17 Replies Latest reply on Jun 21, 2017 1:00 PM by rob day
    Indesign (Overprint Fill) bug? "White" does not print!
    IdamIndia Level 1
      Prologue
      I faced an issue that took some days to solve, with help from experienced professionals.
      I feel it is a bug, or atleast there is something that can be done in InDesign software to prevent it from happening.
      I share here as a discussion, as I wonder how this is not faced by anyone else (?!) before this can be reported as a bug.
      Issue
      My white text would not print. I felt I had made no mistake, or did I? or did InDesign not let me correct (overprint fill option is greyed out for white!)?
      The specifics are illustrated in the attached images:
      1. The color value of "white boxes" swatch which is used for text
      2. As is view of content without Overprint Preview
      3. As is view of content WITH Overprint Preview (some white text disappears) - compare the area below the MAPS title.
      4. Inspection of visible white text
      5. Inspection of invisible white text (the cuplrit is nailed!)
      But wait! the overprint fill option is disabled (greyed out) but shows a tick! I understand/assume that for white/paper this option is disabled. but then how come it is showing ticked.
      Solution (hack?)
      - Change the invisible text to any other non-white color
      - Untick "overprint fill"
      - change color back to white/paper
      - Now white text becomes visible and is able to print!
      Hmm, now is that not a software bug?
        • 1. Re: Indesign (Overprint Fill) bug? "White" does not print!
          Rik Ramsay Level 4
          Without seeing the styles used or the actual file it's hard to determine. My initial thought is that you have a character/paragraph style applied to the text that disappears which has a "overprint fill" setting. Maybe this post has some further insight?
          http://indesignsecrets.com/beware-overprinting-white.php
          EDIT::// I meant to add this but my trigger finger was too fast. Why are you using a white process swatch when all you need to use is the paper swatch? White is unprintable unless it's as a spot color.
          • 2. Re: Indesign (Overprint Fill) bug? "White" does not print!
            BobLevine MVP & Adobe Community Professional
            Why are you using a created white swatch? Is there some special purpose here? If not, use paper.
            • 3. Re: Indesign (Overprint Fill) bug? "White" does not print!
              When you make a new CMYK swatch with 0 values (0|0|0|0) it is set to knockout and the Overprint attribute is not available, which makes sense because in process printing if a white object doesn't knock out it doesn't print—it's hard to think of a case where you would want process white to overprint.
              You can start with a non-white mix, set it to Overprint then change the mix to 0|0|0|0 and it will remain as overprint with the Overprint attribute grayed out. So yes, if you start with a non-white CMYK mix and edit its values to white you could force it to overprint (not print). You can use your solution to change the overprint setting, or make the swatch non-white, uncheck Overprint, and set the color back to white.
              • 4. Re: Indesign (Overprint Fill) bug? "White" does not print!
                IdamIndia Level 1
                Thanks Bob Levine and Rik Ramsay: <about why not paper> In my learning phase of Indesign (I am just a few months old user of Indesign), approaching things in a modular way, I thought using my own "white" will give me the flexibility to change it to a slight grey or something else later. that is why a "duplicate" white/paper color.
                I will try using paper to see if it helps. But what I still don't get is: "If white cannot be allowed to overprint-fill (the property is greyed out) why changing that tick using my solution/hack helps?"
                • 5. Re: Indesign (Overprint Fill) bug? "White" does not print!
                  When you made the swatch it probably had some value other than 0|0|0|0 and you set it to Overprint, then changed it to 0|0|0|0.
                  There's nothing wrong with having a swatch that's variable, but in general you want to leave Overprint unchecked when you apply color except for small black type.
                  • 6. Re: Indesign (Overprint Fill) bug? "White" does not print!
                    IdamIndia Level 1
                    Yes Rob Day, you are right. And thanks for that last tip: "In general you want to leave Overprint unchecked when you apply color, except for small black type."
                    To be honest, learning and exploring Indesign on my own, I made some wrong assumptions trying to relate wrong concepts with the terms. In this particular case, aware of overprint as well as tracking, I understood "overprint" to be "tracking" (that is what the word made me think it was - the text overprints its area to hide the possible white gaps due to inaccurate registration). That made me use "overprint" for everything initially! For people using this for a long time, the term "overprint" may look OK, for someone new (like I was) the term felt it meant tracking.
