4 Replies Latest reply on Oct 11, 2013 9:10 AM by John T Smith
    Can't view an .avi file in Premiere Pro CS6. Getting an "unsupported format or damaged file" error.
    MikeB2342 Level 1
      I am trying to bring three separate animations into Premiere Pro, but it won't pull them into the Source window or Sequence timeline. The three files are uncompressed .avi files that were rendered out in Autodesk Inventor. They are 15 second clips, around 2gb each, and 40fps. I can play them in Windows Media Player without a problem. Any ideas on where to start troubleshooting? I can't imagine it's a codec issue, if the files are uncompressed?
      Edit: I used MediaInfo to get the info on the video.
      General
      Complete name                            : E:\Videos\13-1011 LAGCOE LED Billboard Video\1250 Drill Pipe Elevator Video.avi
      Format                                   : AVI
      Format/Info                              : Audio Video Interleave
      File size                                : 2.06 GiB
      Duration                                 : 15s 25ms
      Overall bit rate                         : 1 180 Mbps
      Video
      Format                                   : RGB
      Codec ID                                 : 0x00000000
      Codec ID/Info                            : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
      Duration                                 : 15s 25ms
      Bit rate                                 : 1 133 Mbps
      Width                                    : 1 280 pixels
      Height                                   : 960 pixels
      Display aspect ratio                     : 4:3
      Frame rate                               : 40.000 fps
      Bit depth                                : 8 bits
      Bits/(Pixel*Frame)                       : 23.050
      Stream size                              : 1.98 GiB (96%)
