1 Reply Latest reply on Oct 17, 2013 9:33 AM by Jim_Simon
    Multi-Camera setup workflow CS6
    TacoRye Level 1
      Hello Forum,
      My current project involves 4 camera angles with audio recorded on a separate 6 channel audio recorder.
      I am having to do a long work around to make the multi-camera sequence take the 6 channel audio, but I am unable to recall it in the source window to play the audio.
      What is the best way to setup a multicam sequence when audio is not from the cameras? (Syncing multiple takes from a tv show)
      Cheers,
      Ryan
        • 1. Re: Multi-Camera setup workflow CS6
          Jim_Simon Level 9
          In my view, the best way to set up any multicam sequence is still the original way - manually.
          Create a sequence and add all your clips.  Sync them manually.  Create a second sequence and nest the first.  Right click on that nested sequence and Enable Multicam.
