4 Replies Latest reply on Oct 17, 2013 3:24 PM by nec240
    Need script to replace "J/" with "*" in PDF form.
    nec240
      This is an error I'm getting when I scan specific barcodes into a form field. Everything works fine unless there is a "*" (asterisk) in the barcode. If there is one, it gets replaced with "J/" in the form field. Is there a setting I can change in LiveCycle Designer ES2 or Acrobat Pro X to let the field accept "*", or, if not, what is a basic string replace script that would automatically fix this? I thank you for any ideas.
