1 Reply Latest reply on Oct 11, 2013 2:54 PM by Joux Rose
    Document class won't load, HELP!
    Joux Rose Level 1
      It happened suddenly, after I began to have weird (not valid, I swear!) errors all over a class (cannot access undefined property... ANY)
      After a while I just removed everything in the class and started to add back pieces bit by bit.
      But then suddenly there was a blank window when I tested... So I checked (edit button) the Main.as document class, and it was a default one created by flash!
      I tried various workaround: rename .fla, rename Main.as, but nothing works! It just wont load the document class
      Just want to know if maybe there's something obvious I didn't see or think of.
      thanks.
      [Win7 64bit, sublime text 3]
      EDIT: Just want to point out that while debugging, I saw that my sources folders had disappeared from AS3 properties... so everything points to a corrupted file.
      I dont see a way to export all assets to a swc, but by saving as uncompressed xfl, but then is there a way to import the whole ASSETS folder?
