013-6-23+19-23-45.640 [error] 1223 1058
                2013-6-23+20-14-0.361 [error] 1223 1058
                2013-6-23+21-14-0.269 [error] 1223 1058
                2013-6-23+22-14-0.256 [error] 1223 1058
                2013-6-23+23-14-0.257 [error] 1223 1058
                2013-6-24+0-14-0.260 [error] 1223 1058
                2013-6-24+1-14-0.278 [error] 1223 1058
                2013-6-24+2-14-0.172 [error] 1223 1058
                2013-6-24+3-14-0.65 [error] 1223 1058
                2013-6-24+3-14-0.284 [error] 1223 1058
                2013-6-24+18-14-0.221 [error] 1223 1058
                2013-6-24+19-14-0.252 [error] 1223 1058
                2013-6-24+20-14-0.284 [error] 1223 1058
                2013-6-24+21-14-0.307 [error] 1223 1058
                2013-6-24+22-14-0.257 [error] 1223 1058
                2013-6-24+23-14-0.279 [error] 1223 1058
                2013-6-25+0-14-0.278 [error] 1223 1058
                2013-6-25+1-14-0.249 [error] 1223 1058
                2013-6-25+2-14-0.970 [error] 1223 1058
                2013-6-25+16-45-16.904 [error] 1223 1058
                2013-6-25+17-14-0.258 [error] 1223 1058
                2013-6-25+18-14-0.480 [error] 1223 1058
                2013-6-25+19-14-0.249 [error] 1223 1058
                2013-6-25+20-40-8.0 [error] 1223 1058
                2013-6-25+21-14-0.258 [error] 1223 1058
                2013-6-25+22-14-0.250 [error] 1223 1058
                2013-6-25+23-14-0.258 [error] 1223 1058
                2013-6-26+0-14-0.284 [error] 1223 1058
                2013-6-26+1-14-0.280 [error] 1223 1058
                2013-6-26+2-14-23.277 [error] 1223 1058
                2013-6-26+3-14-0.254 [error] 1223 1058
                2013-6-26+17-8-7.391 [error] 1223 1058
                2013-6-26+17-14-0.252 [error] 1223 1058
                2013-6-26+18-14-0.255 [error] 1223 1058
                2013-6-26+19-14-0.280 [error] 1223 1058
                2013-6-26+20-14-0.280 [error] 1223 1058
                2013-6-26+21-14-0.300 [error] 1223 1058
                2013-6-26+22-14-0.454 [error] 1223 1058
                2013-6-26+23-14-0.267 [error] 1223 1058
                2013-6-27+0-14-0.255 [error] 1223 1058
                2013-6-27+1-14-0.325 [error] 1223 1058
                2013-6-27+2-14-2.504 [error] 1223 1058
                2013-6-27+3-14-0.298 [error] 1223 1058
                2013-6-27+20-54-34.598 [error] 1223 1058
                2013-6-27+21-14-0.259 [error] 1223 1058
                2013-6-27+22-14-0.263 [error] 1223 1058
                2013-6-27+23-14-0.285 [error] 1223 1058
                2013-6-28+0-14-0.253 [error] 1223 1058
                2013-6-28+1-14-0.475 [error] 1223 1058
                2013-6-28+2-14-0.713 [error] 1223 1058
                2013-6-28+3-14-0.388 [error] 1223 1058
                2013-6-28+4-15-59.99 [error] 1223 1058
                2013-6-28+15-13-9.680 [error] 1223 1058
                2013-6-28+15-14-6.588 [error] 1223 1058
                2013-6-28+16-14-0.271 [error] 1223 1058
                2013-6-28+17-14-0.262 [error] 1223 1058
                2013-6-28+18-14-0.347 [error] 1223 1058
                2013-6-28+19-14-0.291 [error] 1223 1058
                2013-6-28+20-14-0.260 [error] 1223 1058
                2013-6-28+21-14-0.328 [error] 1223 1058
                2013-6-28+22-14-0.419 [error] 1223 1058
                2013-6-28+23-14-0.257 [error] 1223 1058
                2013-6-29+0-14-0.262 [error] 1223 1058
                2013-6-29+1-14-0.253 [error] 1223 1058
                2013-6-29+2-14-0.257 [error] 1223 1058
                2013-6-29+3-14-0.259 [error] 1223 1058
                2013-6-29+22-10-35.467 [error] 1223 1058
                2013-6-29+22-14-0.90 [error] 1223 1058
                2013-6-29+23-14-0.470 [error] 1223 1058
                2013-6-30+0-14-20.880 [error] 1223 1058
                2013-6-30+1-14-1.610 [error] 1223 1058
                2013-6-30+2-14-1.482 [error] 1223 1058
                2013-6-30+3-14-0.284 [error] 1223 1058
                2013-6-30+4-14-0.271 [error] 1223 1058
                2013-6-30+5-14-2.697 [error] 1223 1058
