Hi All,
I've been running into some serious issues with our environment, it seems we have a lot of different versions of Flash Player floating on everyones machine at the moment - I'd like to change this as easily and quick as possible.
I was writing a script that used the Universal uninstaller to remove all versions of Flash Player then it would install the latest. However after it runs it will only partially uninstall the older versions of Flash Player, it sometimes will uninstall the whole thing and Install the latest perfectly. I noticed this only happens on the real older versions of Flash (11.2 - 11.6). After it uninstalls it partially I try to run the (.msi) installer manually and I get an error code 1722 ("There is a problem with this Windows Installer Package. A program run as part of the setup did not finish as Expected") - where after i must run the msfixit tool(http://support.microsoft.com/mats/program_install_and_uninstall/) to fully remove the program.
The script goal:
C:\Windows\SysWOW64\Macromed\Flash
%appdata%\Adobe\Flash Player
%appdata%\Macromedia\Flash Player
User Environment:
Deployment plan as of now is Group Policy - later ideally SCUP once SCCM 2012 is setup.
Also seeking advise to stabalize environment for future deployments, ie: should i disable automatic update and deploy updates accordingly or is there a way to allow the users to get the latest versions of flash.
Thanks all!
