35 Replies Latest reply on Jul 28, 2018 10:27 PM by the zen temple
    Can't use 3D in Photoshop CC
    John@firelands Level 1
      I've been trying to use 3D in Photoshop with either a Smart object or text converted to a shape but the 3D options are all grey'd out. Is there a preference I don't have setup properly? My computer is a MacBook Pro w/Retina display and 16gb of ram.
        • 1. Re: Can't use 3D in Photoshop CC
          SG... Adobe Employee
          Make sure your document is RGB color. You'll also need to make sure the GPU option is enabled for the document.
          regards,
          steve
          4 people found this helpful
          • 2. Re: Can't use 3D in Photoshop CC
            devthegawd Level 1
            what if this did not work?
            • 3. Re: Can't use 3D in Photoshop CC
              davescm Adobe Community Professional
              Go to Help > System info and click copy. Then paste the info into this thread and we may be able to see what is preventing you accessing 3D
              Dave
              • 4. Re: Can't use 3D in Photoshop CC
                devthegawd Level 1
                Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
                Number of Launches: 24
                Operating System: Mac OS 10.12.6
                System architecture: Intel CPU Family:6, Model:69, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                Physical processor count: 2
                Logical processor count: 4
                Processor speed: 2600 MHz
                Built-in memory: 8192 MB
                Free memory: 4336 MB
                Memory available to Photoshop: 6453 MB
                Memory used by Photoshop: 70 %
                History Thumbnails: Enabled.
                Touch Bar: Enabled.
                Alias Layers: Disabled.
                Modifier Palette: Disabled.
                Highbeam: Enabled.
                Image tile size: 128K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                OpenCL crashed on 8/24/17 at 8:33:19 PM (Initializing OpenCL and OpenCL enabled features)
                Display: 1
                Main Display
                High DPI Monitor
                Display Bounds: top=0, left=0, bottom=800, right=1280
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                NumNativeGPUs=1
                glgpu[0].GLVersion="2.1"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=1536
                glgpu[0].GLName="Intel Iris OpenGL Engine"
                glgpu[0].GLVendor="Intel Inc."
                glgpu[0].GLVendorID=32902
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="Intel Iris OpenGL Engine"
                glgpu[0].GLRendererID=16925953
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.2 (Nov 13 2017 23:06:50)"
                clgpu[0].CLDeviceVersion="1.2 "
                clgpu[0].IsIntegratedCLGPU=1
                clgpu[0].CLMemoryMB=1536
                clgpu[0].CLName="Iris"
                clgpu[0].CLVendor="Intel"
                clgpu[0].CLVendorID=16925952
                clgpu[0].CLDriverVersion="1.2(Jan 11 2018 23:57:57)"
                clgpu[0].CLBandwidth=1.43215e+10
                clgpu[0].CLCompute=182.347
                nativegpu[0].NativeName="Intel Iris Graphics"
                License Type: Perpetual
                Serial number: 91199702356201079674
                GUIDBucket:
                  bucket: 185
                  test: DocumentPanel
                Application folder: /Applications/Adobe Photoshop CC 2017/
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 111.9G, 8.65G free
                Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/
                Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
                Installed components:
                   AdbePM.framework   AdbePM   2.5.00.377243   1.578146
                   adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
                   AdobeACE.framework   AdobeACE   2.20.02.37848   79.579975
                   AdobeAGM.framework   AdobeAGM   4.30.87.37848   79.579975
                   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                   AdobeBIB.framework   AdobeBIB   1.2.03.37848   79.579975
                   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.579975
                   AdobeCoolType.framework   AdobeCoolType   5.15.00.37848   79.579975
                   AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
                   AdobeExtendScript.framework   AdobeExtendScript   4.5.6.5   80.1089815
                   AdobeJP2K.framework   AdobeJP2K   1.2.2.38234   79.266006
                   AdobeLinguistic.framework      22175
                   AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
                   AdobeOwl.framework   AdobeOwl   5.2.11
                   AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
                   AdobePDFSettings.framework   AdobePDFSettings   1.4
                   AdobePIP.framework   AdobePIP   7.4.1.60.45263
                   AdobeScCore.framework   AdobeScCore   4.5.6.5   80.1089815
                   AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.37848   79.579975
                   AdobeSVGRE.framework   AdobeSVGRE   6.0   79.579975
                   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                   AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
                   AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
                   AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
                   ahclient.framework   ahclient   2.2.0.1
                   AIDE.framework   AIDE   1.5.0.36540   79.574279
                   aif.framework   aif   6.0.00.1   1.
                   amtlib.framework   amtlib   10.0.0.47
                   boost_date_time.framework   boost_date_time   10.0.0.0
                   boost_filesystem.framework   boost_filesystem   10.0.0.0
                   boost_signals.framework   boost_signals   10.0.0.0
                   boost_system.framework   boost_system   10.0.0.0
                   boost_threads.framework   boost_threads   10.0.0.0
                   Cg.framework   NVIDIA Cg
                   CITThreading.framework
                   dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
                   dvacore.framework   dvacore   10.0.0.0
                   dvamarshal.framework   dvamarshal   10.0.0.0
                   dvamediatypes.framework   dvamediatypes   10.0.0.0
                   dvametadata.framework   dvametadata   10.0.0.0
                   dvametadataapi.framework   dvametadataapi   10.0.0.0
                   dvametadataUI.framework   dvametadataUI   10.0.0.0
                   dvaplayer.framework   dvaplayer   10.0.0.0
                   dvatransport.framework   dvatransport   10.0.0.0
                   dvaui.framework   dvaui   10.0.0.0
                   dvaunittesting.framework   dvaunittesting   10.0.0.0
                   dynamiclink.framework   dynamiclink   10.0.0.0
                   ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                   ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                   ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                   LogSession.framework   LogSession   7.4.1.60.45263
                   manta.framework   manta   2.0.00.1   1.
                   mediacoreif.framework   mediacoreif   10.0.0.0
                   PlugPlugExternalObject.framework      7.0.0.67
                   PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
                   UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
                   WRServices.framework
                Required plug-ins:
                   3D Studio 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Accented Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Adaptive Wide Angle 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                   Angled Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Average 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
                   Bas Relief 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   BMP 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Camera Raw 9.12 (784), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Camera Raw Filter 9.12 (784), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Chalk & Charcoal 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Chrome 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Cineon 18.1.1  ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
                   Clouds 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Collada DAE 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Color Halftone 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Colored Pencil 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   CompuServe GIF 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Conté Crayon 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Craquelure 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crop and Straighten Photos 18.1.1  Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                   Crop and Straighten Photos Filter 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Crosshatch 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crystallize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Cutout 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Dark Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   De-Interlace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dicom 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
                   Difference Clouds 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Diffuse Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Displace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dry Brush 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Eazel Acquire 18.1.1  Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                   Entropy 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Export Color Lookup Tables 18.1.1  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                   Extrude 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   FastCore Routines 18.1.1  ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
                   Fibers 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Film Grain 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Filter Gallery 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Flash 3D 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Fresco 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glowing Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Google Earth 4 KMZ 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Graphic Pen 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Halftone Pattern 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   HDRMergeUI 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                   HSB/HSL 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   IFF Format 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   IGES 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Ink Outlines 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   JPEG 2000 18.1.1  Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                   Kurtosis 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Lens Blur 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                   Lens Correction 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                   Lens Flare 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Liquify 18.1.1, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
                   Matlab Operation 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Maximum 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mean 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Measurement Core 18.1.1  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                   Median 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mezzotint 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Minimum 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   MMXCore Routines 18.1.1  ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                   Mosaic Tiles 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Multiprocessor Support 18.1.1  Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                   Neon Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Note Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   NTSC Colors 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                   Ocean Ripple 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   OpenEXR 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Paint Daubs 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Palette Knife 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Patchwork 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Paths to Illustrator 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   PCX 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
                   Photocopy 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Photoshop 3D Engine 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                   Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
                   Picture Package Filter 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Pinch 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pixar 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
                   Plaster 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Plastic Wrap 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PLY 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   PNG 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pointillize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Polar Coordinates 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Portable Bit Map 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
                   Poster Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PRC 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Radial Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Radiance 18.1.1  ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
                   Range 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Render Color Lookup Grid 18.1.1  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                   Reticulation 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Ripple 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Rough Pastels 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Save for Web 18.1.1, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                   ScriptingSupport 18.1.1, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                   Shake Reduction 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                   Shear 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Skewness 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Smart Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Smudge Stick 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Solarize 18.1.1  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
                   Spaces 18.1.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
                   Spatter 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Spherize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Sponge 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Sprayed Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stained Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stamp 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Standard Deviation 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   STL 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Sumi-e 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Summation 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Targa 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Texturizer 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Tiles 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Torn Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Twirl 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   U3D 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Underpainting 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Vanishing Point 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                   Variance 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Virtual Reality Modeling Language | VRML 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Water Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Watercolor 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Wave 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wavefront|OBJ 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Wind 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wireless Bitmap 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
                   ZigZag 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                Optional and third party plug-ins: NONE
                Duplicate and Disabled plug-ins: NONE
                Plug-ins that failed to load: NONE
                Extensions:
                   com.adobe.inapp.purchase  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
                   Libraries  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
                   New Document  2.0.1 - from the file “/Users/dev/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
                   Start  2.0.1 - from the file “/Users/dev/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
                   com.adobe.experimentation.extension  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
                   Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
                   Export As  3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
                   Device Preview  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
                   com.adobe.preview.loader  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
                Installed TWAIN devices: NONE
                • 5. Re: Can't use 3D in Photoshop CC
                  Hi
                  3D is not working for you because you are not using a genuine copy of Photoshop. Adobe have never sold a Perpetual Licence for Photoshop CC.
                  The hackers who crack these things often break functionality such as 3D and are also known for slipping other unwanted malware into the installation.
                  I cannot help you further.
                  Dave
                  • 6. Re: Can't use 3D in Photoshop CC
                    Jonboy1949 Level 1
                    I am also having problems with the 3D functions not working, they are grayed out in Photoshop CC 2018 9subscription). I also have CC 2015 and CC2015.5 and all three the 3D options are grayed out and not working. The odd thing is I remember using the 3D functions sometime last year, I'm not a heavy user I only use the 3d function to extrude text, however, I have a project to do and none of the three photoshop applications will allow me to use the 3D options.
