3 Replies Latest reply on Jan 7, 2008 7:19 AM by kglad
    email return data formating
    pow_haaweeese
      hi all,
      I'm building a basic "contact me" email return page, and it's working...at least partially.
      (that's the good news)
      the "bad" news is..
      when I fill in the above blanks in the swf, and click send, it opens my email ("mail"-mac) and populates my correct email address, but then puts ALL the information, not just the subject line info, in the subject window. Is there a way to tell the code to put the subject line "jb3_contact" in the subject of the email, and then "tab" to the body area of the email to dump their name, email, and message?
      what my email subject line looks like: (what I typed into the swf fields)
      Subject: jb3_contact:= Name: jim Email: jimsbook.com Message: hey dork...
      I guess I'd like the subject line to be "jb3_contact" ONLY. and their message info in the "body" area of their email.
      like:
      Email: jimsbook.com
      text field instances:
      name [ iptxt_name ]
      email [ iptxt_email ]
      msg [ iptxt_msg ]
      I'd appreciate any thoughts...
      best,
      pow
      following code on the "send" button:
      [code]//email send button info, for "contact me" area
      on (press) {
      // these statements simply read the data from the input fields
      // and print them to the output window for debugging
      trace(this.iptxt_name.text);
      trace(this.iptxt_email.text);
      trace(this.iptxt_msg.text);
      // save the return email address
      returnEmail = this.iptext_email.text;
      // create an empty string variable to store the data
      urlData = "";
      // assemble the data from the fields into the new variable
      urlData += " Name: "+this.iptxt_name.text+newline+" ";
      urlData += " Email: "+this.iptxt_email.text+newline+" ";
      urlData += " Message: "+this.iptxt_msg.text+newline+" ";
      // print url data to output window for debugging
      trace(urlData);
      // send email using user input data
      getURL("mailto:jim@jimsbook.com?subject=jb3_contact="+ urlData);
      //>>>>>>>>>>>>>>[/code]
        • 2. Re: email return data formating
          pow_haaweeese Level 1
          hello kglad,
          thank you very much for this, adding your line alone with one other addition did exactly what I needed.
          other added line:
          "Add another variable(body in this case) in the mailto and use "%0A" instead newline"
          (see code below)
          ...that did exactly what your code did, with basically a carriage return, between for readability.
          the email send executed perfectly:
          subject (in the subject line, all by itself)
          and then:
          "Name: Jim lastName
          Email: jim.contactme@some.com
          Message: hey Jim how come you're such a dork? "
          all stacked, and clear in the body area.
          Thank you very much kglad.
          best,
          Pow.
          code below is to create a return email from a "contact me" form you build in flash.
          input text fields have instance names of as follows:
          name ( iptxt_name )
          email ( iptxt_email )
          message ( iptxt_msg )
          last line of code just has my email I want it to go to, along with what I want in the subject line "jb3_contact"
          hope this helps someone else.
          <final code>
          on (press) {
          urlData = "";
          urlData += " Name: "+this.iptxt_name.text+"%0A";
          urlData += " Email: "+this.iptxt_email.text+"%0A";
          urlData += " Message: "+this.iptxt_msg.text+"%0A";
          trace(urlData);
          getURL("mailto:jim@somewhere.com?subject=jb3_contact&body="+ urlData);
          <end_code>
          • 3. Re: email return data formating
            you're welcome.