                2013-6-30+6-14-1.358 [error] 1223 1058
                2013-6-30+7-14-0.284 [error] 1223 1058
                2013-6-30+16-54-27.343 [error] 1223 1058
                2013-6-30+17-14-0.283 [error] 1223 1058
                2013-6-30+18-14-0.272 [error] 1223 1058
                2013-6-30+19-14-0.299 [error] 1223 1058
                2013-6-30+20-14-1.85 [error] 1223 1058
                2013-6-30+21-14-0.261 [error] 1223 1058
                2013-6-30+22-15-25.328 [error] 1223 1058
                2013-6-30+23-14-0.265 [error] 1223 1058
                2013-7-1+18-27-33.257 [error] 1223 1058
                2013-7-1+19-14-0.86 [error] 1223 1058
                2013-7-1+20-14-0.296 [error] 1223 1058
                2013-7-1+21-14-0.269 [error] 1223 1058
                2013-7-1+22-14-0.353 [error] 1223 1058
                2013-7-1+23-14-0.262 [error] 1223 1058
                2013-7-2+0-14-0.258 [error] 1223 1058
                2013-7-2+1-14-0.271 [error] 1223 1058
                2013-7-2+2-14-0.383 [error] 1223 1058
                2013-7-2+3-14-0.277 [error] 1223 1058
                2013-7-2+16-37-7.900 [error] 1223 1058
                2013-7-2+17-14-0.332 [error] 1223 1058
                2013-7-2+18-14-0.257 [error] 1223 1058
                2013-7-2+19-14-0.275 [error] 1223 1058
                2013-7-2+20-14-0.306 [error] 1223 1058
                2013-7-2+21-14-0.215 [error] 1223 1058
                2013-7-2+22-14-0.265 [error] 1223 1058
                2013-7-2+23-14-0.321 [error] 1223 1058
                2013-7-3+0-14-0.258 [error] 1223 1058
                2013-7-3+1-14-0.261 [error] 1223 1058
                2013-7-3+2-14-0.263 [error] 1223 1058
                2013-7-3+3-14-0.274 [error] 1223 1058
                2013-7-3+4-14-0.269 [error] 1223 1058
                2013-7-3+17-2-14.780 [error] 1223 1058
                2013-7-3+17-14-0.265 [error] 1223 1058
                2013-7-3+18-14-0.240 [error] 1223 1058
                2013-7-3+19-14-0.346 [error] 1223 1058
                2013-7-3+20-14-0.271 [error] 1223 1058
                2013-7-3+21-14-0.258 [error] 1223 1058
                2013-7-4+18-18-8.433 [error] 1223 1058
                2013-7-4+19-14-0.251 [error] 1223 1058
                2013-7-4+20-14-0.268 [error] 1223 1058
                2013-7-4+21-14-0.290 [error] 1223 1058
                2013-7-4+22-14-0.883 [error] 1223 1058
                2013-7-4+23-14-0.366 [error] 1223 1058
                2013-7-5+0-14-0.260 [error] 1223 1058
                2013-7-5+1-14-0.262 [error] 1223 1058
                2013-7-5+3-35-5.229 [error] 1223 1058
                2013-7-5+4-14-0.269 [error] 1223 1058
                2013-7-5+16-14-0.276 [error] 1223 1058
                2013-7-5+17-14-0.287 [error] 1223 1058
                2013-7-5+18-14-0.258 [error] 1223 1058
                2013-7-5+19-14-0.262 [error] 1223 1058
                2013-7-5+21-18-6.546 [error] 1223 1058
                2013-7-5+22-14-0.202 [error] 1223 1058
                2013-7-5+23-14-0.252 [error] 1223 1058
                2013-7-6+0-14-0.270 [error] 1223 1058
                2013-7-6+1-14-0.261 [error] 1223 1058
                2013-7-6+2-14-0.264 [error] 1223 1058
                2013-7-6+17-33-9.636 [error] 1223 1058
                2013-7-6+18-14-0.449 [error] 1223 1058
                2013-7-6+19-14-6.269 [error] 1223 1058
                2013-7-6+20-14-0.483 [error] 1223 1058
                2013-7-7+21-58-56.848 [error] 1223 1058
                2013-7-7+22-14-0.278 [error] 1223 1058
                2013-7-7+23-14-0.220 [error] 1223 1058
                2013-7-8+0-14-0.223 [error] 1223 1058
                2013-7-8+1-14-0.260 [error] 1223 1058
                2013-7-8+2-14-0.107 [error] 1223 1058
                2013-7-8+3-14-0.63 [error] 1223 1058
                2013-7-8+4-14-0.66 [error] 1223 1058
                2013-7-8+16-2-49.136 [error] 1223 1058
                2013-7-8+16-14-0.260 [error] 1223 1058
                2013-7-8+17-14-0.263 [error] 1223 1058
                2013-7-8+18-14-0.253 [error] 1223 1058
                2013-7-8+19-14-0.253 [error] 1223 1058
