1 Reply Latest reply on Oct 14, 2013 6:17 PM by Lucia Lao
    field size
      Can you make the fields larger?
        • 1. Re: field size
          Lucia Lao Employee Moderator
          Are you asking if you can resize the fields when you create them in FormsCentral / Design tab? If so, then yes, after you added a field, select the field, hover on the field and when you see the resize handle (the double vertical lines, or the double edges arrow) click+drag to a new position.
          For example with a text field, you can resize the label box (when your labels are set to 'Label Right' or 'Label Left' position) as well as the input box.
          Hope this answers your question,
