7 Replies Latest reply on Oct 12, 2013 10:06 AM by grug73
    Disk setup optimization for CS6?
    grug73
      Hi guys another one of these...Need drive set up advise please
      First and FOREMOST I'VE READ ALL THE TWEAKERS PAGE so my situation is not in there unfortunaltely so any comment about go read them is uneccesary.  Why? Because it does not consist of all identical drives and unfortunately I have to make due with what i have for now in terms of drives...
      System I5-3570k (4.2 oc), z77-ud5h mobo, 16 Gb low latency 1600 mhz Ram, radeon hd sapphire 4870, Mac OS 10.8.5
      The set up needs to help me work on RED foootage (which i'll reconvert if need be to pro res or cineform or work in proxy if need be until cc), so it's TEMPORARY.  I understand the risks but doing this project will let me upgrade to better disks after. Meaning for the span of this project I don't care about redundancy (the cclient disk stays with me and i have copies)
      Drives available:
      1 x SSD 128 GB                                    (On Sata 3)                                                 r/w = 498
      1 x 500 GB Seagate (sata II)    (c.16)    (On Sata II)                                                 r/w = 128
      2 x 1TB WD Blue      (sata 3)    (c.64)    (On Sata II)                                                 r/w = 325 (Raid 0)
      1 x 1TB WD Gr (7200) (sata II) (c.32)    (On Sata II)                                                 r/w = 84
      1 x 90 GB SSD                                      (On sata 3)                                                 r/w = 500
      2 x 320 GB WD Blue (sata II)   (c.16)    (On g-sata *)                                                 r/w = 228  (Raid 0)
         *possible either from board or asmedia1061 pci-e card
      1 x 1.5 TB WD Gr (5400) Sata II        (c.32) =      (On g-sata)                                                  r/w = 70
      EXTERNAL DRIVES : 2 TB Gdrive (e-sata FW800) - 2 TB USB 2 seagate - 2 TB La Cie usb2 (i have enough to do backups and will)
      Apps used : CS6 (Premiere, AE, speed Grade) + FCPX + motion + c4d  (eventualy Resolve lite at least)
      Camera I edit from : Dslr - Arri - Ex1 -Ex3 - nexF700 - c300 -and red
      What would be my best drive set up options.  Not all drives need to be in there
      understanding and trying to respect the spreading scheme so often pointed out here is one option
      Option 1
      SSD 128GB                         : OS/Programs + Page file (see a.)                                                498
      Seagate 500GB                   : Projects        128
      2TB WD Blue RAID0            : Media        325
      640GB WD Blue Raid0        : Media Cache/Scratch Preview                                                  228
      1TB WD Gr                          : Exports        80
      SSD 90GB                           : Dedicated AE cache (and maybe also for c4d + motion)            495
      Notes:
        -I feel 500GB for Projects is not a lot but enough if separate from media sources, but i put it there because it's faster then the 1 TB wd     Green (128 vs 84)?  Where is speed more importan project files or exports?
        -Media managewise this feels complicated a bit?
      Option 2
      1TB WD Gr                          : Projects        80
      Seagate 500GB                  : Exports        128
      SSD 90GB                           : Dedicated AE cache (and maybe also for c4d and or motion)        495
      Notes: This would mean faster exports and more projects space, but i don think speed wise it's my optimal choice although it stays true to spreading...
      Option 3 : From adobe white paper hardware optimization...
      Preferred is a four-drive system, with one dedicated to the operating system and software, the second for source media and project files, the third for the media cache, and the fourth for previews and exports.
      That means this
      SSD 128 GB                        : OS/Programs + Page file (see a.)                                                   498
      2TB WD blue Raid 0            : Projects / Media        325
      500GB Seagate                   : Media cache/ Scratch        128
      640GB WD Blue Raid 0       : Previews  Exports        228
      Then Why not
      640GB WD Blue Raid 0       : Projects + Exports        228
      2TB WD blue + 1Tb WD Gr  : Media / Media cache + Previews                                                   400
      Or
      3TB TB RAid 0 BL = Gr     : Projects + Media + Exports                                                              400
      640GB WD Blue Raid 0       : Media cache + Previews        228
      introduces more risk because of the mixed Wd Blue and green Raidd 0
      But also seems OPTIMAL FOR media management and workflow as well
      Or
      500 GB Seagate                  : Projects        128
      3TB TB RAid 0 BL = Gr       : Media + exports        400
      if spreading additonnal drive  benefits more then raid 0 for projects whic i have a hard time to believe
      But I'd prefer to keep the 500 seagate for office documents and non video editing related softwares then
      Please feel free to suggest rearrangements.  I can't buy an external Raid 3/5 solution for now
      Q's from reding the tweakers page
      a) is pagefile a mac concern?
      b) Why would a raid 0 hurt project files, if it's also recommended for a raid 3/5 set up?  is it just because of redundancy issues striclty or because of other issues?
      d) What about the dedicated 90 GB ssd for AE cache (and or other motion 3d software) Good idean? 90 GB enough?
      e) How much media cache is enough
      f) Where do we need to adress the speed
        • 1. Re: Disk setup optimization for CS6?
          cc_merchant Level 4
          Your basic problem is your CPU. Any disk setup is only marginal in comparison to the CPU problem. An i5 is just not capable to handle anything RED/EPIC without serious problems.