                2013-7-8+20-14-0.395 [error] 1223 1058
                2013-7-8+21-14-0.225 [error] 1223 1058
                2013-7-8+22-14-0.252 [error] 1223 1058
                2013-7-8+23-14-0.294 [error] 1223 1058
                2013-7-9+0-14-0.252 [error] 1223 1058
                2013-7-9+1-14-0.253 [error] 1223 1058
                2013-7-9+2-14-0.255 [error] 1223 1058
                2013-7-9+3-14-0.270 [error] 1223 1058
                2013-7-9+15-14-0.245 [error] 1223 1058
                2013-7-9+16-14-0.272 [error] 1223 1058
                2013-7-9+17-14-0.228 [error] 1223 1058
                2013-7-9+18-14-0.245 [error] 1223 1058
                2013-7-9+19-14-0.259 [error] 1223 1058
                2013-7-9+20-14-0.317 [error] 1223 1058
                2013-7-9+21-14-0.316 [error] 1223 1058
                2013-7-9+22-14-0.255 [error] 1223 1058
                2013-7-9+23-14-0.246 [error] 1223 1058
                2013-7-10+0-14-0.267 [error] 1223 1058
                2013-7-10+1-14-0.255 [error] 1223 1058
                2013-7-10+2-14-0.246 [error] 1223 1058
                2013-7-10+16-14-0.278 [error] 1223 1058
                2013-7-10+17-14-1.44 [error] 1223 1058
                2013-7-10+18-14-0.336 [error] 1223 1058
                2013-7-10+19-14-0.251 [error] 1223 1058
                2013-7-10+21-34-5.199 [error] 1223 1058
                2013-7-10+22-14-0.258 [error] 1223 1058
                2013-7-10+23-14-0.256 [error] 1223 1058
                2013-7-11+0-14-0.250 [error] 1223 1058
                2013-7-11+10-0-28.192 [error] 1223 1058
                2013-7-11+10-14-0.575 [error] 1223 1058
                2013-7-11+11-14-0.274 [error] 1223 1058
                2013-7-11+12-14-0.261 [error] 1223 1058
                2013-7-11+13-14-0.217 [error] 1223 1058
                2013-7-11+15-44-20.685 [error] 1223 1058
                2013-7-11+16-14-0.273 [error] 1223 1058
                2013-7-11+17-14-0.257 [error] 1223 1058
                2013-7-11+18-14-0.254 [error] 1223 1058
                2013-7-11+19-14-0.245 [error] 1223 1058
                2013-7-11+20-14-0.233 [error] 1223 1058
                2013-7-11+21-14-0.254 [error] 1223 1058
                2013-7-11+22-14-0.273 [error] 1223 1058
                2013-7-11+23-14-0.385 [error] 1223 1058
                2013-7-12+0-14-0.311 [error] 1223 1058
                2013-7-12+1-14-0.237 [error] 1223 1058
                2013-7-12+2-14-0.255 [error] 1223 1058
                2013-7-12+3-14-0.258 [error] 1223 1058
                2013-7-12+4-16-0.439 [error] 1223 1058
                2013-7-12+17-14-0.307 [error] 1223 1058
                2013-7-12+18-14-0.565 [error] 1223 1058
                2013-7-12+19-14-0.256 [error] 1223 1058
                2013-7-12+20-14-0.258 [error] 1223 1058
                2013-7-12+21-27-45.439 [error] 1223 1058
                =O====== M/11.7.700.224 2013-07-12+21-43-56.129 ========
                0000 [I] 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe" -update activex
                0001 [E] 00001039
                =X====== M/11.7.700.224 2013-07-12+21-44-02.989 ========
                =O====== M/11.8.800.94 2013-08-06+14-46-34.227 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -refreshIEElevationPolicies
                =X====== M/11.8.800.94 2013-08-06+14-46-34.286 ========
                =O====== M/11.8.800.94 2013-08-06+14-46-31.314 ========
                0000 [I] 00000010 "C:\Users\nellem\AppData\Local\Adobe\AIH.37995c13545288fd47f7ec6e5eb0e1c62c12939b\install _flash_player_ax.exe" -install -iv 8
                0002 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_94.ocx
                0003 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
                0004 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
                0010 [W] 00001106
                0011 [W] 00001106
                0012 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0013 [I] 00000012
                =X====== M/11.8.800.94 2013-08-06+14-46-37.381 ========
                =O====== M/11.8.800.94 2013-08-06+23-38-24.353 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -maintain activex
