6 Replies Latest reply on Oct 17, 2013 5:31 AM by Doc Maik
    Alignment of objects
    Doc Maik Level 4
      Following situation: I got, like, 10 objects in vertical aligment, all have the same width. Now I want their center point to align on X = 7.5mm. So I select them all, use "Align on vertical axis" (or so, got german Indesign) and then set the top-middle reference point
      and set X to 7.5mm with all 10 objects selected. After this, when selecting a single object, the X value is not 7.5, it is some higher or lower (like in the small image).
      But for all objects, the average of the 10 X values will still be 7.5mm.
      How to get rid of this? Do I have to select every single object and set X = 7.5mm manually?
