5 Replies Latest reply: Oct 21, 2013 9:22 AM by Anit Kumar Panda RSS
    Report framework requires at least one grouped column
    Oliver-2012 Community Member
      A Report requires at least one grouped column, otherwise finish button will lead to "The report doesn't contain grouped columns".
      Is it possible to configure a report not to require grouping?
        • 1. Re: Report framework requires at least one grouped column
          Eddie Lotter Community Member
          A report does not require grouping.
          Did you create a report using the built-in wizard?
          Create a blank report without the wizard. Add a query and then add fields to the detail section. You should not get the error message you mentioned.
          • 2. Re: Report framework requires at least one grouped column
            I created a new report (Page Activity Report) from the Tools/Reports console. I added two columns (Page and Type) and tried to click on "Finish" -> error as described.
            Then I created my own report (copied from libs/cq/reporting/components/auditreport) with custom columns (Path, Title, and some more). The report displays the columns, but click on finish results in the same error, too.
            Is there any special property I have to set in the configurations/Nodes of the report?
            • 3. Re: Report framework requires at least one grouped column
              I'm beginning to suspect you're not talking about ColdFusion reports, right?
              This sub-forum is about creating reports for ColdFusion.
              If you are indeed creating a report for ColdFusion, but you're using a third-party report writer, please identify the report writer so that people who have experience with it will be able to help you.
              Sorry for the confusion.
              • 4. Re: Report framework requires at least one grouped column
                Hi Eddie,
                I am so sorry - I was sure to start a CQ5 thread...
                CF is of course a total different story...
                • 5. Re: Report framework requires at least one grouped column
                  Anit Kumar Panda Employee Hosts
                  Moving the discussion to Adobe CQ forum.
                  Regards,
                  Anit Kumar