                =X====== M/11.8.800.94 2013-08-06+23-38-28.736 ========
                =O====== M/11.8.800.94 2013-08-06+23-42-14.240 ========
                0001 [F] 00001041
                =X====== M/11.8.800.94 2013-08-06+23-42-14.398 ========
                =O====== M/11.8.800.94 2013-08-06+23-43-20.904 ========
                0001 [F] 00001041
                =X====== M/11.8.800.94 2013-08-06+23-43-21.063 ========
                =O====== M/11.8.800.94 2013-08-06+23-43-23.776 ========
                0001 [F] 00001041
                =X====== M/11.8.800.94 2013-08-06+23-43-23.963 ========
                =O====== M/11.8.800.94 2013-08-06+23-43-31.958 ========
                0010 [W] 00001106
                0011 [W] 00001106
                0013 [I] 00000012
                =X====== M/11.8.800.94 2013-08-06+23-43-35.551 ========
                2013-9-20+2-14-2.596 [error] 1223 1058
                2013-9-20+3-14-0.431 [error] 1223 1058
                2013-9-20+18-14-0.193 [error] 1223 1058
                2013-9-20+19-14-0.305 [error] 1223 1058
                2013-9-20+20-14-0.276 [error] 1223 1058
                2013-9-20+23-31-19.905 [error] 1223 1058
                2013-9-21+0-14-0.274 [error] 1223 1058
                2013-9-21+1-14-0.277 [error] 1223 1058
                2013-9-21+2-14-0.279 [error] 1223 1058
                2013-9-21+18-19-31.716 [error] 1223 1058
                2013-9-21+19-14-0.563 [error] 1223 1058
                2013-9-21+20-14-7.23 [error] 1223 1058
                2013-9-21+21-14-0.622 [error] 1223 1058
                2013-9-21+22-14-4.134 [error] 1223 1058
                2013-9-22+18-21-18.958 [error] 1223 1058
                2013-9-22+19-14-0.324 [error] 1223 1058
                2013-9-22+20-14-0.298 [error] 1223 1058
                2013-9-22+21-14-0.264 [error] 1223 1058
                2013-9-22+22-14-0.298 [error] 1223 1058
                2013-9-22+23-14-0.285 [error] 1223 1058
                2013-9-23+5-1-25.855 [error] 1223 1058
                2013-9-23+20-14-0.317 [error] 1223 1058
                2013-9-23+21-14-0.304 [error] 1223 1058
                2013-9-23+22-14-0.343 [error] 1223 1058
                2013-9-23+23-14-0.289 [error] 1223 1058
                2013-9-24+0-14-0.295 [error] 1223 1058
                2013-9-24+1-14-0.267 [error] 1223 1058
                2013-9-24+2-14-0.269 [error] 1223 1058
                2013-9-24+3-14-0.271 [error] 1223 1058
                2013-9-24+4-14-0.274 [error] 1223 1058
                2013-9-24+19-30-29.95 [error] 1223 1058
                2013-9-24+20-14-0.279 [error] 1223 1058
                2013-9-24+21-14-0.252 [error] 1223 1058
                2013-9-24+22-14-0.249 [error] 1223 1058
                2013-9-24+23-14-0.274 [error] 1223 1058
                2013-9-25+0-14-0.265 [error] 1223 1058
                2013-9-25+1-14-0.300 [error] 1223 1058
                2013-9-25+2-14-0.288 [error] 1223 1058
                2013-9-25+3-14-0.291 [error] 1223 1058
                2013-9-25+4-14-0.206 [error] 1223 1058
                2013-9-25+19-14-0.285 [error] 1223 1058
                2013-9-25+20-14-0.288 [error] 1223 1058
                2013-9-25+21-14-0.659 [error] 1223 1058
                2013-9-25+22-14-0.266 [error] 1223 1058
                2013-9-25+23-14-0.275 [error] 1223 1058
                2013-9-26+0-14-0.274 [error] 1223 1058
                2013-9-26+1-14-0.375 [error] 1223 1058
                2013-9-26+2-14-0.417 [error] 1223 1058
                2013-9-26+3-14-0.279 [error] 1223 1058
                2013-9-26+15-14-0.340 [error] 1223 1058
                2013-9-26+16-14-0.291 [error] 1223 1058
                2013-9-26+17-14-0.271 [error] 1223 1058
                2013-9-26+18-14-0.274 [error] 1223 1058
                2013-9-26+19-14-0.277 [error] 1223 1058
                2013-9-26+20-57-23.296 [error] 1223 1058
                2013-9-26+21-14-0.256 [error] 1223 1058
                2013-9-26+22-14-0.362 [error] 1223 1058
                2013-9-26+23-14-0.261 [error] 1223 1058
