3 Replies Latest reply on Oct 11, 2013 6:58 AM by Bill Gehrke
    560 vs 480
    flbreen Level 1
      I have a 3.5 year old PC with a GTX 480 I use as my backup machine.
      It does a good job supporting Mercury Acceleration running Pr CS6.
      I acquired a GTX 560 ti from someone upgrading.
      Would it be worth replacing the 480 with the 560 to get better performance?
        • 1. Re: 560 vs 480
          Bill Gehrke Adobe Community Professional & MVP
          The little improvement over your 480 would be marginal unless you use an awful lot GPU accelerated effects and/or features repeatedly many times a day.
          Message was edited by: Bill Gehrke
          • 2. Re: 560 vs 480
            flbreen Level 1
            The 560 I got is free as I paid for the upgrade to my son's gammer PC.
            But I don't see the 560 listed on the GPU list.
            I assume a 560 not as good as a 580.
            If I can add the 560 to my main PC that has a 680 would that combination add much to the processing speed of that PC?
            I guess the question is what is the best thing to do with a free 560?
            • 3. Re: 560 vs 480
              As you can see from the chart, if you add that 560 Ti to your your 680 and you are running Premiere 7 (CC) it could be a help, if you are using "a lot GPU accelerated effects and/or features" often like down scaling HD to DVD or HD to a lower resolution H.264 format.
              But first check your power supply to make sure you have a additional 170 watts available for the GTX 560 Ti or 210 watts if it happens to be a 448 core version
