1 Reply Latest reply on Jan 9, 2008 7:14 AM by
    Subtopic Messaging problem
      I have a setup where a java thread is running server-side generating messages (with a subtopic header) for flex consumers. It works fine when the flex consumer doesn't specify a subtopic, but when the subtopic is used, the messageEvent handler is never envoked. I have double-checked that the subtopics are valid and match. Are there any other things I should be checking?
        • 1. Re: Subtopic Messaging problem
          Turns out I had a data type mismatch in the subtopics. On the flex side, the subtopic is required to be a String. In java, flex.messaging.messages.AsyncMessage.setHeader will accept any Object as a header value. In my case it was a Double. When I did a toString, everything started working as expected.