                2013-9-27+0-14-0.279 [error] 1223 1058
                2013-9-27+1-14-0.270 [error] 1223 1058
                2013-9-27+3-14-0.349 [error] 1223 1058
                2013-9-27+4-14-0.303 [error] 1223 1058
                2013-9-27+16-14-0.284 [error] 1223 1058
                2013-9-27+17-14-0.293 [error] 1223 1058
                2013-9-27+18-14-0.234 [error] 1223 1058
                2013-9-27+19-14-0.246 [error] 1223 1058
                2013-9-27+20-14-0.259 [error] 1223 1058
                2013-9-27+21-14-0.240 [error] 1223 1058
                2013-9-27+22-14-0.293 [error] 1223 1058
                2013-9-27+23-14-0.229 [error] 1223 1058
                2013-9-28+0-14-0.280 [error] 1223 1058
                2013-9-28+1-14-1.764 [error] 1223 1058
                2013-9-28+2-14-0.269 [error] 1223 1058
                2013-9-28+4-58-51.281 [error] 1223 1058
                2013-9-28+20-14-0.308 [error] 1223 1058
                2013-9-28+21-14-1.93 [error] 1223 1058
                2013-9-28+22-14-0.737 [error] 1223 1058
                2013-9-29+18-32-26.622 [error] 1223 1058
                2013-9-29+19-14-1.38 [error] 1223 1058
                2013-9-29+20-14-0.556 [error] 1223 1058
                2013-9-29+21-14-0.606 [error] 1223 1058
                2013-9-29+22-14-0.594 [error] 1223 1058
                2013-9-29+23-14-0.157 [error] 1223 1058
                2013-9-30+0-14-0.456 [error] 1223 1058
                2013-9-30+1-14-0.458 [error] 1223 1058
                2013-9-30+2-14-1.7 [error] 1223 1058
                2013-9-30+18-42-30.154 [error] 1223 1058
                2013-9-30+19-14-0.407 [error] 1223 1058
                2013-9-30+20-14-0.319 [error] 1223 1058
                2013-9-30+21-14-0.275 [error] 1223 1058
                2013-9-30+22-14-0.287 [error] 1223 1058
                2013-9-30+23-14-0.277 [error] 1223 1058
                2013-10-1+0-14-0.336 [error] 1223 1058
                2013-10-1+1-14-0.283 [error] 1223 1058
                2013-10-1+2-14-0.380 [error] 1223 1058
                2013-10-1+3-14-0.254 [error] 1223 1058
                2013-10-1+4-14-0.260 [error] 1223 1058
                2013-10-1+16-14-0.394 [error] 1223 1058
                2013-10-1+17-14-1.458 [error] 1223 1058
                2013-10-1+18-14-0.275 [error] 1223 1058
                2013-10-1+19-20-32.17 [error] 1223 1058
                2013-10-1+20-14-0.312 [error] 1223 1058
                2013-10-1+21-14-0.271 [error] 1223 1058
                2013-10-1+22-14-0.337 [error] 1223 1058
                2013-10-1+23-14-0.268 [error] 1223 1058
                2013-10-2+0-29-4.188 [error] 1223 1058
                2013-10-2+1-14-0.265 [error] 1223 1058
                2013-10-2+2-14-0.252 [error] 1223 1058
                2013-10-2+3-14-0.271 [error] 1223 1058
                2013-10-2+4-56-42.842 [error] 1223 1058
                2013-10-2+18-14-0.303 [error] 1223 1058
                2013-10-2+19-14-0.284 [error] 1223 1058
                2013-10-2+20-14-0.285 [error] 1223 1058
                2013-10-2+21-14-0.272 [error] 1223 1058
                2013-10-2+22-14-0.274 [error] 1223 1058
                2013-10-3+0-0-37.878 [error] 1223 1058
                2013-10-3+0-14-0.268 [error] 1223 1058
                2013-10-3+1-14-0.271 [error] 1223 1058
                2013-10-3+2-14-1.274 [error] 1223 1058
                2013-10-3+3-14-0.327 [error] 1223 1058
                2013-10-3+15-38-58.608 [error] 1223 1058
                2013-10-3+16-14-0.499 [error] 1223 1058
                2013-10-3+17-14-0.346 [error] 1223 1058
                2013-10-3+18-14-0.271 [error] 1223 1058
                2013-10-3+19-14-0.275 [error] 1223 1058
                2013-10-3+21-6-13.451 [error] 1223 1058
                2013-10-3+21-14-0.288 [error] 1223 1058
                2013-10-3+22-14-0.259 [error] 1223 1058
                2013-10-3+23-14-0.221 [error] 1223 1058
                2013-10-4+0-14-0.276 [error] 1223 1058
                2013-10-4+1-14-0.278 [error] 1223 1058
                2013-10-4+2-14-0.296 [error] 1223 1058
                2013-10-4+3-14-0.267 [error] 1223 1058
