2 Replies Latest reply on Oct 17, 2013 8:08 AM by EL_MISMOLOCO
    Acute Accent...
    EL_MISMOLOCO
      Hi, I have this three scripts to read and retrive audio files and their time to a field member. The problem is that ACUTE CHARACTERS don't come out right.
      PLEASE, SEE AFTER THE SCRIPTS.
      on musicLoad
      musicPath = _movie.path & "MusicFolder"
      set the itemDelimiter = "."
      fxObj = xtra("FileXtra4").new()
      fileStructure = value(string(fxObj.fx_FolderToList(MusicPath)))
      fxObj = 0
      dialogText = ""
      repeat with p = 1 to fileStructure.count
      hhmm = getDuration(string(musicPath)&"\"&fileStructure[p])
      temp = dialogText &hhmm&&" "&& fileStructure[p]
      fileOnly = temp.char[1..(length(temp)-4)]
      dialogText = fileOnly & RETURN
      end repeat
      member("musicField").text = string(dialogText)
      end
      on getDuration filename
      theAudio = new(#sound)
      theAudio.fileName = fileName
      theDuration = theAudio.duration
      theAudio.erase()
      return formatElapsedTime (theDuration)
      end
      on startMovie
      member("musicField").text = EMPTY
      end
      on formatElapsedTime tm
      inttime = integer(tm)
      m = 0
      s = inttime / 1000
      if s >= 60 then
      m = s / 60
      s = s mod 60
      end if
      if s < 10 then s = "0" & s
      if m < 10 then m = "0" & m
      return m & ":" & s
      end
      And this is what I get:
      03:47 Brother Louie - Stories-01-1973-[USA]-ASCAP
      02:55 Build Me Up Buttercup - The Foundations-03-1969-[UK]-BMI
      03:45 Burning Heart - Survivor-02-1986-[USA]-ASCAP
      02:50 Bus Stop - The Hollies-05-1966-[UK]-BMI
      02:46 But It's Alright - J J Jackson-22-1966-[USA]-ASCAP
      02:42 Butcher's Tale - The Zombies-1969-[UK]-BMI
      02:39 By the Time I Get to Phoenix - Glen Campbell-26-1967-[USA]-BMI
      IT NOT ONLY MESS UP THE CHARACTERS, BUT ALSO DON'T GET THE TIME ON THE FILES
      00:00 Deja V�ionne Warwick-15-1980-[USA]-BM
      00:00 Volver� La Canci� Jos�Jos�M
      ORIGINAL FILE NAMES
      00:00 Deja Vú Dionne Warwick-15-1980-[USA]-BMI
      00:00 Volveré La Canción - José José - BMI
      I heard about an xtra named PRegEx, I download it, but it seems to complicated for me.
      Any help will be appreciated
      Brian
        • 1. Re: Acute Accent...
          Sean_Wilson Adobe Community Professional
          Your problem is using FileXtra4. You are using it to get filenames, some of which contain multi-byte characters. FileXtra4 wasn't engineered to handle these characters. Since you are only using it to grab a list of filenames in a folder, start by trying the same thing with Buddy API (which should handle high ANSI characters). I have re-written one of your handlers below and replaced FileXtra4 with Buddy API:
          on musicLoad
            -- _player.itemDelimiter = "."
            fileList = baFileList(MusicPath, "*.*")
            dialogText = ""
            repeat with aFile in fileList
              hhmm = getDuration(musicPath & "\" & aFile)
              temp = dialogText & hhmm && " " && aFile
            end repeat
          end
          • 2. Re: Acute Accent...
            EL_MISMOLOCO Level 1
            Thanks Sean, you saved my day!