                    System Info:
                    Adobe Photoshop Version: 19.1.2 20180302.r.277 2018/03/02: 1160083  x64
                    Number of Launches: 21
                    Operating System: Windows 7 64-bit
                    Version: 7 SP1 6.1.7601.24059
                    System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
                    Physical processor count: 4
                    Logical processor count: 8
                    Processor speed: 3392 MHz
                    Built-in memory: 16366 MB
                    Free memory: 2 MB
                    Memory available to Photoshop: 14546 MB
                    Memory used by Photoshop: 75 %
                    Highbeam: Enabled.
                    Image tile size: 1028K
                    Image cache levels: 6
                    TextComposer: Latin
                    Display: 1
                    Display Bounds: top=0, left=0, bottom=1050, right=1680
                    Display: 2
                    Display Bounds: top=0, left=1680, bottom=1050, right=3360
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=1
                    NumNativeGPUs=0
                    glgpu[0].GLVersion="4.1"
                    glgpu[0].GLMemoryMB=1024
                    glgpu[0].GLName="NVIDIA GeForce GTX 550 Ti"
                    glgpu[0].GLVendor="NVIDIA Corporation"
                    glgpu[0].GLVendorID=4318
                    glgpu[0].GLDriverVersion="23.21.13.9135"
                    glgpu[0].GLRenderer="GeForce GTX 550 Ti/PCIe/SSE2"
                    glgpu[0].GLRendererID=4676
                    glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                    glgpu[0].GLDriverDate="20180323000000.000000-000"
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                    clgpu[0].CLPlatformVersion="1.2"
                    clgpu[0].CLDeviceVersion="1.1 CUDA"
                    clgpu[0].IsIntegratedCLGPU=0
                    clgpu[0].CLMemoryMB=1024
                    clgpu[0].CLName="GeForce GTX 550 Ti"
                    clgpu[0].CLVendor="NVIDIA Corporation"
                    clgpu[0].CLVendorID=4318
                    clgpu[0].CLDriverVersion="391.35"
                    clgpu[0].CLBandwidth=7.6905e+10
                    clgpu[0].CLCompute=209.245
                    License Type: Subscription
                    Serial number: 96040207515759976303
                    GUIDBucket:
                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                    Temporary file path: C:\Users\User\AppData\Local\Temp\
                    Scratch volume(s):
                      L:\, 3.64T, 13.3G free
                      K:\, 931.5G, 528.8G free
                      J:\, 931.5G, 50.4G free
                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
                       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                       ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
                       AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                       AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                       AdobeOwl.dll   Adobe Owl   5.2.11
                       AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
                       AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
                       AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
                       AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                       AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
                       AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
                       adobe_caps.dll   Adobe CAPS   10,0,0,6
                       AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
                       ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                       AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                       amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                       ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
                       AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                       AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                       Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
                       BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
                       boost_date_time.dll   photoshopdva   11.1.0
                       boost_filesystem.dll   photoshopdva   11.1.0
                       boost_signals.dll   photoshopdva   11.1.0
                       boost_system.dll   photoshopdva   11.1.0
                       boost_threads.dll   photoshopdva   11.1.0
                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                       CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                       CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
                       CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
                       dnssd.dll   Bonjour   3,0,0,2
                       dvaaudiodevice.dll   photoshopdva   11.1.0
                       dvacore.dll   photoshopdva   11.1.0
                       dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                       dvamarshal.dll   photoshopdva   11.1.0
                       dvamediatypes.dll   photoshopdva   11.1.0
                       dvametadata.dll   photoshopdva   11.1.0
                       dvametadataapi.dll   photoshopdva   11.1.0
                       dvametadataui.dll   photoshopdva   11.1.0
                       dvaplayer.dll   photoshopdva   11.1.0
                       dvatransport.dll   photoshopdva   11.1.0
                       dvaui.dll   photoshopdva   11.1.0
                       dvaunittesting.dll   photoshopdva   11.1.0
                       dynamiclink.dll   photoshopdva   11.1.0
                       ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
                       icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       igestep30.dll   IGES Reader   9.3.0.113
                       imslib.dll   IMSLib DLL   10.0.0.22
                       JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                       libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                       libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                       LogSession.dll   LogSession   7.4.1.109.46827
                       mediacoreif.dll   photoshopdva   11.1.0
                       MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
                       pdfsettings.dll   Adobe PDFSettings   1.04
                       Photoshop.dll   Adobe Photoshop CC 2018   19.1.2
                       Plugin.dll   Adobe Photoshop CC 2018   19.1.2
                       PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
                       PSArt.dll   Adobe Photoshop CC 2018   19.1.2
                       PSCloud.dll                                                   1.0.0.1
                       PSViews.dll   Adobe Photoshop CC 2018   19.1.2
                       SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
                       SVGRE.dll   SVGRE   79.586793   79.586793
                       svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                       tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                       TfFontMgr.dll   FontMgr   9.3.0.113
                       TfKernel.dll   Kernel   9.3.0.113
                       TFKGEOM.dll   Kernel Geom   9.3.0.113
                       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                       updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                       VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                       VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                       WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
                       WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
                       wu3d.dll   U3D Writer   9.3.0.113
                    Required plug-ins:
                       3D Studio 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Accented Edges 19.1.2 - from the file “Filter Gallery.8bf”
                       Adaptive Wide Angle 19.1.2 - from the file “Adaptive Wide Angle.8bf”
                       Angled Strokes 19.1.2 - from the file “Filter Gallery.8bf”
                       Average 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Average.8bf”
                       Bas Relief 19.1.2 - from the file “Filter Gallery.8bf”
                       BMP 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Camera Raw 10.2 - from the file “Camera Raw.8bi”
                       Camera Raw Filter 10.2 - from the file “Camera Raw.8bi”
                       Chalk && Charcoal 19.1.2 - from the file “Filter Gallery.8bf”
                       Chrome 19.1.2 - from the file “Filter Gallery.8bf”
                       Cineon 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Cineon.8bi”
                       Clouds 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Clouds.8bf”
                       Collada 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Color Halftone 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Colored Pencil 19.1.2 - from the file “Filter Gallery.8bf”
                       CompuServe GIF 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Conté Crayon 19.1.2 - from the file “Filter Gallery.8bf”
                       Craquelure 19.1.2 - from the file “Filter Gallery.8bf”
                       Crop and Straighten Photos 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “CropPhotosAuto.8li”
                       Crop and Straighten Photos Filter 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Crosshatch 19.1.2 - from the file “Filter Gallery.8bf”
                       Crystallize 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Cutout 19.1.2 - from the file “Filter Gallery.8bf”
                       Dark Strokes 19.1.2 - from the file “Filter Gallery.8bf”
                       De-Interlace 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Dicom 19.1.2 - from the file “Dicom.8bi”
                       Difference Clouds 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Clouds.8bf”
                       Diffuse Glow 19.1.2 - from the file “Filter Gallery.8bf”
                       Displace 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Dry Brush 19.1.2 - from the file “Filter Gallery.8bf”
                       Eazel Acquire 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “EazelAcquire.8ba”
                       Entropy 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Export Color Lookup Tables 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Export3DLUT.8be”
                       Extrude 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       FastCore Routines 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “FastCore.8bx”
                       Fibers 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Film Grain 19.1.2 - from the file “Filter Gallery.8bf”
                       Filter Gallery 19.1.2 - from the file “Filter Gallery.8bf”
                       Flash 3D 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Fresco 19.1.2 - from the file “Filter Gallery.8bf”
                       Glass 19.1.2 - from the file “Filter Gallery.8bf”
                       Glowing Edges 19.1.2 - from the file “Filter Gallery.8bf”
                       Google Earth 4 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Graphic Pen 19.1.2 - from the file “Filter Gallery.8bf”
                       Halftone Pattern 19.1.2 - from the file “Filter Gallery.8bf”
                       Halide Bottlenecks 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “HalideBottlenecks.8bx”
                       HDRMergeUI 19.1.2 - from the file “HDRMergeUI.8bf”
                       HSB/HSL 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       IFF Format 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       IGES 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Ink Outlines 19.1.2 - from the file “Filter Gallery.8bf”
                       JPEG 2000 19.1.2 - from the file “JPEG2000.8bi”
                       Kurtosis 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Lens Blur 19.1.2 - from the file “Lens Blur.8bf”
                       Lens Correction 19.1.2 - from the file “Lens Correction.8bf”
                       Lens Flare 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Liquify 19.1.2 - from the file “Liquify.8bf”
                       Matlab Operation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “ChannelPort.8bf”
                       Maximum 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Mean 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Measurement Core 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MeasurementCore.8me”
                       Median 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Mezzotint 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Minimum 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       MMXCore Routines 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MMXCore.8bx”
                       Mosaic Tiles 19.1.2 - from the file “Filter Gallery.8bf”
                       Multiprocessor Support 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MultiProcessor Support.8bx”
                       Neon Glow 19.1.2 - from the file “Filter Gallery.8bf”
                       Note Paper 19.1.2 - from the file “Filter Gallery.8bf”
                       NTSC Colors 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “NTSC Colors.8bf”
                       Ocean Ripple 19.1.2 - from the file “Filter Gallery.8bf”
                       ON1 Develop 2017 11.6.0 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Develop 2017 Filter 11.6.0 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Develop 2018 12.1.1.0 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Develop 2018 Filter 12.1.1.0 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Effects 10 10.5.1 - from the file “PerfectEffects.8li”
                       ON1 Effects 10 Filter 10.5.1 - from the file “PerfectEffects.8li”
                       ON1 Effects 2017 11.6.0 - from the file “PerfectEffects.8li”
                       ON1 Effects 2017 Filter 11.6.0 - from the file “PerfectEffects.8li”
                       ON1 Effects 2018 12.1.1.0 - from the file “PerfectEffects.8li”
                       ON1 Effects 2018 Filter 12.1.1.0 - from the file “PerfectEffects.8li”
                       ON1 Enhance 10 10.5.1 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Enhance 10 Filter 10.5.1 - from the file “PerfectEnhanceProxy.8li”
                       ON1 Portrait 10 10.5.1 - from the file “PerfectPortraitProxy.8li”
                       ON1 Portrait 10 Filter 10.5.1 - from the file “PerfectPortraitProxy.8li”
                       ON1 Resize 10 10.5.1 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 10 Engine Automation 10.5.1 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 10 Engine Filter 10.5.1 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 10 Filter 10.5.1 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2017 11.6.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2017 Engine Automation 11.6.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2017 Engine Filter 11.6.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2017 Filter 11.6.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2018 12.1.1.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2018 Engine Automation 12.1.1.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2018 Engine Filter 12.1.1.0 - from the file “PerfectResizeProxy.8li”
                       ON1 Resize 2018 Filter 12.1.1.0 - from the file “PerfectResizeProxy.8li”
                       OpenEXR 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Paint Daubs 19.1.2 - from the file “Filter Gallery.8bf”
                       Palette Knife 19.1.2 - from the file “Filter Gallery.8bf”
                       Patchwork 19.1.2 - from the file “Filter Gallery.8bf”
                       Paths to Illustrator 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       PCX 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “PCX.8bi”
                       Photocopy 19.1.2 - from the file “Filter Gallery.8bf”
                       Photoshop 3D Engine 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Photoshop3DEngine.8bi”
                       Photoshop Touch 19.0 - from the file “PSDX.8bi”
                       Picture Package Filter 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “ChannelPort.8bf”
                       Pinch 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Pixar 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Pixar.8bi”
                       Plaster 19.1.2 - from the file “Filter Gallery.8bf”
                       Plastic Wrap 19.1.2 - from the file “Filter Gallery.8bf”
                       PLY 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Pointillize 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Polar Coordinates 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Portable Bit Map 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “PBM.8bi”
                       Poster Edges 19.1.2 - from the file “Filter Gallery.8bf”
                       PRC 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Radial Blur 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Radiance 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Radiance.8bi”
                       Range 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Render Color Lookup Grid 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Export3DLUT.8be”
                       Reticulation 19.1.2 - from the file “Filter Gallery.8bf”
                       Ripple 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Rough Pastels 19.1.2 - from the file “Filter Gallery.8bf”
                       Save for Web 19.1.2 - from the file “Save for Web.8be”
                       ScriptingSupport 19.1.2 - from the file “ScriptingSupport.8li”