                2013-10-4+4-58-33.703 [error] 1223 1058
                2013-10-4+22-14-0.274 [error] 1223 1058
                2013-10-4+23-14-0.277 [error] 1223 1058
                2013-10-5+0-14-0.263 [error] 1223 1058
                2013-10-5+1-14-0.266 [error] 1223 1058
                2013-10-5+2-14-0.268 [error] 1223 1058
                2013-10-5+17-0-31.502 [error] 1223 1058
                2013-10-5+17-14-0.272 [error] 1223 1058
                2013-10-5+18-14-0.839 [error] 1223 1058
                2013-10-5+19-14-4.240 [error] 1223 1058
                2013-10-5+20-14-0.537 [error] 1223 1058
                =O====== M/11.8.800.175 2013-10-05+21-09-39.986 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe" -refreshIEElevationPolicies
                =X====== M/11.8.800.175 2013-10-05+21-09-40.005 ========
                =O====== M/11.8.800.175 2013-10-05+21-09-40.033 ========
                =X====== M/11.8.800.175 2013-10-05+21-09-40.040 ========
                =O====== M/11.8.800.175 2013-10-05+21-09-40.047 ========
                =X====== M/11.8.800.175 2013-10-05+21-09-40.055 ========
                =O====== M/11.8.800.175 2013-10-05+21-09-36.120 ========
                0002 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
                0003 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
                0004 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
                0010 [W] 00001106
                0011 [W] 00001106
                0013 [I] 00000012
                =X====== M/11.8.800.175 2013-10-05+21-09-43.384 ========
                2013-10-5+21-14-0.363 [error] 1223 1058
                2013-10-5+22-14-0.287 [error] 1223 1058
                2013-10-5+23-14-0.294 [error] 1223 1058
                2013-10-6+0-14-0.265 [error] 1223 1058
                2013-10-6+1-14-0.268 [error] 1223 1058
                2013-10-6+4-42-44.831 [error] 1223 1058
                2013-10-6+17-25-40.814 [error] 1223 1058
                2013-10-6+18-14-0.305 [error] 1223 1058
                2013-10-6+19-14-0.277 [error] 1223 1058
                2013-10-6+20-14-1.869 [error] 1223 1058
                2013-10-6+21-14-0.281 [error] 1223 1058
                2013-10-6+22-14-0.299 [error] 1223 1058
                2013-10-7+2-52-31.48 [error] 1223 1058
                2013-10-7+3-14-0.81 [error] 1223 1058
                2013-10-7+4-14-0.68 [error] 1223 1058
                2013-10-7+16-29-47.320 [error] 1223 1058
                2013-10-7+17-14-0.289 [error] 1223 1058
                2013-10-7+18-14-0.287 [error] 1223 1058
                2013-10-7+19-14-0.249 [error] 1223 1058
                2013-10-7+20-14-0.331 [error] 1223 1058
                2013-10-7+21-14-0.265 [error] 1223 1058
                2013-10-7+22-14-0.266 [error] 1223 1058
                2013-10-7+23-14-0.278 [error] 1223 1058
                2013-10-8+0-14-0.267 [error] 1223 1058
                2013-10-8+1-14-0.273 [error] 1223 1058
                2013-10-8+16-34-54.544 [error] 1223 1058
                2013-10-8+17-14-0.415 [error] 1223 1058
                2013-10-8+18-14-0.382 [error] 1223 1058
                2013-10-8+19-14-0.245 [error] 1223 1058
                2013-10-8+22-25-49.804 [error] 1223 1058
                2013-10-8+23-14-0.208 [error] 1223 1058
                2013-10-9+0-14-0.314 [error] 1223 1058
                2013-10-9+1-14-0.426 [error] 1223 1058
                2013-10-9+2-14-0.263 [error] 1223 1058
                2013-10-9+3-14-0.234 [error] 1223 1058
                2013-10-9+4-14-0.242 [error] 1223 1058
                2013-10-9+15-14-0.285 [error] 1223 1058
                2013-10-9+16-14-0.247 [error] 1223 1058
                2013-10-9+17-14-0.271 [error] 1223 1058
                2013-10-9+18-14-0.196 [error] 1223 1058
                2013-10-9+19-14-0.245 [error] 1223 1058
                2013-10-9+22-20-2.406 [error] 1223 1058
                2013-10-9+23-14-0.174 [error] 1223 1058
                2013-10-10+0-14-0.233 [error] 1223 1058
                2013-10-10+1-14-0.237 [error] 1223 1058
                2013-10-10+2-14-2.236 [error] 1223 1058
