• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RH6: Command line compilation warnings
Explorer ,
Jan 02, 2008 Jan 02, 2008
Hi all,
When I compile my project from the command line I get lots of warning messages in the following format:
HHC3015: Warning:
An alias has been created to "Utility\System_Options\Members.htm#Points_Pool_ID" but the file does not exist.
It appears to be saying that there is no file corresponding to each of my project's bookmarks? Should I be concerned about this? The file seems to comile and work correctly, but I am a little worried that when my project ships it will be a problem.
Thanks in advance for any advice on this issue,
darkagn
Views
398
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Don't know if this is the same problem I ran into or not. What I found was that in some cases my .pss file was not updating correctly when I compiled from the command line. (I compiled from a copy of the project, not in the original location.) It spit out a bunch of errors.
Although it's not the same situation - I was generating webhelp, and my errors were related to WH_LNG - it might be worth a look. What I saw was that the "Language" path in the .pss file did not update to the new location. (Other paths did update correctly.) Manually updating that line with the correct path solved the problem.
I hope that offers a clue, anyway.
G
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Hi Gravenstein and thanks for the reply,
I took a look in the pss file (using Notepad) and the Language setting points to a lng file located in my project's folder, so I don't think this is my problem. Thanks though for the suggestion - I didn't even know what the pss file was!
Anyone else have any suggestions?
Cheers,
darkagn
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