                       Shake Reduction 19.1.2 - from the file “Shake Reduction.8bf”
                       Shear 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Skewness 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Smart Blur 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Smudge Stick 19.1.2 - from the file “Filter Gallery.8bf”
                       Solarize 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Solarize.8bf”
                       Spaces 19.1.2 - from the file “Spaces.8li”
                       Spatter 19.1.2 - from the file “Filter Gallery.8bf”
                       Spherize 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Sponge 19.1.2 - from the file “Filter Gallery.8bf”
                       Sprayed Strokes 19.1.2 - from the file “Filter Gallery.8bf”
                       Stained Glass 19.1.2 - from the file “Filter Gallery.8bf”
                       Stamp 19.1.2 - from the file “Filter Gallery.8bf”
                       Standard Deviation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       STL 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Sumi-e 19.1.2 - from the file “Filter Gallery.8bf”
                       Summation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Targa 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Texturizer 19.1.2 - from the file “Filter Gallery.8bf”
                       Tiles 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Torn Edges 19.1.2 - from the file “Filter Gallery.8bf”
                       Twirl 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       U3D 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       Underpainting 19.1.2 - from the file “Filter Gallery.8bf”
                       Vanishing Point 19.1.2 - from the file “VanishingPoint.8bf”
                       Variance 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
                       Virtual Reality Modeling Language | VRML 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       VueScan 1.0.00 - from the file “VueScan.8ba”
                       Water Paper 19.1.2 - from the file “Filter Gallery.8bf”
                       Watercolor 19.1.2 - from the file “Filter Gallery.8bf”
                       Wave 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Wavefront|OBJ 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
                       WIA Support 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “WIASupport.8li”
                       Wind 19.1.2 - from the file “Standard MultiPlugin.8bf”
                       Wireless Bitmap 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “WBMP.8bi”
                       ZigZag 19.1.2 - from the file “Standard MultiPlugin.8bf”
                    Extensions:
                       com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                       com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                       Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                       New Document  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
                       Start  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
                       Pexels  1.0.0 - from the file “C:\Users\User\AppData\Roaming\Adobe\CEP\extensions\com.pexels\index.html”
                       ON1  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\onOne\index.html”
                       Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                       Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                       Adobe Paper Texture Pro  3.1.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.AdobePaperTexturePro\index.html”
                    Thanks for the help, getting to the bottom of this and why the 3D is grayed out?
                    • 7. Re: Can't use 3D in Photoshop CC
                      DaveMez Level 1
                      I am also having problems, cannot edit a PS 3D file I made a little while back.  Need a solution, fast!   Also the graphics processor options in preferences is grayed out as well!  says 'unable to detect information'
                      ..OK, I FOUND THE SOLUTION FOR ME.
                      1. Check system preferences, CUDA driver needed an update.
                      2. Enable OpenGL under performance settings in Ps.
                      3. Adjust available RAM as needed under 3D preferences in Ps.
                      I am now able to update the Illustration.
                      From a user perspective, it would be great if Ps would put up an error stating that OpenGL is not available when trying to edit existing or create new 3D.
                      Thanks!
                      • 8. Re: Can't use 3D in Photoshop CC
                        Jonboy,
                        Your system info look Ok. Is your document in RGB mode? It needs to be for 3D.
                        Dave
                        • 9. Re: Can't use 3D in Photoshop CC
                          limz97363343 Level 1
                          how about me, can u help see what is the problem ? thank you
                          Adobe Photoshop Version: 2017.1.3 20180103.r.26 2018/01/03: 1151628  x64
                          Number of Launches: 78
                          Operating System: Mac OS 10.13.4
                          Free memory: 2138 MB
                          Memory available to Photoshop: 6574 MB
                          Touch Bar: Enabled.
                          Highbeam: Enabled.
                          TextComposer: Latin
                          OpenCL crashed on 11/07/2017 at 8:57:08 PM (Initializing OpenCL and OpenCL enabled features)
                          Display: 1
                          Main Display
                          High DPI Monitor
                          AIFOGLInitialized=1
                          OGLContextCreated=1
                          NumGLGPUs=1
                          NumCLGPUs=1
                          NumNativeGPUs=1
                          clgpu[0].CLPlatformVersion="1.2 (Mar 15 2018 21:59:37)"
                          clgpu[0].CLDriverVersion="1.2(Mar 15 2018 22:04:19)"
                          clgpu[0].CLBandwidth=1.45349e+10
                          clgpu[0].CLCompute=165.368
                          Serial number: 90970984274750166816
                          GUIDBucket:
                            bucket: 231
                            test: DocumentPanel
                          Scratch volume(s):
                            Startup, 112.8G, 50.4G free
                          Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-Ins/
                             AdobeSVGRE.framework   AdobeSVGRE   6.0   88.588432
                             AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.39544   88.588432
                             amtlib.framework   amtlib   10.0.0.119
                          Required plug-ins:
                             3D Studio 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Accented Edges 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Adaptive Wide Angle 18.1.3, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                             Angled Strokes 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Average 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
                             Bas Relief 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             BMP 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Camera Raw 10.3 (933), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                             Camera Raw Filter 10.3 (933), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                             Chalk & Charcoal 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Chrome 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Cineon 18.1.3  ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
                             Clouds 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Collada DAE 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Color Halftone 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Colored Pencil 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             CompuServe GIF 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Conté Crayon 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Craquelure 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crop and Straighten Photos 18.1.3  Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                             Crop and Straighten Photos Filter 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Crosshatch 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crystallize 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Cutout 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Dark Strokes 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             De-Interlace 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Dicom 18.1.3, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
                             Difference Clouds 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Diffuse Glow 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Displace 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Dry Brush 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Eazel Acquire 18.1.3  Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                             Entropy 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Export Color Lookup Tables 18.1.3  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                             Extrude 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             FastCore Routines 18.1.3  ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
                             Fibers 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Film Grain 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Filter Gallery 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Flash 3D 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Fresco 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glass 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glowing Edges 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Google Earth 4 KMZ 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Graphic Pen 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Halftone Pattern 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             HDRMergeUI 18.1.3, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                             HSB/HSL 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             IFF Format 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             IGES 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Ink Outlines 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             JPEG 2000 18.1.3  Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                             Kurtosis 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Lens Blur 18.1.3, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                             Lens Correction 18.1.3, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                             Lens Flare 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Liquify 18.1.3, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
                             Matlab Operation 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Maximum 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Mean 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Measurement Core 18.1.3  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                             Median 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Mezzotint 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Minimum 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             MMXCore Routines 18.1.3  ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                             Mosaic Tiles 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Multiprocessor Support 18.1.3  Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                             Neon Glow 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Note Paper 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             NTSC Colors 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                             Ocean Ripple 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             OpenEXR 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Paint Daubs 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Palette Knife 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Patchwork 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Paths to Illustrator 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             PCX 18.1.3  ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
                             Photocopy 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Photoshop 3D Engine 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                             Picture Package Filter 18.1.3  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Pinch 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pixar 18.1.3  ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
                             Plaster 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Plastic Wrap 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             PLY 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             PNG 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pointillize 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Polar Coordinates 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Portable Bit Map 18.1.3  ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
                             Poster Edges 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             PRC 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Radial Blur 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Radiance 18.1.3  ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
                             Range 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Render Color Lookup Grid 18.1.3  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                             Reticulation 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Ripple 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Rough Pastels 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Save for Web 18.1.3, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                             ScriptingSupport 18.1.3, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                             Shake Reduction 18.1.3, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                             Shear 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Skewness 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Smart Blur 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Smudge Stick 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Solarize 18.1.3  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
                             Spaces 18.1.3, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
                             Spatter 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Spherize 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Sponge 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Sprayed Strokes 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stained Glass 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stamp 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Standard Deviation 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             STL 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Sumi-e 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Summation 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Targa 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Texturizer 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Tiles 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Torn Edges 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Twirl 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             U3D 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Underpainting 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Vanishing Point 18.1.3, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                             Variance 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Virtual Reality Modeling Language | VRML 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Water Paper 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Watercolor 18.1.3, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Wave 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wavefront|OBJ 18.1.3  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Wind 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wireless Bitmap 18.1.3  ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
                             ZigZag 18.1.3, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                          Extensions:
                             New Document  2.0.1 - from the file “/Users/macbook/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
                             Start  2.0.1 - from the file “/Users/macbook/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
                             PixelSquid  0.7.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.pixelsquid.heroplayer/index.html”
                          • 10. Re: Can't use 3D in Photoshop CC
                            DugzPhotos Level 1
                            Me too
                            Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750  x64
                            Number of Launches: 45
                            Operating System: Windows 10 64-bit
                            Version: 10 or greater 10.0.16299.15
                            System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
                            Processor speed: 3193 MHz
                            Built-in memory: 8162 MB
                            Free memory: 870 MB
                            Memory available to Photoshop: 6928 MB
                            Modifier Palette: Enabled.