                2013-10-10+3-14-0.304 [error] 1223 1058
                2013-10-10+4-26-25.170 [error] 1223 1058
                =O====== M/11.8.800.175 2013-10-10+04-39-21.016 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe" -maintain activex
                0001 [E] 00001039
                =X====== M/11.8.800.175 2013-10-10+04-39-32.685 ========
                2013-10-10+4-39-45.992 [error] 1226 1062
                =O====== M/11.8.800.175 2013-10-10+04-39-40.782 ========
                0001 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0002 [I] 00000018
                0003 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0004 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll 5
                0005 [I] 00000018
                0006 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll 5
                0007 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0008 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0009 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0010 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0011 [W] 00001021
                0012 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0014 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0016 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                0017 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0018 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0019 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll 5
                0020 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll 5
                0021 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0022 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0023 [I] 00000012
                =X====== M/11.8.800.175 2013-10-10+04-39-48.909 ========
                =O====== M/11.9.900.117 2013-10-10+04-42-55.180 ========
                0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -refreshIEElevationPolicies
                =X====== M/11.9.900.117 2013-10-10+04-42-55.202 ========
                =O====== M/11.9.900.117 2013-10-10+04-42-55.194 ========
                =X====== M/11.9.900.117 2013-10-10+04-42-55.206 ========
                =O====== M/11.9.900.117 2013-10-10+04-42-53.913 ========
                0000 [I] 00000010 "C:\Users\nellem\AppData\Local\Adobe\AIH.37995c13545288fd47f7ec6e5eb0e1c62c12939b\install _flash_player_ax.exe" -install -iv 8 -au 1
                0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0003 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0005 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_117.ocx
                0006 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
                0007 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
                0010 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0011 [I] 00000012
                =X====== M/11.9.900.117 2013-10-10+04-42-55.976 ========
                =O====== M/11.9.900.117 2013-10-10+15-30-29.452 ========
                0000 [I] 00000010 "C:\Users\nellem\Downloads\uninstall_flash_player.exe" -force
                0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0002 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0003 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0004 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0005 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0006 [W] 00001021
                0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0011 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                0014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0015 [W] 00001018
                0016 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0017 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0018 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                0019 [W] 00001019
                0020 [W] 00001020
                0021 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0022 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                0023 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0024 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0025 [W] 00001021
