6 Replies Latest reply on Oct 15, 2013 2:45 PM by JimHess
    I can't open my Nikon D7100 RAW image in Photoshop CS5
    Clive D Turner
      Q I am having difficulty downloading Camera Raw 6.7 onto Photoshop CS5 Please advise
        • 1. Re: Downloading issue
          John Waller Adobe Community Professional & MVP
          What kind of difficulty?
          • 2. Re: Downloading issue
            Clive D Turner Level 1
            I have recently purchased a Nikon D7100 camera and when I upload the raw files into Photoshop CS5 it doesn't recognise the Raw files. I have used the update function to upload the latest version of Camera Raw (6.7) but that has had no effect. Is there a Camera Raw plug in which will resolve the problem.
            • 3. Re: Downloading issue
              The D7100 was added as a supported camera in version 7.4 which is only compatible with Photoshop CS6.  You will either have to upgrade or use the latest DNG converter.
              • 4. Re: Downloading issue
                Thank you for your response. I would rather not have to upgrade as CS5 is more than adequate for my needs. Can you provide more information on the DNG converter. Can I download and install as a plug in.
                • 5. Re: I can't open my Nikon D7100 RAW image in Photoshop CS5
                  ssprengel Adobe Community Professional & MVP
                  The DNG Converter 8.2 is available in the Camear Raw updates section of Adobe’s updates page:  http://www.adobe.com/downloads/updates.html
                  The DNG Converter is a standalone application that you must run explicitly to processes a FOLDER of raw files at a time, and creates a copy of each of the folder’s raw files that has a DNG extension.  Its purpose is to create a package containing the original raw data plus the camera profile and other camera-support parameters so that older ACR plug-ins have enough information to process the raw data.
                  This is an extra step that some find inconvenient and if you’re not comfortable deleting your original RAWs (I never delete them) then you’ll end of with things taking about twice the space.
                  Personally, I always update to the current version of PS so I have the current version of the ACR plug-in so PS will integrated seamlessly with the current version of Lightroom which is the main image-adjustment component of my workflow, and I rarely use PS, anymore.
                  • 6. Re: Downloading issue
                    The DNG converter is a freestanding (not a plugin) program that can be used to convert your original raw files to the digital negative format.  The new files will contain all of the original raw image data, but the file format is one that has been standardized.  It will enable you to edit your raw files with the older version of Photoshop that you are using.  I will provide you with the link to the Windows version.  You can Google DNG converter Mac to get that version if you need it.  Download it, install it and run it.  One little point that seems to confuse new users.  There is a prompt asking you to point to the folder containing your raw files.  Note that you should just choose the folder and not expect to see a list of your raw files.  If you do that, everything should run smoothly.
                    http://www.adobe.com/support/downloads/product.jsp?product=106&platform=Windows