                            Highbeam: Enabled.
                            Image tile size: 1024K
                            TextComposer: Latin
                            Display: 1
                            Display Bounds: top=0, left=0, bottom=1200, right=1920
                            AIFOGLInitialized=1
                            OGLContextCreated=1
                            NumGLGPUs=1
                            NumCLGPUs=1
                            NumNativeGPUs=0
                            glgpu[0].GLMemoryMB=2048
                            glgpu[0].GLName="AMD Radeon R7 200 Series"
                            glgpu[0].GLVendor="ATI Technologies Inc."
                            glgpu[0].GLVendorID=4098
                            glgpu[0].GLDriverVersion="23.20.15007.1005"
                            glgpu[0].GLRenderer="AMD Radeon R7 200 Series"
                            glgpu[0].GLRendererID=26131
                            glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\c0322096.inf_amd64_7ff7d 53c3793b9e4\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0322096.inf_amd64 _7ff7d53c3793b9e4\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0322096.inf _amd64_7ff7d53c3793b9e4\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c03220 96.inf_amd64_7ff7d53c3793b9e4\amdxc64.dll"
                            glgpu[0].GLDriverDate="20171217000000.000000-000"
                            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50"
                            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[2147 483647]
                            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[160]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
                            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
                            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
                            clgpu[0].CLPlatformVersion="2.1 AMD-APP (2527.7)"
                            clgpu[0].CLDeviceVersion="1.2 AMD-APP (2527.7)"
                            clgpu[0].CLMemoryMB=2048
                            clgpu[0].CLName="Oland"
                            clgpu[0].CLVendor="Advanced Micro Devices, Inc."
                            clgpu[0].CLVendorID=4098
                            clgpu[0].CLDriverVersion="2527.7"
                            clgpu[0].CLBandwidth=2.45135e+10
                            clgpu[0].CLCompute=231.414
                            Serial number: 96040079152525663103
                            GUIDBucket:
                            Temporary file path: C:\Users\Doug\AppData\Local\Temp\
                            Scratch volume(s):
                              Startup, 464.8G, 305.0G free
                               Photoshop.dll   Adobe Photoshop CC 2018   19.1.4
                               Plugin.dll   Adobe Photoshop CC 2018   19.1.4
                               PSArt.dll   Adobe Photoshop CC 2018   19.1.4
                               PSCloud.dll                                                   1.0.0.1
                               PSViews.dll   Adobe Photoshop CC 2018   19.1.4
                            Required plug-ins:
                               3D Studio 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Accented Edges 19.1.4 - from the file “Filter Gallery.8bf”
                               Adaptive Wide Angle 19.1.4 - from the file “Adaptive Wide Angle.8bf”
                               Angled Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                               Average 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Average.8bf”
                               Bas Relief 19.1.4 - from the file “Filter Gallery.8bf”
                               BMP 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Camera Raw 10.3 - from the file “Camera Raw.8bi”
                               Camera Raw Filter 10.3 - from the file “Camera Raw.8bi”
                               Chalk && Charcoal 19.1.4 - from the file “Filter Gallery.8bf”
                               Chrome 19.1.4 - from the file “Filter Gallery.8bf”
                               Cineon 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Cineon.8bi”
                               Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
                               Collada 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Color Halftone 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Colored Pencil 19.1.4 - from the file “Filter Gallery.8bf”
                               CompuServe GIF 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Conté Crayon 19.1.4 - from the file “Filter Gallery.8bf”
                               Craquelure 19.1.4 - from the file “Filter Gallery.8bf”
                               Crop and Straighten Photos 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “CropPhotosAuto.8li”
                               Crop and Straighten Photos Filter 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Crosshatch 19.1.4 - from the file “Filter Gallery.8bf”
                               Crystallize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Cutout 19.1.4 - from the file “Filter Gallery.8bf”
                               Dark Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                               De-Interlace 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Dicom 19.1.4 - from the file “Dicom.8bi”
                               Difference Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
                               Diffuse Glow 19.1.4 - from the file “Filter Gallery.8bf”
                               Displace 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Dry Brush 19.1.4 - from the file “Filter Gallery.8bf”
                               Eazel Acquire 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “EazelAcquire.8ba”
                               Entropy 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Export Color Lookup Tables 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
                               Extrude 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               FastCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “FastCore.8bx”
                               Fibers 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Film Grain 19.1.4 - from the file “Filter Gallery.8bf”
                               Filter Gallery 19.1.4 - from the file “Filter Gallery.8bf”
                               Flash 3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Fresco 19.1.4 - from the file “Filter Gallery.8bf”
                               Glass 19.1.4 - from the file “Filter Gallery.8bf”
                               Glowing Edges 19.1.4 - from the file “Filter Gallery.8bf”
                               Google Earth 4 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Graphic Pen 19.1.4 - from the file “Filter Gallery.8bf”
                               Halftone Pattern 19.1.4 - from the file “Filter Gallery.8bf”
                               Halide Bottlenecks 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “HalideBottlenecks.8bx”
                               HDRMergeUI 19.1.4 - from the file “HDRMergeUI.8bf”
                               HSB/HSL 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               IFF Format 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               IGES 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Ink Outlines 19.1.4 - from the file “Filter Gallery.8bf”
                               JPEG 2000 19.1.4 - from the file “JPEG2000.8bi”
                               Kurtosis 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Lens Blur 19.1.4 - from the file “Lens Blur.8bf”
                               Lens Correction 19.1.4 - from the file “Lens Correction.8bf”
                               Lens Flare 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Liquify 19.1.4 - from the file “Liquify.8bf”
                               Matlab Operation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
                               Maximum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Mean 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Measurement Core 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MeasurementCore.8me”
                               Median 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Mezzotint 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Minimum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               MMXCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MMXCore.8bx”
                               Mosaic Tiles 19.1.4 - from the file “Filter Gallery.8bf”
                               Multiprocessor Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MultiProcessor Support.8bx”
                               Neon Glow 19.1.4 - from the file “Filter Gallery.8bf”
                               Note Paper 19.1.4 - from the file “Filter Gallery.8bf”
                               NTSC Colors 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “NTSC Colors.8bf”
                               Ocean Ripple 19.1.4 - from the file “Filter Gallery.8bf”
                               OpenEXR 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Paint Daubs 19.1.4 - from the file “Filter Gallery.8bf”
                               Palette Knife 19.1.4 - from the file “Filter Gallery.8bf”
                               Patchwork 19.1.4 - from the file “Filter Gallery.8bf”
                               Paths to Illustrator 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               PCX 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PCX.8bi”
                               Photocopy 19.1.4 - from the file “Filter Gallery.8bf”
                               Photoshop 3D Engine 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Photoshop3DEngine.8bi”
                               Picture Package Filter 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
                               Pinch 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Pixar 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Pixar.8bi”
                               Plaster 19.1.4 - from the file “Filter Gallery.8bf”
                               Plastic Wrap 19.1.4 - from the file “Filter Gallery.8bf”
                               PLY 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Pointillize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Polar Coordinates 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Portable Bit Map 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PBM.8bi”
                               Poster Edges 19.1.4 - from the file “Filter Gallery.8bf”
                               PRC 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Radial Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Radiance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Radiance.8bi”
                               Range 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Render Color Lookup Grid 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
                               Reticulation 19.1.4 - from the file “Filter Gallery.8bf”
                               Ripple 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Rough Pastels 19.1.4 - from the file “Filter Gallery.8bf”
                               Save for Web 19.1.4 - from the file “Save for Web.8be”
                               ScriptingSupport 19.1.4 - from the file “ScriptingSupport.8li”
                               Shake Reduction 19.1.4 - from the file “Shake Reduction.8bf”
                               Shear 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Skewness 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Smart Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Smudge Stick 19.1.4 - from the file “Filter Gallery.8bf”
                               Solarize 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Solarize.8bf”
                               Spaces 19.1.4 - from the file “Spaces.8li”
                               Spatter 19.1.4 - from the file “Filter Gallery.8bf”
                               Spherize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Sponge 19.1.4 - from the file “Filter Gallery.8bf”
                               Sprayed Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                               Stained Glass 19.1.4 - from the file “Filter Gallery.8bf”
                               Stamp 19.1.4 - from the file “Filter Gallery.8bf”
                               Standard Deviation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               STL 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Sumi-e 19.1.4 - from the file “Filter Gallery.8bf”
                               Summation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Targa 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Texturizer 19.1.4 - from the file “Filter Gallery.8bf”
                               Tiles 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Torn Edges 19.1.4 - from the file “Filter Gallery.8bf”
                               Twirl 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               U3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Underpainting 19.1.4 - from the file “Filter Gallery.8bf”
                               Vanishing Point 19.1.4 - from the file “VanishingPoint.8bf”
                               Variance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                               Virtual Reality Modeling Language | VRML 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               Water Paper 19.1.4 - from the file “Filter Gallery.8bf”
                               Watercolor 19.1.4 - from the file “Filter Gallery.8bf”
                               Wave 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Wavefront|OBJ 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                               WIA Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WIASupport.8li”
                               Wind 19.1.4 - from the file “Standard MultiPlugin.8bf”
                               Wireless Bitmap 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WBMP.8bi”
                               ZigZag 19.1.4 - from the file “Standard MultiPlugin.8bf”
                            Extensions:
                               com.adobe.inapp.purchase  2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseStock.html”
                               Libraries  2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\index.html”
                               New Document  2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
                               com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseTypekit.html”
                               Start  2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
                            • 11. Re: Can't use 3D in Photoshop CC
                              davescm Adobe Community Professional
                              Hi
                              I don't use a Mac so can't do a direct comparison. At first glance system info looks to be OK (open GL enabled, one GPU, sufficient VRAM). Is your document in RGB color mode?
                              Dave
                              • 12. Re: Can't use 3D in Photoshop CC
                                anitab33814388 Level 1
                                Hi, I would appreciate some help on the 3D function as well here is my info:
                                I also included a Snip it of the file name and the 3D window:
                                Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750  x32
                                Number of Launches: 62
                                Operating System: Windows 7 32-bit
                                Version: 7 SP1 6.1.7601.18847
                                System architecture: AMD CPU Family:15, Model:0, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
                                Physical processor count: 1
                                Logical processor count: 2
                                Processor speed: 3393 MHz
                                Built-in memory: 2782 MB
                                Free memory: 234 MB
                                Memory available to Photoshop: 1557 MB
                                Memory used by Photoshop: 70 %
                                Alias Layers: Disabled.
