2 Replies Latest reply on Oct 15, 2013 3:34 PM by Aegis Kleais
    I'm trying to print up my certificate from the AHA website and it is not accessible
      The following information is meant for the website developer for debugging purposes.
      Error Occurred While Processing Request
      The  C:/inetpub/wwwroot/Clients/org.onlineaha/REL-20130506/website/wwwroot/../../docs/certific ate_templates/prodnum_70-2304-Archived.pdf  file specified in the cfpdfform tag either does not exist or is not  accessible by this tag.
      • Enable Robust Exception Information to provide  greater detail about the source of errors.  In the Administrator, click  Debugging & Logging > Debug Output Settings, and select the  Robust Exception Information option.
      • Check the ColdFusion documentation to verify that you are using the correct syntax.
      • Search the Knowledge Base to find a solution to your problem.
      Browser  Mozilla/5.0 (Windows NT 6.1; WOW64; rv:24.0) Gecko/20100101 Firefox/24.0
      Remote Address
      Referrer  http://www.onlineaha.org/index.cfm?fuseaction=myaccount.home
      Date/Time  15-Oct-13 05:03 PM
