3 Replies Latest reply on Oct 18, 2013 10:06 AM by elainecc
    Where is the stage class defined? Why is the -webkit-transform property set for everything?
      Working with inline SVGs has become quite a pain with Edge Animate as of late due to the following CSS declaration:
      .EdgeStage, .EdgeStage * {
      I could not track down where this is defined using Chrome's inspection capabilities, or by manually searching through all files. In the case of inline SVGs it breaks all transform attributes and causes a large number of problems. Inline SVGs are a requirement for the project due to the need to be able to reach into and change them.
      Removing the class after the stage has loaded and before any content is generated solves the issue, but it's a hacky solution and I would prefer to avoid it if possible.