                                Modifier Palette: Disabled.
                                Highbeam: Enabled.
                                Image tile size: 132K
                                Image cache levels: 2
                                Font Preview: Medium
                                TextComposer: Latin
                                Display: 1
                                Display Bounds: top=0, left=0, bottom=768, right=1366
                                OpenGL Drawing: Enabled.
                                OpenGL Allow Old GPUs: Not Detected.
                                OpenGL Drawing Mode: Advanced
                                OpenGL Allow Normal Mode: True.
                                OpenGL Allow Advanced Mode: True.
                                AIFCoreInitialized=1
                                AIFOGLInitialized=1
                                OGLContextCreated=1
                                NumGLGPUs=1
                                NumCLGPUs=1
                                NumNativeGPUs=0
                                glgpu[0].IsIntegratedGLGPU=0
                                glgpu[0].GLMemoryMB=512
                                glgpu[0].GLName="AMD Radeon HD 7480D"
                                glgpu[0].GLDriverVersion="13.152.0.0"
                                glgpu[0].GLRectTextureSize=16384
                                glgpu[0].GLRenderer="AMD Radeon HD 7480D"
                                glgpu[0].GLRendererID=39315
                                glgpu[0].HasGLNPOTSupport=1
                                glgpu[0].GLDriver="aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumd va.cap"
                                glgpu[0].GLDriverDate="20130830000000.000000-000"
                                glgpu[0].CanCompileProgramGLSL=1
                                glgpu[0].GLFrameBufferOK=1
                                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.30"
                                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[32]
                                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                clgpu[0].CLPlatformVersion="1.2 AMD-APP (1268.1)"
                                clgpu[0].CLDeviceVersion="1.2 AMD-APP (1268.1)"
                                clgpu[0].IsIntegratedCLGPU=1
                                clgpu[0].CLMemoryMB=765
                                clgpu[0].CLName="Scrapper"
                                clgpu[0].CLDriverVersion="1268.1 (VM)"
                                clgpu[0].CLBandwidth=0
                                clgpu[0].CLCompute=0
                                Serial number: 90970211517205581189
                                GUIDBucket:
                                Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\
                                Temporary file path: C:\Users\Student\AppData\Local\Temp\
                                Photoshop scratch has async I/O enabled
                                Scratch volume(s):
                                  Startup, 423.1G, 338.1G free
                                Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\Required\Plug-Ins\
                                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\Plug-Ins\
                                Installed components:
                                   amtlib.dll   AMTLib   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (32 bit)   8.5.0
                                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit)   8.5.0.87
                                   PSCloud.dll                                                   1.0.0.1
                                Required plug-ins:
                                Extensions:
                                   com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                                   com.adobe.inapp.purchase  2.13.141 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseStock.html”
                                   New Document  2.2.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
                                   Libraries  2.13.141 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\index.html”
                                   com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseTypekit.html”
                                   Start  2.3.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.3.0\index.html?v=2.3.0.58”
                                   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                                   Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018 (32 Bit)\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                                • 13. Re: Can't use 3D in Photoshop CC
                                  SG... Adobe Employee
                                  Photoshop 3D features is not enabled on Win 32 bit systems. You may also want to update your video card drivers as your current driver is 5 years old.
                                  regards,
                                  steve
                                  • 14. Re: Can't use 3D in Photoshop CC
                                    sankeerths66884888 Level 1
                                    I am also unable to perform 3D clicks in PS cc 2018.
                                    Can anyone please help me it's urgent
                                    • 15. Re: Can't use 3D in Photoshop CC
                                      Ged Traynor Adobe Community Professional
                                      Hi
                                      Can you post your Photoshop system info, go to Help > System Info and copy and paste into this thread
                                      • 16. Re: Can't use 3D in Photoshop CC
                                        Number of Launches: 13
                                        Operating System: Windows 8.1 32-bit
                                        Version: 8.1 6.3.9600.17415
                                        Physical processor count: 2
                                        Logical processor count: 4
                                        Processor speed: 2295 MHz
                                        Built-in memory: 2980 MB
                                        Free memory: 683 MB
                                        Memory available to Photoshop: 1515 MB
                                        Highbeam: Enabled.
                                        Image tile size: 128K
                                        Image cache levels: 4
                                        TextComposer: Latin
                                        OpenCL crashed on 7/1/2018 at 8:07:42 PM (Initializing Shared Sampling OpenCL  feature)
                                        Display: 1
                                        OpenGL Drawing: Disabled.
                                        AIFOGLInitialized=1
                                        OGLContextCreated=1
                                        NumGLGPUs=1
                                        NumNativeGPUs=0
                                        glgpu[0].GLVersion="3.1"
                                        glgpu[0].IsIntegratedGLGPU=1
                                        glgpu[0].GLMemoryMB=1298
                                        glgpu[0].GLName="Intel(R) HD Graphics 3000"
                                        glgpu[0].GLVendor="Intel"
                                        glgpu[0].GLVendorID=32902
                                        glgpu[0].GLDriverVersion="9.17.10.4229"
                                        glgpu[0].GLRectTextureSize=8192
                                        glgpu[0].GLRenderer="Intel(R) HD Graphics 3000"
                                        glgpu[0].GLRendererID=278
                                        glgpu[0].GLDriver="igdumd32.dll,igd10umd32.dll,igd10umd32.dll"
                                        glgpu[0].GLDriverDate="20150528000000.000000-000"
                                        glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Intel Build 9.17.10.4229"
                                        glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
                                        glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
                                        glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
                                        glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
                                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                                        glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
                                        License Type: Tryout Version
                                        Serial number: Tryout Version
                                        GUIDBucket:
                                        Temporary file path: C:\Users\SANKEE~1\AppData\Local\Temp\
                                        Scratch volume(s):
                                          Startup, 190.7G, 137.1G free
                                           PSCloud.dll                                                   1.0.0.1
                                        Required plug-ins:
                                        Extensions:
                                           com.adobe.inapp.purchase  1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseStock.html”
                                           Libraries  1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\index.html”
                                           com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseTypekit.html”
                                           Start  2.2.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
                                        • 17. Re: Can't use 3D in Photoshop CC
                                          Hi
                                          You have a 32 bit operating system and a 32 bit version of Photoshop, the 3D features are not available on the 32 bit version
                                          Photoshop system requirements
                                          • 18. Re: Can't use 3D in Photoshop CC
                                            is there any posibility @Ged Traynor
                                            • 19. Re: Can't use 3D in Photoshop CC
                                              is there any other way
                                              i am running my ps in trial sir and i am unable to download it permanently
                                              • 20. Re: Can't use 3D in Photoshop CC
                                                Only on a 64 bit operating system
                                                Dave
                                                • 21. Re: Can't use 3D in Photoshop CC
                                                  my pc is of windows 8.1 pro and 64 bit ready and intel graphics 3000 and intel 2.30 gHZ processor still i am unable to download it permanently..
                                                  i am able to run in trial but how to download it permanently .
                                                  please help me sir!!!
                                                  • 22. Re: Can't use 3D in Photoshop CC
                                                    only on a 64 os we can download ps permanently and can run 3d files
                                                    • 23. Re: Can't use 3D in Photoshop CC
                                                      What do you mean by "unable to download it permanently"
                                                      If you're running a trial version the version installed should be 19.1.5
                                                      • 24. Re: Can't use 3D in Photoshop CC
                                                        s i am runnint it in trial but i want it for permanently
                                                        is it possible
                                                        • 27. Re: Can't use 3D in Photoshop CC
                                                          adélab23424951 Level 1
                                                          Hello,
                                                          I have the same problem here. Could you please help me too? My system info is:
                                                          Adobe Photoshop verze: 19.1.4 20180507.r.325 2018/05/07: 1170750  x64
                                                          Počet spuštění: 52
                                                          Operační systém: Windows 7 (64bitová verze)
                                                          Verze: 7 SP1 6.1.7601.24117
                                                          Systémová architektura: řada CPU Intel: 6, model: 14, taktování: 10 s MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                                                          Počet fyzických procesorů: 6
                                                          Počet logických procesorů: 12
                                                          Rychlost procesoru: 3192 MHz
                                                          Vestavěná paměť: 16263 MB
                                                          Volná paměť: 11236 MB
                                                          Paměť dostupná pro Photoshop: 14451 MB
                                                          Paměť používaná Photoshopem: 88 %
                                                          Vrstvy aliasů: Vypnuto.
                                                          Paleta modifikátorů: Vypnuto.
                                                          Dálkový paprsek: Zapnuto.
                                                          Velikost vyrovnávací paměti dlaždice: 1024 kB
                                                          Úrovní vyrovnávací paměti pro obrazy: 4
                                                          Náhled písma: Střední
                                                          Algoritmus sazby textu: Latinka
                                                          Zobrazení: 1
                                                          Hranice zobrazení: horní= 0, vlevo= 0, spodní= 1080, vpravo= 1920
                                                          Zobrazení: 2
                                                          Hranice zobrazení: horní= 0, vlevo= 1920, spodní= 1024, vpravo= 3200
                                                          Kreslení OpenGL: Zapnuto.
                                                          OpenGL - povolit staré GPU: Nezjištěno.
                                                          Režim kreslení OpenGL: Další volby
                                                          OpenGL - povolit normální režim: True.
                                                          OpenGL - povolit pokročilý režim: True.
