1 Reply Latest reply on Aug 4, 2006 11:35 AM by jrunrandy
    ie6 browser causing ioerror
    sp0rArb3jd3r
      We are using flex 2 to develop a survey chart of various web traffic parameters.
      To do so we need to load XML served to the flashapp on request by an sql-server.
      When we try it out in the firefox browser, the opera browser, even in the internet explorer 7.0,
      it works fine. But in internet explorer 6.0 we seem to hit a wall.
      Every time we try and run it we get an IOStreamError #2032.
      Anyone experiencing similar problems?
      Anyone know of a solution/an explanation?
      It seems to be in the communication with the server that somethin is amiss.
      If we try to just load a static xml file it works fine.
      Any help would be appreciated.
      Here's the sample code:
      private var inhale:XML = new XML();
      private var rq:URLRequest = new URLRequest();
      private var ld:URLLoader = new URLLoader();
      public function init():void{
      if(Application.application.parameters.xml==null){
      rq.url="ychartdata.xml";
      else {
      rq.url="/../.."+Application.application.parameters.xml+"&parameter2="+Application.applica tion.parameters.parameter2;
      base+=Application.application.parameters.xml+"&parameter2="+Application.application.param eters.parameter2;
      ld.addEventListener("ioError", errorHandler);
      ld.addEventListener(Event.COMPLETE, parPlex);
      try {
      ld.load(rq);
      catch(e:IOError){
      trace("IOerror");
      public function errorHandler(e:IOErrorEvent):void{
      Alert.show(e.type+":"+e.text);
      public function parPlex(whatever:Event):void {
      parX();
      public function parX():void {
      inhale = XML(ld.data);
      //dothestuff
      Sincerely
      Sporarbejder
