1 Reply Latest reply on May 12, 2014 11:41 AM by elDudereno
    Script works Great, Pro-Tips appreciated.
    elDudereno Level 3
      This script is used to make a few changes that SOME of our die suppliers require. It works great. If you have a little time to look it over and give me some advice on best practices, consiseness etc. it would be greatly appreciated.
      Note: The files this script is aimed at are fairly civilized, and don't vary much so I didn't have to buld in room for varience. For example, the die lines will ALWAYS be a spot color, so I didn't need to include anything for RGB or CMYK.
      // script.name = prepDieFile.js;
      // script.description = removes unnecessary layers, vectors, and text. Leaves cross-mark line unpainted. Colors all remaining text and strokes black;
      // script.requirements = an opened document;
      // script.parent = elDudereno // 10/10/13;
      // script.elegant = false;
      #target Illustrator
      var idoc = app.activeDocument;
      var pi = idoc.pathItems;
      var tf = idoc.textFrames;
      var deletedLayers = 0;
      var deletedPaths = 0;
      var spotStroke = 0;
      var deletedText = 0;
      var blackedText = 0;
      var layerCount = idoc.layers.length;
      //loop through all layers deleting hidden layers. Loop from the back, to preserve index of remaining layers when we remove one.
      for (var i = layerCount - 1; i >= 0; i--) {
                var thisLayer = idoc.layers[i];
                if (thisLayer.visible == false || thisLayer.locked == true) {
                          thisLayer.visible = true;
                          thisLayer.locked = false;
                          thisLayer.remove();
                          deletedLayers++;
      unlockPaths();
      //locate largest path item (bounding box) and lock it.
      var theBiggest = pi[0];
      for (i=1; i<pi.length; i++) {
                if (Math.abs(pi[i].area) > Math.abs(theBiggest.area)) {
                          theBiggest = pi[i];
      theBiggest.remove();
      deletedLayers++;
      //locate second largest path (cross-mark size) remove stroke and lock
      var secondBiggest = pi[0];
      for (j=1; j<pi.length; j++) {
                if (Math.abs(pi[j].area) > Math.abs(secondBiggest.area)) {
                          secondBiggest = pi[j];
      secondBiggest.strokeColor = NoColor;
      secondBiggest.fillColor = NoColor;
      secondBiggest.locked = true;
      // loop through path items delete if hidden, registration, or un-stroked. Change all non-registration spot colors to 100% GrayColor.
      for (var j=pi.length -1; j >= 0; j--) {
                var ipath = pi[j];
                if (ipath.hidden==true) {
                          ipath.remove();
                          deletedPaths++;
                if (ipath.locked==false) {
                          var strokeColor = ipath.strokeColor;
                          if (strokeColor.typename == "NoColor"){
                                    ipath.remove();
                                    deletedPaths++;
                          else if (strokeColor.typename == "SpotColor"){
                                    if (strokeColor.spot.name == "[Registration]"){
                                              ipath.remove();
                                              deletedPaths++;
                                    } else {
                                              ipath.strokeColor = GrayColor;
                                              ipath.strokeColor.gray = 100.0;
                                              spotStroke++;
      unlockPaths();
      // delete text frames with first letter set to registration. Turn all other text to black.
      for (t=tf.length -1; t>=0; t--) {
                var iTxtFrm = tf[t];
                var firstLtr = iTxtFrm.characters[0];
                if (firstLtr.characterAttributes.fillColor.spot.name == "[Registration]"){
                          iTxtFrm.remove();
                          deletedText++;
                else {
                          var chars = iTxtFrm.characters;
                          for (var c=0; c<chars.length; c++) {
                                    var ltr = chars[c];
                                    ltr.characterAttributes.fillColor = GrayColor;
                                    ltr.characterAttributes.fillColor.gray = 100.0;
                                    blackedText++;
      redraw();
      alert(deletedLayers + " hidden or locked layer(s), " + deletedPaths + " path(s) & " + deletedText + " text frames, were deleted.  " + blackedText + " letters, & " + spotStroke + " stroke(s) were converted to 100% K.");
      //unlock all path items
      function unlockPaths(){
                for (var k=0; k<pi.length; k++){
                          var lpath = pi[k];
                          if (lpath.locked == true){
                                    lpath.locked = false;
      Thanks for taking a look.
      http://www.filedropper.com/0388701die <-sample file.
        • 1. Re: Script works Great, Pro-Tips appreciated.
          elDudereno Level 3
          I recently updated this to delete all but one artboard and make the remaining artboard the same size as the object with the largest area.
          #target Illustrator
          var spotStroke = 0;
          var deletedBoards = 0;
          var boardCount = idoc.artboards.length;
          //loop through all artboards deleting all but the first.
          for (var i = boardCount - 1; i >= 1; i--) {
            var thisBoard = idoc.artboards[i];
            thisBoard.remove();
            deletedBoards++;
            thisLayer.remove();
            deletedLayers++;
          unlockPaths();
          //locate largest path item (bounding box) set artboard to that size and remove path.
            theBiggest = pi[i];
          idoc.artboards[0].artboardRect=theBiggest.geometricBounds;
          deletedLayers++;
            var ipath = pi[j];
            ipath.remove();
            deletedPaths++;
            ipath.remove();
            deletedPaths++;
            ipath.remove();
            deletedPaths++;
            } else {
            spotStroke++;
          unlockPaths();
            iTxtFrm.remove();
            deletedText++;
            else {
            var ltr = chars[c];
            blackedText++;
          redraw();
          alert(deletedBoards + " art board(s), " + deletedLayers + " hidden or locked layer(s), " + deletedPaths + " path(s) & " + deletedText + " text frames, were deleted.  " + blackedText + " letters, & " + spotStroke + " stroke(s) were converted to 100% K.");
            var lpath = pi[k];
          Credit to @Tom_Friedman for post 13 in this thread Re: Resize Artboard