                                                          AIFOGLInitialized=1
                                                          OGLContextCreated=1
                                                          NumGLGPUs=1
                                                          NumNativeGPUs=0
                                                          glgpu[0].GLVersion="3.3"
                                                          glgpu[0].GLMemoryMB=256
                                                          glgpu[0].GLName="ATI Radeon HD 2600 XT"
                                                          glgpu[0].GLDriverVersion="8.970.100.1100"
                                                          glgpu[0].GLRenderer="ATI Radeon HD 2600 XT"
                                                          glgpu[0].GLRendererID=38280
                                                          glgpu[0].GLDriver="aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,a tiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll"
                                                          glgpu[0].GLDriverDate="20130429000000.000000-000"
                                                          glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="3.30"
                                                          Typ licence: Předplatné
                                                          Sériové číslo: 94070056425120653980
                                                          GUIDBucket:
                                                          Složka aplikace: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                                                          Cesta dočasného souboru: C:\Users\ABASNI~1\AppData\Local\Temp\
                                                          Photoshop odkládá s použitím asynchronního I/O zapnuto
                                                          Odkládací disk(y):
                                                              Startovací, 476,8 GB, 302,9 GB volného
                                                          Složka vyžadovaných zásuvných modulů: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
                                                          Primární složka zásuvných modulů: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
                                                          Nainstalované komponenty:
                                                             PSCloud.dll                                                   1.0.0.1
                                                          Vyžadované zásuvné moduly:
                                                             3D Studio 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Adaptivní široký úhel 19.1.4 – ze souboru “Adaptive Wide Angle.8bf”
                                                             Akvarel 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Asymetrie 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Barevné pastelky 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Barevný polotón 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Basreliéf 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             BMP 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Camera Raw 10.3 – ze souboru “Camera Raw.8bi”
                                                             Cesty do Illustratoru 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Chróm 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Cikcak 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Cineon 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Cineon.8bi”
                                                             Collada 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             CompuServe GIF 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Conté pastel 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Dicom 19.1.4 – ze souboru “Dicom.8bi”
                                                             Dlaždice 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Dopisní papír 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Eazel Acquire 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “EazelAcquire.8ba”
                                                             Entropie 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Exportovat vyhledávací tabulky barev 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Export3DLUT.8be”
                                                             FastCore podprogramy 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “FastCore.8bx”
                                                             Filtr Camera Raw 10.3 – ze souboru “Camera Raw.8bi”
                                                             Filtr Oříznout a narovnat fotografie 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Filtr Sada obrazů 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “ChannelPort.8bf”
                                                             Flash 3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Formát IFF 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Fotokopie 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Freska 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Galerie filtrů 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Google Earth 4 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Halide Bottlenecks 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “HalideBottlenecks.8bx”
                                                             HDRMergeUI 19.1.4 – ze souboru “HDRMergeUI.8bf”
                                                             Houba 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Hrubé pastely 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             HSB/HSL 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             IGES 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Inkoustové obrysy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Inteligentní rozostření 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Jádro měření 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “MeasurementCore.8me”
                                                             Jazyk VRML (Virtual Reality Modeling Language) | VRML 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             JPEG 2000 19.1.4 – ze souboru “JPEG2000.8bi”
                                                             Korekce objektivu 19.1.4 – ze souboru “Lens Correction.8bf”
                                                             Křída a uhel 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Kruhové rozostření 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Krystalizace 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Malířská špachtle 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Matlab Operation 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “ChannelPort.8bf”
                                                             Maximum 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Medián 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Mezzotinta 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Minimum 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Míra fluktuace 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             MMXCore podprogramy 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “MMXCore.8bx”
                                                             Modul Photoshop 3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Photoshop3DEngine.8bi”
                                                             Mozaikové dlaždice 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Mozaikové okno 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Multiprocesorová podpora 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “MultiProcessor Support.8bx”
                                                             Nastříkané tahy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Neónová záře 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             NTSC barvy 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “NTSC Colors.8bf”
                                                             Oblaka 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Clouds.8bf”
                                                             Odečíst oblaka 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Clouds.8bf”
                                                             Odlesk objektivu 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Odstranit prokládání 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             OpenEXR 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Oříznout a narovnat fotografie 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “CropPhotosAuto.8li”
                                                             Otisk 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             PCX 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “PCX.8bi”
                                                             Photoshop Touch 19.0 – ze souboru “PSDX.8bi”
                                                             Pixar 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Pixar.8bi”
                                                             Plakátové obrysy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Plastikový obal 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             PLY 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Podmalba 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Podpora skriptování 19.1.4 – ze souboru “ScriptingSupport.8li”
                                                             Podpora WIA 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “WIASupport.8li”
                                                             Pointilizace 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Polární souřadnice 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Polotónový vzorek 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Portable Bit Map 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “PBM.8bi”
                                                             Postřik 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Potrhané obrysy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Praskliny 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             PRC 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Přestavět 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Prohnutí 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Průměr 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Average.8bf”
                                                             Radiance 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Radiance.8bi”
                                                             Redukce chvění 19.1.4 – ze souboru “Shake Reduction.8bf”
                                                             Rozmazání 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Rozostření objektivu 19.1.4 – ze souboru “Lens Blur.8bf”
                                                             Rozptyl 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Rozptýlené světlo 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Rozsah 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Rýsovací pero 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Sádra 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Síťovina 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Sklo 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Slátanina 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Šmouhy barvy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Solarizace 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Solarize.8bf”
                                                             Součet 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Spaces 19.1.4 – ze souboru “Spaces.8li”
                                                             Šrafování 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Standardní odchylka 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             STL 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Stř. hodnota 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “statistics.8ba”
                                                             Střih 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Suchý štětec 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Sumi-e 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Targa 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Texturování 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Tmavé tahy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Tvarování 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             U3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             Úběžný bod 19.1.4 – ze souboru “VanishingPoint.8bf”
                                                             Uhlokresba 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Úhlové tahy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Uložit pro Web 19.1.4 – ze souboru “Save for Web.8be”
                                                             Vítr 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Vlákna 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Vlhký papír 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Vlna 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Vyhledávací mřížka barev pro vykreslování 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “Export3DLUT.8be”
                                                             Vystřižení 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Wavefront|OBJ 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “U3D.8bi”
                                                             WBMP 19.1.4 (20180507.r.325 2018/05/07: 1170750) – ze souboru “WBMP.8bi”
                                                             Zaoblení 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Zářící obrysy 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Zkapalnění 19.1.4 – ze souboru “Liquify.8bf”
                                                             Zkroutit 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Zrnění 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Zrnitý film 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Zvlnění 19.1.4 – ze souboru “Standard MultiPlugin.8bf”
                                                             Zvlnění moře 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                             Zvýraznění obrysů 19.1.4 – ze souboru “Filter Gallery.8bf”
                                                          Doplňkové zásuvné moduly a zásuvné moduly jiných výrobců: ŽÁDNÉ
                                                          Duplicitní a zakázané zásuvné moduly: ŽÁDNÉ
                                                          Zásuvné moduly, které se nepodařilo zavést: žádné
                                                          Rozšíření:
                                                             com.adobe.inapp.purchase  1.0.0 – ze souboru “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseStock.html”
                                                             com.adobe.Butler.backend  2.0.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                                                             Knihovny  1.0.0 – ze souboru “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\index.html”
                                                             Nový dokument  2.2.1 – ze souboru “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
                                                             com.adobe.inapp.typekit.purchase  1.0.0 – ze souboru “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseTypekit.html”
                                                             Začátek  2.2.1 – ze souboru “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
                                                             Motivy Adobe Color  6.1.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                                                             Exportovat jako  3.1.2 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                                                          Instalovaná zařízení TWAIN: ŽÁDNÁ
                                                          • 28. Re: Can't use 3D in Photoshop CC
                                                            Hi adélab23424951
                                                            3D features are disabled on systems with less that 512MB of VRA (your system info shows 256MB)
                                                            • 29. Re: Can't use 3D in Photoshop CC
                                                              Thank you very much
                                                              • 30. Re: Can't use 3D in Photoshop CC
        Barnone16barz Level 1
        Im having the same issues
        Adobe Photoshop Version: 19.1.5 20180604.r.346 2018/06/04: 1175273  x64
        Number of Launches: 117
        System architecture: AMD CPU Family:15, Model:2, Stepping:0 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
        Physical processor count: 4
        Logical processor count: 8
        Processor speed: 4018 MHz
        Built-in memory: 32750 MB
        Free memory: 17395 MB
        Memory available to Photoshop: 29991 MB
        Memory used by Photoshop: 58 %
        Highbeam: Enabled.
