2 Replies Latest reply on Oct 11, 2013 6:22 AM by mattnewnham
    event.fieldFull is false
    mattnewnham
      I am trying to implement a solution where I have to populate a text field with a string that may be too large to fit in the text field. In this case, I want to populate a second text field with the overspill.
      The field does not have a character limit, but has "Scroll long text" set to false, multiline to true.
      I have been looking at the "event.fieldFull" property on the keystroker event of the text field, this works great when text is entered manually from the keyboard. However, in my scenario, these fields will never be entered manually, always pre-populated. I've experimented with setting the field value with javascript inside the PDF. This does appear to fire the keystroke event for the field, but the event.fieldFull value is always false, even if the text exceeds the display limit.
      Is there any way to simulate the key press, so that the event is triggered as if the user entered via the keyboard?
      Any other solutions to this problem?
        • 1. Re: event.fieldFull is false
          Why would you need to do it? If you're setting the value with a script you can easily check the length of that value and if necessary split it yourself and apply each part to a different field.
          • 2. Re: event.fieldFull is false
            mattnewnham Level 1
            Although there are methods for calculating the space required for a large string, they are not 100% reliable, as I have discovered in other areas of the project. It would be much cleaner for Acrobat to do the calculating and flag whether a string fits or not, rather than performing the calculation elsewhere.
