1 Reply Latest reply on Oct 19, 2013 2:45 PM by AMULI
    Mousemove issues
    LizJablon
      I want to control one symbols timeline by using mousemove after the animation before it plays (it is a zoom in of an object then a 360 degree animation, I only want the mousemove to control the 360 animation). There are other things on the stage that I don't want controlled by the mousemove either. This is a problem because the only solution I have found is this...
      mousemove:
      this.onMove(e.pageX, epageY);
      CompositionReady:
      this.onMove=function(posX, posY){
      timelinecontrol = Number(posX)*5;
      console.log(timelinecontrol);
      sym.stop(timelinecontrol);
      I am new to Edge so the simpler the better. Thanks!
        • 1. Re: Mousemove issues
          AMULI Level 4
          Hi LizJablon,
          We use a boolean variable intro set to true while the  initial zoom animation is playing.
          Stage > document.compositionReady event handler :
          sym.setVariable("intro", true);
          Stage @ 2500 ms trigger (end of the initial zoom)
          sym.setVariable("intro", false);
          Stage > Stage.mousemove event handler :
          We prevent processing until intro animation is complete :
          if (sym.getVariable("intro"))
            return;
          e.pageX is the horizontal position. The scene being width 600 pixels, subtracting 300 gives a value in interval ] -300, 300 [ :
          var angleValue = e.pageX -300;
          We add 360 to the angle value if it's negative, which gives a positive value for the same angle :
          angleValue = angleValue < 0 ? angleValue +360 : angleValue;
          The angle element displays the angle value :
          sym.$('angle').text( angleValue);
          The rotatingDisk symbol is a 360 ms timeline of a 360° rotation of a disk :
          sym.getSymbol('rotatingDisk').stop( angleValue);
          Could not make it simpler
          You can download the example file here : https://app.box.com/s/jsxorqg8hjdo9s0bp2q7
          Gil