        Image tile size: 1028K
        Image cache levels: 6
        TextComposer: Latin
        Display: 1
        Display Bounds: top=0, left=0, bottom=1050, right=1680
        Display: 2
        Display Bounds: top=-25, left=1680, bottom=1025, right=3360
        AIFOGLInitialized=1
        OGLContextCreated=1
        NumGLGPUs=1
        NumNativeGPUs=0
        glgpu[0].GLVersion="4.1"
        glgpu[0].GLName="NVIDIA GeForce GTX 750 Ti"
        glgpu[0].GLVendor="NVIDIA Corporation"
        glgpu[0].GLVendorID=4318
        glgpu[0].GLDriverVersion="23.21.13.8813"
        glgpu[0].GLRenderer="GeForce GTX 750 Ti/PCIe/SSE2"
        glgpu[0].GLRendererID=4992
        glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2 e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.i nf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_r ef_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepos itory\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll"
        glgpu[0].GLDriverDate="20171027000000.000000-000"
        glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
        glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
        glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
        glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
        glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
        License Type: Subscription
        Serial number: 90970207930636620769
        GUIDBucket:
        Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
        Temporary file path: C:\Users\BARNON~1\AppData\Local\Temp\
        Scratch volume(s):
        F:\, 2.73T, 559.2G free
        Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
        Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
        A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
        ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
        AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
        AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
        AdobeOwl.dll   Adobe Owl   5.2.11
        AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
        AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
        AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
        AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
        AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
        AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
        adobe_caps.dll   Adobe CAPS   10,0,0,6
        AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
        ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
        AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
        amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
        ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
        AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
        AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
        Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
        BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
        boost_date_time.dll   photoshopdva   11.1.0
        boost_filesystem.dll   photoshopdva   11.1.0
        boost_signals.dll   photoshopdva   11.1.0
        boost_system.dll   photoshopdva   11.1.0
        boost_threads.dll   photoshopdva   11.1.0
        cg.dll   NVIDIA Cg Runtime   3.0.00007
        cgGL.dll   NVIDIA Cg Runtime   3.0.00007
        CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
        CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
        CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
        dnssd.dll   Bonjour   3,0,0,2
        dvaaudiodevice.dll   photoshopdva   11.1.0
        dvacore.dll   photoshopdva   11.1.0
        dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
        dvamarshal.dll   photoshopdva   11.1.0
        dvamediatypes.dll   photoshopdva   11.1.0
        dvametadata.dll   photoshopdva   11.1.0
        dvametadataapi.dll   photoshopdva   11.1.0
        dvametadataui.dll   photoshopdva   11.1.0
        dvaplayer.dll   photoshopdva   11.1.0
        dvatransport.dll   photoshopdva   11.1.0
        dvaui.dll   photoshopdva   11.1.0
        dvaunittesting.dll   photoshopdva   11.1.0
        dynamiclink.dll   photoshopdva   11.1.0
        ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
        icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
        icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
        icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
        igestep30.dll   IGES Reader   9.3.0.113
        imslib.dll   IMSLib DLL   10.0.0.22
        JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
        libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
        libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
        libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
        LogSession.dll   LogSession   7.4.1.109.46827
        mediacoreif.dll   photoshopdva   11.1.0
        MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
        pdfsettings.dll   Adobe PDFSettings   1.04
        Photoshop.dll   Adobe Photoshop CC 2018   19.1.5
        Plugin.dll   Adobe Photoshop CC 2018   19.1.5
        PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
        PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
        PSArt.dll   Adobe Photoshop CC 2018   19.1.5
        PSCloud.dll                                                   1.0.0.1
        PSViews.dll   Adobe Photoshop CC 2018   19.1.5
        SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
        SVGRE.dll   SVGRE   79.586793   79.586793
        svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
        tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
        tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
        TfFontMgr.dll   FontMgr   9.3.0.113
        TfKernel.dll   Kernel   9.3.0.113
        TFKGEOM.dll   Kernel Geom   9.3.0.113
        TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
        updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
        VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
        VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
        WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
        WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
        wu3d.dll   U3D Writer   9.3.0.113
        Required plug-ins:
        3D Studio 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Accented Edges 19.1.5 - from the file “Filter Gallery.8bf”
        Adaptive Wide Angle 19.1.5 - from the file “Adaptive Wide Angle.8bf”
        Angled Strokes 19.1.5 - from the file “Filter Gallery.8bf”
        Average 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Average.8bf”
        Bas Relief 19.1.5 - from the file “Filter Gallery.8bf”
        BMP 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Camera Raw 10.4 - from the file “Camera Raw.8bi”
        Camera Raw Filter 10.4 - from the file “Camera Raw.8bi”
        Chalk && Charcoal 19.1.5 - from the file “Filter Gallery.8bf”
        Chrome 19.1.5 - from the file “Filter Gallery.8bf”
        Cineon 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Cineon.8bi”
        Clouds 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Clouds.8bf”
        Collada 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Color Halftone 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Colored Pencil 19.1.5 - from the file “Filter Gallery.8bf”
        CompuServe GIF 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Conté Crayon 19.1.5 - from the file “Filter Gallery.8bf”
        Craquelure 19.1.5 - from the file “Filter Gallery.8bf”
        Crop and Straighten Photos 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “CropPhotosAuto.8li”
        Crop and Straighten Photos Filter 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Crosshatch 19.1.5 - from the file “Filter Gallery.8bf”
        Crystallize 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Cutout 19.1.5 - from the file “Filter Gallery.8bf”
        Dark Strokes 19.1.5 - from the file “Filter Gallery.8bf”
        De-Interlace 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Dicom 19.1.5 - from the file “Dicom.8bi”
        Difference Clouds 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Clouds.8bf”
        Diffuse Glow 19.1.5 - from the file “Filter Gallery.8bf”
        Displace 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Dry Brush 19.1.5 - from the file “Filter Gallery.8bf”
        Eazel Acquire 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “EazelAcquire.8ba”
        Entropy 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Export Color Lookup Tables 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Export3DLUT.8be”
        Extrude 19.1.5 - from the file “Standard MultiPlugin.8bf”
        FastCore Routines 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “FastCore.8bx”
        Fibers 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Film Grain 19.1.5 - from the file “Filter Gallery.8bf”
        Filter Gallery 19.1.5 - from the file “Filter Gallery.8bf”
        Fix Motion-Blur 4.0.1.0 - from the file “FocusMagic64.8bf”
        Fix Out-of-focus Blur 4.0.1.0 - from the file “FocusMagic64.8bf”
        Flash 3D 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Fresco 19.1.5 - from the file “Filter Gallery.8bf”
        Glass 19.1.5 - from the file “Filter Gallery.8bf”
        Glowing Edges 19.1.5 - from the file “Filter Gallery.8bf”
        Google Earth 4 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Graphic Pen 19.1.5 - from the file “Filter Gallery.8bf”
        Halftone Pattern 19.1.5 - from the file “Filter Gallery.8bf”
        Halide Bottlenecks 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “HalideBottlenecks.8bx”
        HDRMergeUI 19.1.5 - from the file “HDRMergeUI.8bf”
        HSB/HSL 19.1.5 - from the file “Standard MultiPlugin.8bf”
        IFF Format 19.1.5 - from the file “Standard MultiPlugin.8bf”
        IGES 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Ink Outlines 19.1.5 - from the file “Filter Gallery.8bf”
        JPEG 2000 19.1.5 - from the file “JPEG2000.8bi”
        Kurtosis 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Lens Blur 19.1.5 - from the file “Lens Blur.8bf”
        Lens Correction 19.1.5 - from the file “Lens Correction.8bf”
        Lens Flare 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Liquify 19.1.5 - from the file “Liquify.8bf”
        Matlab Operation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “ChannelPort.8bf”
        Maximum 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Mean 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Measurement Core 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “MeasurementCore.8me”
        Median 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Mezzotint 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Minimum 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        MMXCore Routines 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “MMXCore.8bx”
        Mosaic Tiles 19.1.5 - from the file “Filter Gallery.8bf”
        Multiprocessor Support 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “MultiProcessor Support.8bx”
        Neon Glow 19.1.5 - from the file “Filter Gallery.8bf”
        Note Paper 19.1.5 - from the file “Filter Gallery.8bf”
        NTSC Colors 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “NTSC Colors.8bf”
        Ocean Ripple 19.1.5 - from the file “Filter Gallery.8bf”
        OpenEXR 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Paint Daubs 19.1.5 - from the file “Filter Gallery.8bf”
        Palette Knife 19.1.5 - from the file “Filter Gallery.8bf”
        Patchwork 19.1.5 - from the file “Filter Gallery.8bf”
        Paths to Illustrator 19.1.5 - from the file “Standard MultiPlugin.8bf”
        PCX 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “PCX.8bi”
        Photocopy 19.1.5 - from the file “Filter Gallery.8bf”
        Photoshop 3D Engine 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Photoshop3DEngine.8bi”
        Photoshop Touch 19.0 - from the file “PSDX.8bi”
        Picture Package Filter 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “ChannelPort.8bf”
        Pinch 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Pixar 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Pixar.8bi”
        Plaster 19.1.5 - from the file “Filter Gallery.8bf”
        Plastic Wrap 19.1.5 - from the file “Filter Gallery.8bf”
        PLY 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Pointillize 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Polar Coordinates 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Portable Bit Map 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “PBM.8bi”
        Poster Edges 19.1.5 - from the file “Filter Gallery.8bf”
        PRC 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Radial Blur 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Radiance 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Radiance.8bi”
        Range 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Render Color Lookup Grid 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Export3DLUT.8be”
        Reticulation 19.1.5 - from the file “Filter Gallery.8bf”
        Ripple 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Rough Pastels 19.1.5 - from the file “Filter Gallery.8bf”
        Save for Web 19.1.5 - from the file “Save for Web.8be”
        ScriptingSupport 19.1.5 - from the file “ScriptingSupport.8li”
        Shake Reduction 19.1.5 - from the file “Shake Reduction.8bf”
        Shear 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Skewness 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Smart Blur 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Smudge Stick 19.1.5 - from the file “Filter Gallery.8bf”
        Solarize 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “Solarize.8bf”
        Spaces 19.1.5 - from the file “Spaces.8li”
        Spatter 19.1.5 - from the file “Filter Gallery.8bf”
        Spherize 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Sponge 19.1.5 - from the file “Filter Gallery.8bf”
        Sprayed Strokes 19.1.5 - from the file “Filter Gallery.8bf”
        Stained Glass 19.1.5 - from the file “Filter Gallery.8bf”
        Stamp 19.1.5 - from the file “Filter Gallery.8bf”
        Standard Deviation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        STL 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Sumi-e 19.1.5 - from the file “Filter Gallery.8bf”
        Summation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Targa 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Texturizer 19.1.5 - from the file “Filter Gallery.8bf”
        Tiles 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Torn Edges 19.1.5 - from the file “Filter Gallery.8bf”
        Twirl 19.1.5 - from the file “Standard MultiPlugin.8bf”
        U3D 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Underpainting 19.1.5 - from the file “Filter Gallery.8bf”
        Vanishing Point 19.1.5 - from the file “VanishingPoint.8bf”
        Variance 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “statistics.8ba”
        Virtual Reality Modeling Language | VRML 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        Water Paper 19.1.5 - from the file “Filter Gallery.8bf”
        Watercolor 19.1.5 - from the file “Filter Gallery.8bf”
        Wave 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Wavefront|OBJ 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “U3D.8bi”
        WIA Support 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “WIASupport.8li”
        Wind 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Wireless Bitmap 19.1.5 (20180604.r.346 2018/06/04: 1175273) - from the file “WBMP.8bi”
        ZigZag 19.1.5 - from the file “Standard MultiPlugin.8bf”
        Optional and third party plug-ins: NONE
        Duplicate and Disabled plug-ins: NONE
        Plug-ins that failed to load: NONE
        Extensions:
        com.adobe.inapp.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseStock.html”
        Social Kit Pro  1.0.6 - from the file “C:\Users\Barnone Pc\AppData\Roaming\Adobe\CEP\extensions\com.madebysource.socialkitpro\index.html”
        Libraries  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\index.html”
        com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseTypekit.html”
        Start  2.3.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.3.0\index.html?v=2.3.0.58”
        DODGE AND BURN 2.0  2.0.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.thinkingpixels.dodgeandburn2\index.html”
        Watermark CC  2.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\watermarkcc_en\index.html”
        Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
        com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
        Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
        preview-basic  2.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\watermarkcc_en\preview\preview-basic.html”
        Installed TWAIN devices: NONE
        • 31. Re: Can't use 3D in Photoshop CC
        Hi Barnone16barz
        Your system data looks OK. Is your document in RGB mode? It needs to be for 3D to work.
        Dave
        • 32. Re: Can't use 3D in Photoshop CC
        OMG I forgot I have been doing alot of Print work smh Thank you!!!
