• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Problems installing Flash 11.9 on Mac
New Here ,
Oct 15, 2013 Oct 15, 2013
I tried to install the latest update for flash and it failed. I followed the regular troubleshooting instructions for Mac (including remove old version of flash) and ran the package again... failed.
I checked the package contents and down to the resources folder to run Adobe Flash Player.pkg (original version didn't have this so found the full install package).
When I run the pkg at Destination Select screen my disks all have the ! next to them saying that "Adobe Flash Player can't be installed on this disk."
I tried repairing disk permissions (there were no problems) and still no joy.
Any help please?
Views
808
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Oct 15, 2013 Oct 15, 2013
Are you running 10.8.5?
If so, did you delete the "mach_kernel" file that appeared after the 10.8.5 update installed?
Votes
Translate
Translate
LEGEND ,
Votes
Translate
Translate
Report
Report
New Here ,
Yes, running 10.8.5
and I think yes... I remember removing mach_kernel.
Is this the issue?
Votes
Translate
Translate
Report
Report
New Here ,
Ok, yes it was. Thanks!
What is in mach_kernel to prevent the install?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
"mach_kernel" is the base file for OS X.
If you run Time Machine and have backups prior to the 10.8.5 update, you can restore it.
You'll need a preference pane called "Secrets" to eb abel to see it. You can get "Secrets" here:  http://secrets.en.softonic.com/mac
Install it, and open your System Preferences. You can make "hidden files" visible, even in Time Machine, and then you can resotee the mach_kernel file to its original location.
If you DON'T use Time Machine, there's a zip file I have with a replacement here: http://tinyurl.com/kq3cu72
Click it and it should download.
Put the zip file in your Mac HD directory and THEN unzip it, because you WON'T be able to see it.
Reboot and try running the installer again.
If it gives you any troubles, that's where the news gets bad. You'll have to reinstall OS 10.
Votes
Translate
Translate
Report
Report