                    • 7. Re: Indesign (Overprint Fill) bug? "White" does not print!
                      IdamIndia Level 1
                      Thanks for the link Rik Ramsay. Yes that link describes the scenario exactly as I faced. Interestingly the author says "It’s a subtle but dangerous bug."
                      • 8. Re: Indesign (Overprint Fill) bug? "White" does not print!
                        Do you mean trapping? In modern print workflows trapping is handled at output either by third party software or via InDesign's trapping presets—there's no reason to try and set manual traps. You can set overprints, but printers often will ignore document overprints because they can get in the way of their trapping at output. The disabling of overprint for white objects is more of a feature than bug.
                        It's also a good habit to turn on Overprint or Separation Preview which accurately softproofs color conversions and overprint objects.
                        • 9. Re: Indesign (Overprint Fill) bug? "White" does not print!
                          Rik Ramsay Level 4
                          In addition to what Rob has suggested, I would set up a print profile for your work that checks for common issues such as locked/restricted typefaces and overprint. You can do this by clicking at the bottom of the page (might show a green/red dot with *errors) and select "Define Profiles". You can then create a profile to your requirements and ask it to check for Overprint of white (see screenshot). With this profile, it will show you 'live' at the bottom (green/red dot) whether anything is needing attention.
                          • 10. Re: Indesign (Overprint Fill) bug? "White" does not print!
                            SJRiegel Adobe Community Professional & MVP
                            A better way to provide the flexibility you want would be to use Paragraph styles and Character styles for all of your formatting. That way, you can globally change not only the color, but all of your text attributes for each style with one easy move.
                            • 11. Re: Indesign (Overprint Fill) bug? "White" does not print!
                              IdamIndia Level 1
                              @Rob Day, yes I meant trapping (not tracking! but I dont see a way to correct/edit my earlier comment). Hope it does not confuse other readers, and they dicover or figure out.)
                              @SRiegel, yes I had invested effort and time in setting up para and chr styles, and even tried to re-define the issue using the style. But it seemed the color was still a local attribute somehow. Style cascade issue I think, where the local property was overriding the style. Thus I had to clear individual formatting everywhere and ensure I only had styles.
                              But I also discovered an indesign plugin that could have helped my case (Note: I have not tried this plugin as yet). http://indesignsecrets.com/resources/plug-ins-and-scripts has a "Preserve Local Formatting" at the end. This promises to create character styles and apply them. This could have eased my effort. Then my next question would have been how to combine styles or select text with say two different styles and apply another third style... Ok. This is deviating from the topic (perhaps needs a sepearate post).
                              • 12. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                Kathryn Klein
                                I believe that this IS a bug.  I am a long-time InDesign user and pretty much know what I'm doing.  I was working on a doc that I have used successfully in past versions of INDD - now open in CC - just to make a few minor changes.  When I saved my production PDF, I found that one of my paragraph styles with type set to Paper was not appearing.  Looked at the style and overprint was NOT checked, yet in the Attributes pane, overprint was ticked.  No explanation for this.  To fix, I simply changed the type color in the paragraph style to another color and overprint was mysteriously checked (though it had not been checked when the color was set to Paper).  I unchecked overprint and changed the color back to Paper and my type appeared. THAT is a bug!
                                • 13. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                  It's difficult, but not impossible, to get paper set to overprint in ID. Did you have any effects applied to the text at any point?
                                  • 14. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                    Just curious, how? I can get a white swatch to overprint but not the default [Paper]
                                    • 15. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                      Perhaps I mispoke and it's only with a swatch defined as 0,0,0,0, and honestly I don't remeber how it was done, just thatI've seen it, and it involved some sort of effect. I'm presuming here that the common problem -- an overprint imported from Illustrator where it's relatively easy to set -- is not in play.
                                      • 16. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                        samanthar91918670
                                        I'm having a similar problem, except the text in question (in a table) is viewable when I have selected Overprint Preview from the View menu, but not when that option is deselected. Is there a similar fix for this issue?
                                        • 17. Re: Indesign (Overprint Fill) bug? "White" does not print!
                                          That would happen if you uncheck Print Layer from the layer's Layer Options dialog. A layer with printing turned off will be in italics in the Layers panel.
                                          If that doesn't work start a new thread this one is 4 years old.