                0026 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0027 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0028 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                0029 [W] 00001048
                0030 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0031 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0032 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0033 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
                0034 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                0035 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0036 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0037 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0038 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0039 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0040 [W] 00001036 Software\Opera Software/Plugin Path 2
                0041 [W] 00001036 Software\Opera Software/Plugin Path 2
                0042 [E] 00001039
                =X====== M/11.9.900.117 2013-10-10+15-30-38.235 ========
                =O====== M/11.8.800.175 2013-10-11+00-55-09.002 ========
                =X====== M/11.8.800.175 2013-10-11+00-55-09.407 ========
                =O====== M/11.8.800.175 2013-10-11+00-55-09.438 ========
                =X====== M/11.8.800.175 2013-10-11+00-55-09.454 ========
                =O====== M/11.8.800.175 2013-10-11+00-55-07.364 ========
                0000 [I] 00000010 "C:\Users\nellem\AppData\Local\Temp\InstallAX_11_8_800_175.exe" -install -msi
                0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0006 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
                0007 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
                0008 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
                0011 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0012 [I] 00000012
                =X====== M/11.8.800.175 2013-10-11+00-55-16.505 ========
                2013-10-11+0-56-31.537 [error] 1226 1062
                2013-10-11+0-56-33.206 [error] 1226 1062
                2013-10-11+0-56-34.860 [error] 1226 1062
                2013-10-11+0-56-37.761 [error] 1226 1062
                =O====== M/11.8.800.175 2013-10-11+01-00-37.809 ========
                0000 [I] 00000010 "C:\Users\nellem\Downloads\fp_11.8.800.175_archive\fp_11.8.800.175_archive\11_8_r800_175_ debug\flashplayer11_8r800_175_winax_debug.exe"
                0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0003 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
                0004 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
                0005 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
                0006 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                0007 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                0008 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                0009 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                =X====== M/11.8.800.175 2013-10-11+01-00-52.068 ========
                • 6. Re: Flash Player plug in does not install
                  FKMITCHELL Level 1
                  Thank you.  A clean install and permitting Google Chrome to install under the enterprise version of Win 7 32 bit resulted in Google Chrome having the plug-in on this computer but IE does NOT!  On my other computer running Win 7 professional 32 bit, allowing Chrome to install worked and the plug-in for IE also worked.  Both versions of IE are 10, same update (KB2879017).  I presume this is really a Microsoft problem?
                  • 7. Re: Flash Player plug in does not install
                    Mike M Level 6
                    Chrome uses its own proprietary Flash Player Plugin ("PepperFlash"). It doesn't update through Adobe but rather through updating Chrome.
                    IE uses the ActiveX plugin here: Flash Player for ActiveX (Internet Explorer)
                    IF necessary, you can download and run the uninstaller  to remove any other Flash Player plugins beforehand.