        • 33. Re: Can't use 3D in Photoshop CC
        mac-donald25308 Level 1
        Adobe Photoshop Version: 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00) x64 Operating System: Windows 8 64-bit Version: 6.2 System architecture: Intel CPU Family:6, Model:7, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2 Physical processor count: 4 Processor speed: 2000 MHz Built-in memory: 3993 MB Free memory: 1488 MB Memory available to Photoshop: 2795725 MB Memory used by Photoshop: 60 % Image tile size: 1024K Image cache levels: 4 OpenGL Drawing: Enabled. OpenGL Drawing Mode: Advanced OpenGL Allow Normal Mode: True. OpenGL Allow Advanced Mode: True. OpenGL Allow Old GPUs: Not Detected. OpenCL Unavailable OpenGL Version: 2.1 Video Rect Texture Size: 16384 OpenGL Memory: 2060 MB Video Card Vendor: Intel Video Card Renderer: Intel(R) HD Graphics Display: 1 Display Bounds: top=0, left=0, bottom=768, right=1366 Video Card Number: 1 Video Card: Intel(R) HD Graphics Driver Version: 10.18.10.4358 Driver Date: 20151221000000.000000-000 Video Card Driver: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll Video Mode: 1366 x 768 x 4294967296 colors Video Card Caption: Intel(R) HD Graphics Video Card Memory: 2060 MB Serial number: 91198709403270006793 Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\ Temporary file path: C:\Users\USERPC~1\AppData\Local\Temp\ Photoshop scratch has async I/O enabled Scratch volume(s):   Startup, 464.4G, 260.9G free Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\ Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\ Installed components:   ACE.dll  ACE 2013/03/19-12:09:02  79.535293  79.535293   adbeape.dll  Adobe APE 2013/02/04-09:52:32  0.1160850  0.1160850   AdobeLinguistic.dll  Adobe Linguisitc Library  7.0.0    AdobeOwl.dll  Adobe Owl 2013/03/03-12:10:08  5.0.13  79.533484   AdobePDFL.dll  PDFL 2013/03/13-12:09:15  79.499517  79.499517   AdobePIP.dll  Adobe Product Improvement Program  7.0.0.1768    AdobeXMP.dll  Adobe XMP Core 2013/03/13-12:09:15  79.151481  79.151481   AdobeXMPFiles.dll  Adobe XMP Files 2013/03/13-12:09:15  79.151481  79.151481   AdobeXMPScript.dll  Adobe XMP Script 2013/03/13-12:09:15  79.151481  79.151481   adobe_caps.dll  Adobe CAPS  7,0,0,21    AGM.dll  AGM 2013/03/29-12:09:59  79.536232  79.536232   ahclient.dll    AdobeHelp Dynamic Link Library  1,8,0,31    aif_core.dll  AIF  5.0  79.534508   aif_ocl.dll  AIF  5.0  79.534508   aif_ogl.dll  AIF  5.0  79.534508   amtlib.dll  AMTLib (64 Bit)  7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)  1.000000   ARE.dll  ARE 2013/03/19-12:09:02  79.535293  79.535293   AXE8SharedExpat.dll  AXE8SharedExpat 2011/12/16-15:10:49  66.26830  66.26830   AXEDOMCore.dll  AXEDOMCore 2011/12/16-15:10:49  66.26830  66.26830   Bib.dll  BIB 2013/03/19-12:09:02  79.535293  79.535293   BIBUtils.dll  BIBUtils 2013/03/19-12:09:02  79.535293  79.535293   boost_date_time.dll  DVA Product  7.0.0    boost_signals.dll  DVA Product  7.0.0    boost_system.dll  DVA Product  7.0.0    boost_threads.dll  DVA Product  7.0.0    cg.dll  NVIDIA Cg Runtime  3.0.00007    cgGL.dll  NVIDIA Cg Runtime  3.0.00007    CIT.dll  Adobe CIT  2.1.6.30158  2.1.6.30158   CITThreading.dll  Adobe CITThreading  2.1.6.30158  2.1.6.30158   CoolType.dll  CoolType 2013/03/19-12:09:02  79.535293  79.535293   dvaaudiodevice.dll  DVA Product  7.0.0    dvacore.dll  DVA Product  7.0.0    dvamarshal.dll  DVA Product  7.0.0    dvamediatypes.dll  DVA Product  7.0.0    dvaplayer.dll  DVA Product  7.0.0    dvatransport.dll  DVA Product  7.0.0    dvaunittesting.dll  DVA Product  7.0.0    dynamiclink.dll  DVA Product  7.0.0    ExtendScript.dll  ExtendScript 2013/03/21-12:10:31  79.535742  79.535742   FileInfo.dll  Adobe XMP FileInfo 2013/03/19-12:09:02  79.151561  79.151561   filter_graph.dll  AIF  5.0  79.534508   icucnv40.dll  International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615    icudt40.dll  International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615    imslib.dll  IMSLib DLL  7.0.0.37    JP2KLib.dll  JP2KLib 2013/02/19-12:28:44  79.248139  79.248139   libifcoremd.dll  Intel(r) Visual Fortran Compiler  10.0 (Update A)    libmmd.dll  Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler  12.0    LogSession.dll  LogSession  2.1.2.1756    mediacoreif.dll  DVA Product  7.0.0    MPS.dll  MPS 2013/03/15-13:25:52  79.535029  79.535029   msvcm80.dll  Microsoft® Visual Studio® 2005  8.00.50727.9445    msvcm90.dll  Microsoft® Visual Studio® 2008  9.00.30729.1    msvcp100.dll  Microsoft® Visual Studio® 2010  10.00.40219.1    msvcp80.dll  Microsoft® Visual Studio® 2005  8.00.50727.9445    msvcp90.dll  Microsoft® Visual Studio® 2008  9.00.30729.1    msvcr100.dll  Microsoft® Visual Studio® 2010  10.00.40219.1    msvcr80.dll  Microsoft® Visual Studio® 2005  8.00.50727.9445    msvcr90.dll  Microsoft® Visual Studio® 2008  9.00.30729.1    PatchMatch.dll  PatchMatch 0000/00/00-00:00:00  1.  1.   pdfsettings.dll  Adobe PDFSettings  1.04    Photoshop.dll  Adobe Photoshop CC  CC    Plugin.dll  Adobe Photoshop CC  CC    PlugPlugOwl.dll  Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)  4.0.1.34    PSArt.dll  Adobe Photoshop CC  CC    PSViews.dll  Adobe Photoshop CC  CC    SCCore.dll  ScCore 2013/03/21-12:10:31  79.535742  79.535742   ScriptUIFlex.dll  ScriptUIFlex 2013/03/21-12:10:31  79.535742  79.535742   svml_dispmd.dll  Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler  12.0    tbb.dll  Intel(R) Threading Building Blocks for Windows  4, 1, 2012, 1003    tbbmalloc.dll  Intel(R) Threading Building Blocks for Windows  4, 1, 2012, 1003    updaternotifications.dll  Adobe Updater Notifications Library  7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)  7.0.1.102   WRServices.dll  WRServices Mon Feb 25 2013 16:09:10  Build 0.19078  0.19078 Required plug-ins:   Accented Edges 14.0   Adaptive Wide Angle 14.0   Angled Strokes 14.0   Average 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Bas Relief 14.0   BMP 14.0   Camera Raw 8.0   Camera Raw Filter 8.0   Chalk & Charcoal 14.0   Charcoal 14.0   Chrome 14.0   Cineon 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Clouds 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Collada 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Color Halftone 14.0   Colored Pencil 14.0   CompuServe GIF 14.0   Conté Crayon 14.0   Craquelure 14.0   Crop and Straighten Photos 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Crop and Straighten Photos Filter 14.0   Crosshatch 14.0   Crystallize 14.0   Cutout 14.0   Dark Strokes 14.0   De-Interlace 14.0   Difference Clouds 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Diffuse Glow 14.0   Displace 14.0   Dry Brush 14.0   Eazel Acquire 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Embed Watermark 4.0   Extrude 14.0   FastCore Routines 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Fibers 14.0   Film Grain 14.0   Filter Gallery 14.0   Fresco 14.0   Glass 14.0   Glowing Edges 14.0   Grain 14.0   Graphic Pen 14.0   Halftone Pattern 14.0   HDRMergeUI 14.0   IFF Format 14.0   Ink Outlines 14.0   JPEG 2000 14.0   Lens Blur 14.0   Lens Correction 14.0   Lens Flare 14.0   Liquify 14.0   Matlab Operation 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Measurement Core 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Mezzotint 14.0   MMXCore Routines 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Mosaic Tiles 14.0   Multiprocessor Support 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Neon Glow 14.0   Note Paper 14.0   NTSC Colors 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Ocean Ripple 14.0   Oil Paint 14.0   OpenEXR 14.0   Paint Daubs 14.0   Palette Knife 14.0   Patchwork 14.0   Paths to Illustrator 14.0   PCX 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Photocopy 14.0   Photoshop 3D Engine 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Picture Package Filter 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Pinch 14.0   Pixar 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Plaster 14.0   Plastic Wrap 14.0   PNG 14.0   Pointillize 14.0   Polar Coordinates 14.0   Portable Bit Map 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Poster Edges 14.0   Radial Blur 14.0   Radiance 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Read Watermark 4.0   Reticulation 14.0   Ripple 14.0   Rough Pastels 14.0   Save for Web 14.0   ScriptingSupport 14.0   Shake Reduction 14.0   Shear 14.0   Smart Blur 14.0   Smudge Stick 14.0   Solarize 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Spatter 14.0   Spherize 14.0   Sponge 14.0   Sprayed Strokes 14.0   Stained Glass 14.0   Stamp 14.0   Sumi-e 14.0   Targa 14.0   Texturizer 14.0   Tiles 14.0   Torn Edges 14.0   Twirl 14.0   Underpainting 14.0   Vanishing Point 14.0   Variations 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Water Paper 14.0   Watercolor 14.0   Wave 14.0   WIA Support 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   Wind 14.0   Wireless Bitmap 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)   ZigZag 14.0 Optional and third party plug-ins: NONE Plug-ins that failed to load: NONE Flash:   Kuler   Adobe Exchange Installed TWAIN devices: NONE
        • 34. Re: Can't use 3D in Photoshop CC
        Hi
        Are you asking a question, your system info shows that you are using Photoshop version 14.0, why have you not updated via the Adobe Creative Cloud app, also which seems odd is that your License Type info is missing from the above
        Photoshop version 14.0 was originally released after CS6 in 2013 so it seems a bit strange that you would be using that version when the current version of Photoshop is 19.1.5
        • 35. Re: Can't use 3D in Photoshop CC
        the zen temple Level 1
        thanks so very much