          • 2. Re: Disk setup optimization for CS6?
            grug73 Level 1
            Ok thanks for the cpu comment.  But could you answer the question about drive set up please.
            I'll look into changing the processor althoug I've worked on red footage with my old machine a q9550 on a socket 775 board...I can send you the link to the tv spot if you'd like.
            I'm sure there is a workflow we can find for this processor...
            • 3. Re: Disk setup optimization for CS6?
              grug73 Level 1
              So just for fun here let's pretend I have a I-7 do you would you care to help on the questions asked? I see a lot of users on the red forum who work to a degree with footage with i-5  (I don't expect fullframe realtime playback and am ok with some rendering  as i will also do the grading in a post facility for now. Setting the drives would help me with other projects for now.
              • 4. Re: Disk setup optimization for CS6?
                cc_merchant Level 4
                Dunno. I'm a PC person without a Mac wallet.
                Redundancy. You don't want to lose project files, but using (r)aid0 you double or even triple (depending on the number of disks) the chances of losing everything.
                Seems small.
                256 GB looks OK for small to medium projects. For large projects you may need more.
                Cores, clock speed and memory.
                Green disks are OK for backup, nothing else. Certainly not for editing and not in a (r)aid configuration.
                • 5. Re: Disk setup optimization for CS6?
                  grug73 Level 1
                  Ok good start (btw it's a hackintos...used to be on macs, could afford a new MPro that's why i did it that way)
                  So if i were to put all caches on my second raido (640 GB) except the AE cache that i would put on the 90GB SSD would that help?
                  by f) i meant in relation to drive assignation : Projects : Media : Media Cache/Scratch Preview  : Previews and exports
                  The 1.5 T Green was out of the equation (5400) for sure but the 1TB Green is 7200 RPM.  Would it be  separate 4th drive for exports and be better ? And you find it too risky to add it as a third drive of a Raid 0.
                  So that leaves
                  2TB WD BL RAid 0              : Media + exports        325
                  *SSD 90GB                           : Dedicated AE cache (and maybe also for c4d + motion)                495
                  or do you see a better set up
                  • 6. Re: Disk setup optimization for CS6?
                    cc_merchant Level 4
                    A woman in a hot air balloon realized she was lost. She lowered her altitude and spotted a man in a boat below. She shouted to him, "Excuse me, can you help me? I promised a friend I would meet him an hour ago, but I don't know where I am."
                    The man consulted his portable GPS and replied, "You're in a hot air balloon approximately 30 feet above a ground elevation of 2346 feet above sea level. You are 31 degrees, 14.97 minutes north latitude and 100 degrees, 49.09 minutes west longitude."
                    She rolled her eyes and said, "You must be a Republican."
                    "I am," replied the man. "How did you know?"
                    "Well," answered the balloonist, "everything you told me is technically correct, but I have no idea what to make of your information, and I'm still lost. Frankly, you've not been much help to me."
                    The man smiled and responded, "You must be a Democrat."
                    "I am," replied the balloonist. "How did you know?"
                    "Well," said the man, "you don't know where you are or where you're going. You've risen to where you are due to a large quantity of hot air. You made a promise that you have no idea how to keep, and you expect me to solve your problem. You're in exactly the same position you were in before we met, but somehow now, it's my fault."
                    Media Cache and Previews is where you need speed, not redundancy.
                    Media & Projects is where you want redundancy, although speed is very nice as well.
                    Exports are not really critical, speed and redundancy wise, as long as you back-up the exports regularly.
                    • 7. Re: Disk setup optimization for CS6?
                      grug73 Level 1
                      Wow
                      A wise Chineesse man said
                      'When you feel like it's your fault then it must be'
                      Although I never implied any fault on your behèalf, beeing the one looking for more knowledge, untill now : you've made this a bit personal by your metaphorical assumptions.
                      Excuse me Sir for wanting to understand how speed of disks works in relation to drive size and drive assignations since i have disks of different sizes and speed and cache size.  I had read the forum well before posting.  Never again should you trouble yourself to answer any of my posts.  I really did explain I did not care about redundancy for now becaus i knew i could not get both for now for media and projects not having a raid an external controller and having read that even on board controller on z77 type of boards are useless, outside of usign time machine to back it up.  Excuse me for wanting to understand why you would put projects alone on a no raid drive if you wnated to work with 2 k material. Excuse me for wanting to understand wheter speed drive was more important thant speading the load on different disks (in relation to having different disk sizes and disk caches).  I come from FCP and was very active on help forums and whatever I knew I'd gladly shared.  Since you make this personnal by your assumptions instead of beeing a serial tweakers page copy paster and time waster (98 % of all drive set-up related questions on the forum have your fine print in them) maybe just answer the question. I'm sure i'm not alone to have unfortunately a system of disks with different sizes.  And i'm also sure i'm not the only one annoyed by not receiving an answer when you are waiting to help a friend with his film and are switching to a completly new editing system.
                      Well if i were in your place and considering the drives you ghave I'd place
                      c : for this
                      d : for that
                      e : for that
                      f : for that
                      and here is why
