2 Replies Latest reply: Oct 15, 2013 9:03 AM by Omke Oudeman RSS
    Clicking on subfolders under view.
    twtybrd678 Community Member
      How do I keep the check mark under View-View Subfolders checked? Everytime I open it up I have to click on view subfolders.
      joe
        • 1. Re: Clicking on subfolders under view.
          Curt Y Community Member
          If you have "load Bridge on Startup" checked (adv. pref.) you have to close with File/exit.  Or uncheck the startup option.
          • 2. Re: Clicking on subfolders under view.
            Omke Oudeman Community Member
            Unfortunately this behavior is as designed, you have to click on the view items from subfolders every time again. Opening an extra window helps because the behavior for that window stays the same while you can use other views in the extra window but once restarted Bridge needs to be set again to this setting.
            It would be preferred as being 'sticky' but it isn't
            Use a collection for being able viewing files from different folders but you have to create one first.
