3 Replies Latest reply on Oct 12, 2013 11:08 AM by Ann Bens
    How to view the settings of the sequence (info that appears when you first open sequence)?
      Hi I would like to ask how to view the current settings of the sequence i am already working in, the same information that appears when you first open a new sequence
      Editing mode: QuickTime DV PAL
      Timebase: 25.00fps
      Video Settings
      Frame size: 720h 576v (1.4587)
      Frame rate: 25.00 frames/second
      Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.4587)
      Fields: Lower Field First
      Audio Settings
      Sample rate: 48000 samples/second
      Default Sequence
      Total video tracks: 3
      Master track type: Stereo
      Audio Tracks:
      Audio 1: Standard
      Audio 2: Standard
      Audio 3: Standard
      I have forgotten which setting I chose for my current sequence and have tried to look under project settings and also sequence settings
      but the info that you see when you first open a new sequence doesn't show, especially if the editing mode is PAL or NTSC etc.
      How can I find out this information that my current sequence is on?
