1 Reply Latest reply on Oct 11, 2013 9:09 PM by Sean_Wilson
    FileIO - Readfile stops at certain characters
    Sh3rv
      Hello,
      Windows 8 - Director 12
      I’m designing a GUI which opens an ini file into memory, and edits specific lines depending on the user’s preference before saving back to the file. When I open the ini file into memory it partially works until a 'special' character is encountered, in this case the " ¦ " symbol. I cannot remove these characters from the original ini file as they are required. How can I get Director to read all of the files contents despite the special characters?
      Here are the variations of the code I have used, all resulting in the same issue :
      1
          fileObj = new(xtra "FileIO")
          openFile(fileObj, "C:\Work\Projects\BusLane Application\NRS\BLOM.ini", 1)
          blomINI = readfile(fileObj)
      2
           objFileio = new xtra("fileio")
      objFileio.openFile("C:\Work\Projects\BusLane Application\NRS\BLOM.ini",0)
        blomINI =objFileio.readFile()
        put contents
      3
         set fileXtra = new(xtra "FileIO")
        openFile(fileXtra, "C:\Work\Projects\BusLane Application\NRS\BLOM.ini",1)
        set blomINI = readFile(fileXtra)
      closeFile(fileXtra)
      Here is an extract of the ini file :
      ; The following information has been split into two elements, as somewhere it is getting
      truncated Element 14=KeyValuePair¦DynamicObservationXML¦<zoneId>%LocationDescription
      %</zoneId><zoneAlias>%LocationIdentifier%</zoneAlias>
      The text in memory only shows :
      It also stops at " // "
      Thanks.
