10 Replies Latest reply on Jul 29, 2014 3:37 AM by hparmar
    Stream records for sometime and then gives Stream.Record.NoAccess
    Crimson Sahil
      Following are the details of the Stream:
      Stream: Video, encoded in H.264, H264Profile.BASELINE, H264Level.LEVEL_3, recording the f4v.
      I try to upgrade/degrade the bitrate(only) of the stream, using setQuality(br, q) method with respect to the change in bandwidth of the publisher.
      Issue: With use of setQuality, after a few bitrate changes, it gives Stream.Record.NoAccess error and stops the recording of the stream at that point. Noticably the live stream keeps on running well but the part after Stream.Record.NoAccess does not get recorded.
      Normally the stream records fine and completely, there are no issues of readOnly folder/file in my case. I have tried the issue on all FMS 3.5 to 5.0 and it occurs.
      Can anybody provide a fix as i have not been able to find help on the web other than these:
      1) help docs
      NetStream.Record.NoAccess
      error
      The client tried to record a stream that is still playing. Or the client tried to record (overwrite) a stream that exists on the server with read-only status.
      2) http://forums.adobe.com/message/3928900
      Thanks.
      Sahil.
