Hello All,
Quick back-story. We purchased a monthly subscription to Captive when they announced HTML5 support, but due to the lack of supported devices we also purchased a subscription to Presenter which has a mobile app. A few of our content were created using Captivate now these projects had voice over’s that I had to export and rename the audio files to be associated with the correct slide. I have gone ahead and manually imported each individual audio file to the correct slide in the PowerPoint presentation.
My issue now is when I publish the PowerPoint (2007) using Presenter 9 the project does not load it just has he spinning arrow. For some reason the project works in “preview mode” but not when it’s published. Is there a way to find the path where the cache preview files are stored?
Any help would be greatly appreciated.
Hi Jerry,
Please check the following settings:
Goto Adobe Presenter>>quiz>>Manage>>Reporting
Make sure that AICC is not enabled.
If AICC reporting is enabled , it will not play in Destop mode. Please disable the AiCC .
If this is not the case then plase share you sample file to me at sunsahu@adobe.com and will try to resolve your issue at the earliest.
Sunil
Adobe Presenter Engg Team
Hi Jerry,
Sunil
Mr Sahu,
That did the trick. I'm now able to view the published content.
Thank you.
